5¼" External Drive Enclosure Recommendations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 06-06-2011, 11:59 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Thinking of putting my Blu-ray ODD in an enclosure for easy access on my desk and occassoinal use on my HTPC so I need to get an enclosure for it.
Any recommendations?
Sammy2 is offline
post #2 of 15 Old 06-06-2011, 12:35 PM
hlkc's Avatar
IDE version
SATA version
hlkc is offline
post #3 of 15 Old 06-06-2011, 01:19 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Wonder if I can p/u a second power brick somewhere for that so I don't have to drag the cables around but just the enclosure?
Sammy2 is offline
post #4 of 15 Old 06-06-2011, 01:36 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I think maybe USB 2.0 is about the limit of a faster blu-ray drive? Mine is rated at 12x but seems to pump 6x when using MakeMKV so maybe it won't be an issue.
Sammy2 is offline
post #5 of 15 Old 06-06-2011, 01:59 PM
sneals2000's Avatar
Quoted: 253 Post(s)
Liked: 131
Some BD writers and some USB2.0 enclosures don't play nice together, though you can get enclosures with USB2.0 and eSATA outputs, and if your PC has an eSATA input that might be a neat solution (it's pretty close to identical to the connnection you would have for an internal drive)
sneals2000 is offline
post #6 of 15 Old 06-06-2011, 02:07 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I've got eSATA II input on both my Desktop PC and my HTPC (they both have the same MoBo).
Sammy2 is offline
post #7 of 15 Old 06-06-2011, 02:23 PM
Zon2020's Avatar
I haven't used their optical drive enclosure, but I've had great luck with Vantec's Nexstar line of e-sata/USB hard drive enclosures.
Zon2020 is offline
post #8 of 15 Old 06-06-2011, 02:33 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Seems like a personal choice to me.
Has the interface u need, that's really it.
I personally prefer one with a built-in PSU, no dangling power brick, and for a removable, no fan (noise) needed. and if moved frequently, some sort of handle would be a very nice touch indeed not that I've seen any like that.
Go wild.
MrBobb is offline
post #9 of 15 Old 06-06-2011, 02:45 PM
lsilvest's Avatar
Go to Thermaltake's website. They have some refurbs at very good prices. I generally use the docks, but I have a Thermaltake Silver Duo that has both eSata and USB options and it's been very reliable (3 years old refurb and no problems). Not sure, but you may even be able to get an extra power adapter for it through them.
lsilvest is offline
post #10 of 15 Old 06-06-2011, 02:59 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Didn't see any 5¼" drive enclosures on Thermaltake's site.
Sammy2 is offline
post #11 of 15 Old 03-03-2012, 09:53 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Never got this.. Any recommendations?
Sammy2 is offline
post #12 of 15 Old 03-03-2012, 01:20 PM
tomandbeth's Avatar
I used a blank expansion slot panel and installed a power plug in it, then soldered it to one of the PSU leads. Be aware that many/most SATA enclosures need the system powered down before connecting (for the drive to be recognised) USB doesn't have that restriction.
tomandbeth is offline
post #13 of 15 Old 03-04-2012, 07:56 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Got this one.
Sammy2 is offline
post #14 of 15 Old 03-04-2012, 08:46 AM
AVTechMan's Avatar
Quoted: 34 Post(s)
Liked: 37
I have Vantec enclosures for both my IDE HD-DVD drive and BD SATA drive. Works like a champ for me.
AVTechMan is online now
post #15 of 15 Old 03-04-2012, 09:05 AM
assassin's Avatar
Quoted: 84 Post(s)
Liked: 246
I have vantec as well. Not the highest quality construction but works very well. I would buy again.
assassin is online now
Reply Home Theater Computers
