Audio out of sync with DirectVobSub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-23-2011, 11:48 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
After I installated of DirectVobSub, the audio streams on playback get progressivelly out of sync and are lagging the video stream and the subtitle streams out of sync too and not in sync with either the audio and the video.
I am using Win7x86 WMC with LAV splitters with an i3-550 CPU/GPU. The audio/video sync was fine before installation of DirectVobSub.
Has anybody else experienced this issue? Any solutions to it?
Sammy2 is offline
post #2 of 9 Old 06-24-2011, 08:08 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
You could call this a shameless bump bet I guess I'm the only one experiencing this.
Might my diagnosis be incorrect?
Sammy2 is offline
post #3 of 9 Old 06-24-2011, 09:22 AM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
simply replacing the installed vsfilter.dll with THIS ONE may resolve your issue.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #4 of 9 Old 06-24-2011, 09:31 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Hey Shark Thanks.
A couple of questions...
What is vsfilter.dll Ver4.7? is it the latest VobSub filter?
How's the implementation of LAV in your pac coming along?
Sammy2 is offline
post #5 of 9 Old 06-24-2011, 09:52 AM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
it is a 'work in progress' develoment built soon to be added to the MPC-HC SVN repository
implementation of new splitters/decoders is not an issue.
LAV is simply not ready for primetime distribution.
If you wish to use your HTPC as an alpha testing ground, I applaud you.
Shark007 is offline
post #6 of 9 Old 06-25-2011, 07:53 AM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
you never did state whether or not the vsfilter update solved your issue.
To keep you abreast with development, HERE is v5.
Shark007 is offline
post #7 of 9 Old 06-30-2011, 09:37 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I've tried the previously posted vsfilter which caused issues with no playback at all. Then I went to an earlier restore point before installing VobSub and tried again. Now I am still having this sync issue.
Recently I saw a post stating that MakeMKV fails sometimes and am wondering if that is my issue? I've made a few mkv's using it latelly some of which don't have HD Audio tracks which playback fine. All the mkv's I've made with dts-HD/MA are having this issue and I don't have any Dolby TrueHD movies to verify if that codec is working right now.
Do I have an issue with the file/container and not the splitter/decoder for HD Audio???
Sammy2 is offline
post #8 of 9 Old 06-30-2011, 02:05 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I was hoping you guys would fix this problem for me...
sight un-seen...
over the internet...
for free...
Sammy2 is offline
post #9 of 9 Old 05-15-2013, 05:39 AM
Golfimbul's Avatar
I've got the same issue. I'm using DirectVobSub_2.41.7036_x64
Any tips? Trying to get bluray MKV rips made with makemkv working with subtitles with LAV Filters and directvobsub alone.
I managed to get the forced subtitles working by setting flags in mkvmerge header editor but media center wouldn't natively play the subtitle. It does play the subtitles with directvobsub installed but the audio is WAY out of sync... HELP!
Golfimbul is offline
Reply Home Theater Computers
