MPC-HC compatibility with Shark007 x64? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-24-2011, 06:16 PM - Thread Starter
lifespeed's Avatar
Quoted: 154 Post(s)
I would like to install Media Player Classic Home Cinema x64 alongside my working Windows 7 64-bit setup with Shark007 codecs. Everything works perfectly now, from MKV to FLAC, even DTS audio.
I thought MPC-HC might add codecs of it's own. Yet it is a direct show player, so could theoretically use my existing codecs.
Am I going to mess up a perfectly good system by installing it? I really just want the player, and no modifications to my codecs. Guess I should take a disk image first . . .
Lifespeed
91XG Yagi for San Francisco, DB4e bowtie for Fremont
SiliconDust HDHR4-2US network tuners, one per antenna
Media server PC running Emby
TV Fool report
lifespeed is offline
post #2 of 3 Old 06-24-2011, 06:28 PM
Shark007's Avatar
Quoted: 88 Post(s)
Liked: 75
on my tools page I redistribute up-to-date SVN releases of MPC-HC that are preconfigured to use the codecs installed on your system.
even though I have a 64bit system, I still use the 32bit player because codec compatibility is more refined in the 32bit versions.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #3 of 3 Old 06-24-2011, 06:31 PM - Thread Starter
lifespeed's Avatar
Quoted: 154 Post(s)
I should have known!
Lifespeed
TV Fool report
Reply Home Theater Computers
