My New HTPC - Three 3.5" Hard Drive Locations and an SSD in a Mini-ITX Build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 09-29-2011, 04:59 PM
laszlomdq's Avatar
So I finally had time to play with my Blu-ray player and try PowerDVD 9, it came with it, but it won't play any discs. Is there any special drivers I need for playing Blu-rays out of a Samsung player with PowerDVD 9? Is this a trial version of the software?
laszlomdq is offline
Old 10-06-2011, 05:31 PM
laszlomdq's Avatar
Anyone?
Old 10-06-2011, 08:10 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Anyone?
Almost all the software that comes with the drives are crap trial version that try to entice you to buying the full version.
However, the last Samsung drive I used the software did allow me to play bluray disc in 2 channel only.
assassin is offline
Old 10-18-2011, 11:59 AM
Tizi's Avatar
Assassin,
I moved a HTPC from another case to the APEX and used the same Silverstone cooler on the build. The cooler attachement points did not work well when installing to the motherboard, they were backwards, as you picture shows. The slotted screw driver turn location should be toward the fan, not away from it. Every OEM fan I have installed has been turn in toward the fan, not away from it. Is that a manufacturing defect?
Tizi is offline
Old 10-18-2011, 12:29 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
The Apex MI-008 is $39.99 at NewEgg.com today and you get free shipping w/ code: EMCJKJB24.
StardogChampion is offline
Old 10-18-2011, 01:33 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Originally Posted by Tizi View Post
Assassin,
I don't recall specifically. I do recall having to mess with the cooler a little longer than usual to get it to lock. Maybe that was the reason.
Usually I install outside the case and just look underneath the board to make sure that all the pegs have engaged completely. Then I give it the old gentle rock back and forth test once its installed in the case.
assassin is offline
Old 10-24-2011, 01:13 PM
notorious19's Avatar
hi assasin, paid member from the uk, great website and guides,
was looking to build a htpc but as im in the uk i cant get the same case so i was wondering if the Thermaltake VL52021N2 Element Q 220W Mini ITX Case would be ok. it seems similar to the case you used. also the Asrock H67M-ITX 1155 mini-Itx Motherboard .. unless there is a better mini itx board that i could use, also gonna go with the 2100t for the lower cpu cooler.
notorious19 is offline
Old 10-24-2011, 01:23 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Thanks. Glad you enjoy the guides.
Yes, I think that combination would work just fine.
assassin is offline
Old 10-26-2011, 12:33 PM
NO1B4ME's Avatar
Originally Posted by assassin View Post
Thanks for posting! Glad you liked the build. I put it through a test run tonight and it did fantastic!
assassin,
I have 4 of these in my house. Do you experience any issues with bluray iso playback with the intel HD2000 GPU? I am asking because i am having an issue and cnanot figure out what the problem is. i just now ordered a pico psu and a SSD for this main tv room build. This PC will do all my Lburay ISo and 3D playback form my server.
Main TVRoom Onkyo TX-NR809 - Klipsch RF-82II Fronts - Klipsch RC62II - Klipsch X 2 Surrounds - Velodyne HGS-12 - Sharp 80" Aquos Quatron TV - 3D powered by Intel I7 HTPC. with 2 CEton InfiniTV6ETH on VZ Fios, Media Server Norco RP4224 2TBx24 for Blurays MyMovies
NO1B4ME is offline
Old 11-24-2011, 01:33 PM
booker1's Avatar
Hi. I'm in the process of upgrading my 3 year old htpc and i'm mostly concerned about idle power consumption. Will I see the same results if I use an asrock z68m itx/ht motherboard? Or will the h67 itx be better? Have you tested this particular z68 board with a kill a watt? I've read a review about this z68 board and it idles at 40 watts with an ssd. Any thoughts on this?
booker1 is offline
Old 11-24-2011, 02:34 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Originally Posted by NO1B4ME View Post
assassin,
Sorry I missed this question. I use mkv instead of iso so I have very little experience with it.
assassin is offline
Old 11-24-2011, 02:37 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I haven't used the z68 itx board. Why do you want or need a z68 board? I have found that h67 boards are more stable IMO for htpc use and z68 gives you very little advantages unless you are overclocking it for some reason. Or perhaps if you are building a small gaming build and want to use virtu technology.
assassin is offline
Old 11-25-2011, 03:03 AM
booker1's Avatar
Thanks for the reply. I really don't need the features of the z68. I'm also buying another mce remote and the price of an asrock h67 board + mce remote is equal to the price of the z68 itx/ht with the bundled remote. You think I should just go with the h67 board and just get a separate remote?
booker1 is offline
Old 11-25-2011, 09:18 AM
SUBCOB's Avatar
I have this board with the following:
I3-2100T CPU
60G vertex 2
1TB WD green drive
Hauppauge 2250
150 Pico PSU.
I am idling at around 27i-29 watts, with 1080i TV stream I run up between 38-42 watts.
Tested with a kilowatt meter. It looks higher than what assassin is getting with the H67 chip. I went with the Z68 board because I repurpose all the time, but if I did not I would have went with the 67 for the power savings.
I will try and find time to post some pics of the kilowatt meter.
SUBCOB is offline
Old 11-25-2011, 03:39 PM
booker1's Avatar
I3-2100T CPU
60G vertex 2
1TB WD green drive
Hauppauge 2250
150 Pico PSU.
Nice. Thanks for posting your results. Have you tested it without the 1TB drive and Hauppage 2250?
What's the model number of your 1TB? If it's the WD10EACS, then I would assume that the Z68 board has the the same power consumption as the h67 board. From what I've read, the lowest idle power consumption of an asrock h67 itx with a 2100T is 17 watts. Add in your 1TB (5w idle) and Hauppage 2250 (5-6w idle) and we get the same idle power as yours. Or am I mistaken? What do you think?
booker1 is offline
Old 11-25-2011, 03:44 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Power consumption shouldn't be dramatically different between the two.
assassin is offline
Old 11-25-2011, 05:57 PM
SUBCOB's Avatar
It's an older drive I believe it is an EARS drive
I have not tested without the Hauppauge card, but will look at that during the weekend.
I forgot to mention the standby which is 4w, not sure why so high was expecting no more than 2w, but that may be the difference between the 120 and 150 pico unit.
SUBCOB is offline
Old 11-25-2011, 06:13 PM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
This is the first time seeing this thread, but it came at the right time. The Apex MI-008 case used in this project is currently on sale at Newegg for $34.95 with free shipping (http://www.newegg.com/Product/Produc...82E16811154091). I picked one up thinking I'd use it for a future project. After seeing this thread it may happen sooner than later.
captain_video is offline
Old 11-25-2011, 07:47 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Its a fun project. I love my little Frankenstein.
assassin is offline
Old 11-25-2011, 09:24 PM
SUBCOB's Avatar
It is a great little case, especially if you are working with limited space in your entertainment center.
SUBCOB is offline
Old 11-25-2011, 11:46 PM
booker1's Avatar
Yup. Seems like it.
By the way, thanks for this thread. This is exactly what I wanted to build for a small htpc/media server. I was thinking of modifying the case to something like this for more airflow.
Attachment 228910
booker1 is offline
Old 11-25-2011, 11:57 PM
booker1's Avatar
Thanks again for all the help. The EARS is 3w idle. 4w in standby is a little high.
Would really appreciate it if you could test it some more if you have time. Looking forward to it.
booker1 is offline
Old 11-27-2011, 07:57 PM
NO1B4ME's Avatar
Assassin,
Question for you. What kind of display are you using for hte HTPC? What is the resoultion of the TV itself set to? Are you able to output 1080p 24p on your display with the setup without issues?
I was going crazy chasing a movie judder issue and realized it started happening when I upgraded to new sharp 70" tv with the new SB setup and a new Onkyo receiver to handle the 3D of the TV.
I have to set the intel graphics on the HTPC to 1920x1080 at 60hz. I had it at 24 hz and it was causing the judder issue in Total Media Theater.
NO1B4ME is offline
Old 11-27-2011, 08:04 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Assassin,
1920x1080 @ 60hz. 61" Samsung DLP.
assassin is offline
Old 11-27-2011, 08:10 PM
NO1B4ME's Avatar
Awesome that is what I thought and thanks for the fast response.
NO1B4ME is offline
Old 11-28-2011, 12:07 PM
Quoted: 93 Post(s)
Liked: 160
$35 at Amazon.com today: http://www.amazon.com/gp/product/B001H0BA24/
Old 02-25-2012, 12:09 AM
laszlomdq's Avatar
Sorry for bumping this old post but after building this HTPC last year I had almost no time to play with the blu ray part of it until recently. My issue is that I tried playing a blu ray and is not working smoothly. Is there any setting that I'm missing?
Thanks in advance!
Old 02-25-2012, 09:06 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Asssassin is this your daily use HTPC ?
Mfusick is offline
Old 02-25-2012, 09:24 AM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Absolutely.
assassin is offline
Old 02-25-2012, 08:02 PM
laszlomdq's Avatar
Thanks in advance!
Assassin, do you have any problems playing blurays?
