Intel Integrated HD Graphics Black Level Setting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 98 Old 08-04-2011, 05:36 AM - Thread Starter
bryansj's Avatar
Quoted: 1418 Post(s)
Liked: 645
For some reason I can't get the black level set on my Intel i5 integrated graphics to stick to Full. It keeps reverting back to Limited under the Quantization setting.
I've tried two different versions of the driver. Is this thing broken or is it just my system (Onkyo TX-805 and Panny Plasma)?
I've got an Nvidia 430 that I could dust off, but I'd rather just use what is built in if I can get it to work. I'm just seeing crushed blacks and realized that it keeps reverting back to Limited. My Nvidia card never did that.
bryansj is offline
post #2 of 98 Old 08-05-2011, 03:37 AM - Thread Starter
bryansj's Avatar
Liked: 645
So my system is the only one that will not save the black level setting of Full?
bryansj is offline
post #3 of 98 Old 08-06-2011, 01:10 PM
rolk's Avatar
Ah, I don't think so! I've got the exact same issue that has driven me to buy an NVIDIA card to get around it.
I was using the Intel HD Graphics HDMI output to connect to a Samsung C8700 LCD tv. Worked fine, except for the problematic playback of '24Hz' blueray stuff (which is hardware related, can't be dealt with) and the issue you describe. The quantization level setting in the dialog does not stick. Each time I change resolution setting, display frequency, reboot or do a suspend-to-ram/resume cycle, the setting reverts back to 'limited'.
When it is set at 'limited', my tv set shows significant 'banding' in gradients, especially in darker areas. It isn't pretty! When I switch it to 'full' the banding is greatly reduced.
I've tried this also under a user account that has windows administrator rights, as I thought this might have something to do with access rights, but the dialog setting would not stick then either.
I would very much like this issue to be fixed, as I would rather again just use the built in graphics: my HTPC is now using almost twice the amount of electric power, with the associated added heat, fan noise...
I've reported this on an Intel forum, but so far no official word from Intel.
rolk is offline
post #4 of 98 Old 08-06-2011, 01:57 PM
AFryia's Avatar
I think not.
I suspect I have the same issue with my i3 2100.
Stupid question but were do I find the "Quantization setting"?
AJF
No such thing as a stupid question! Well have you got a minute ?
AFryia is offline
post #5 of 98 Old 08-06-2011, 03:10 PM - Thread Starter
bryansj's Avatar
Liked: 645
Originally Posted by AFryia View Post
I think not.
Graphics Properties / Advanced Mode then Display / Monitor/TV Settings.
There is a Quantization Range setting for Limited and Full.
bryansj is offline
post #6 of 98 Old 08-06-2011, 09:40 PM
BartMan01's Avatar
You are not alone. I finally gave up and put my ATI card in the machine to get correct color space.
BartMan01 is offline
post #7 of 98 Old 08-07-2011, 05:55 AM - Thread Starter
bryansj's Avatar
Liked: 645
I guess I could put my Nvidia 430 in until they sort out their driver issue.
My new HTPC was build around having minimal hardware and being quiet with all the storage and other tasks offloaded to my new server. The server is the guts out of my old HTPC and the Nvidia card was left behind since I didn't think it was needed, until now.
bryansj is offline
post #8 of 98 Old 08-14-2011, 02:48 PM
AFryia's Avatar
The "Quantization" setting does not show up on my i3 HD2000 Intel control panel, nor does the "IT" control.
All I see is "Monitor/TV settings not supported". The control panels does identify my SONY IFB DVI input card on my projector on other screens.
To see the BTB data I had to override application settings and bump Brightness from default 0 to ~12. My fear is this work around is compromising the video quality. Never had this issue with my ATI DVI card.
AJF
AFryia is offline
post #9 of 98 Old 08-14-2011, 05:00 PM
claw's Avatar
Quoted: 1071 Post(s)
Liked: 991
I have the same issue with an I3-2100. It won't stick at Full.
CJ
claw is offline
post #10 of 98 Old 08-14-2011, 05:22 PM
snef's Avatar
same here
i5-2500k, it won't stick at full
snef is offline
post #11 of 98 Old 08-14-2011, 07:37 PM - Thread Starter
bryansj's Avatar
Liked: 645
I've got my Nvidia 430 ready for when I get my Ceton this week. If I can't find a fix by the time I crack open my case then I'll pop in the 430 at the same time.
bryansj is offline
post #12 of 98 Old 08-15-2011, 11:40 AM
tlmaclennan's Avatar
I have an Intel i3-530 and have been using an older version of the graphics driver because black levels seemed to vary with the newer versions. I recently upgraded and everything was fine until I reboot my system...it seemed a bit dark. All my settings were still the same and that's when I saw this thread.
The quantization setting must be new since I never saw it in my older driver version. In the past versions I would have problems with my xvYCC setting becoming unselected whenever I switched inputs on my receiver. Now it sticks with the latest driver but this quantization setting won't stick. I guess I will complain to tech support and see how far that will go.
tlmaclennan is offline
post #13 of 98 Old 08-30-2011, 07:14 PM
Alan Winslow's Avatar
I have been experiencing the same issue with my i3 2100 build . It is frustrating.
I am using a small Rosewell case with a 150 watt power supply. Are there any low wattage video cards that would work well?
I may have to reinstall in a bigger case and larger power supply. Does anyone have suggestions for a budget high quality video card for 1080p playback?
Alan Winslow is offline
post #14 of 98 Old 08-30-2011, 07:17 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
The fanless 5450 cards use about 20 watts at peak and 3 watts at idle.
assassin is offline
post #15 of 98 Old 08-30-2011, 07:42 PM
Assassin, Thank you for the quick response. I am using the Rosewill RC-CIX-01, Have you used a 5450 in any of your builds? How does the 1080P video quality compare to the Intel? Are there other higher quality cards for comparison out there that would fit the case regarding size and power draw.
I really appreciate your help.
post #16 of 98 Old 08-30-2011, 07:54 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
Alan - Personally I like the Intel better mainly because the ATI driver were absolutely abysmal with my particular setup. NVidia was a little better but nowhere near as stable as the Intel drivers. Other have no issues at all with ATI or NVidia. So ymmv.
Picture quality honestly was about the same on all 3 subjectively.
assassin is offline
post #17 of 98 Old 08-30-2011, 08:00 PM
Assasin, Maybe I'll sit tight and see if they come out with a driver update. I'll just change the setting in the Intel HD Panel setup each time turning the computer on. It will hold for a movie but reset itself each time I turn the computer back on. It has been a great HTPC.
Thank you for the help.
post #18 of 98 Old 09-20-2011, 07:12 AM
NufNuf's Avatar
Same issue with my Intel I5 processor graphics. Nothing happens after setting "Quantization" to "Full". After reboot it reverts to "Limited". Black level depth considerably reduced.
New driver version 15.22.50.64.2509 released 7 September still not fixes this bug.
NufNuf is offline
post #19 of 98 Old 09-20-2011, 07:36 AM - Thread Starter
bryansj's Avatar
Liked: 645
Every time I see this thread bumped I hope that the last post has a fix...
bryansj is offline
post #20 of 98 Old 09-20-2011, 12:57 PM
shortcut3d's Avatar
Quoted: 21 Post(s)
Liked: 29
Driver version 15.22.50.64.2509 did not fix it for me. It will sometimes stay set for an entire power state. However, any resolution change (Desktop vs 7MC) will cause it to revert to limited (yes, I had set the two differently in an attempt to fix another issue).
shortcut3d is offline
post #21 of 98 Old 09-21-2011, 07:30 AM
NufNuf's Avatar
When you set it to "Full", do you see visible changes? It seems that two issues are reported in this thread:
  1. Full quantization doesn't work (remains limited after setting it to Full). After reboot quantization setting resets to Limited. (My case)
  2. Full quantization works, but after reboot quantization setting resets to Limited.
So, is your case #2? I am just curious to know whether someone managed to see full rgb range signal from intel hd graphics.
NufNuf is offline
post #22 of 98 Old 09-28-2011, 08:32 PM
sacrebleu's Avatar
i think i found a workaround. it worked for me, at least.
system specs: celeron g540, msi h67 mb, asus ml239h monitor (native resolution 1920x1080), latest intel hd graphics drivers (build 2509).
my motherboard has vga and dvi-i outputs, and my monitor has vga and hdmi inputs. i'm using the dvi to hdmi cable the monitor came with.
the problem: the graphics driver detects the monitor as a 'digital television', and sets the quantization range to 'limited', resulting in blacks that are dark grey and whites that are light grey. changing the option in the pulldown doesn't have any effect.
playing around with the resolutions a bit, i noticed that the limited range only occurred at certain resolutions. if you set the windows background color to black and scaling to 'center', you can immediately see which resolutions have this problem when you switch to them (the border would be the monitor/tv's true black and the windows desktop would be a lighter shade).
the solution that worked for me was to create custom resolutions to override the ones which have the problem.
i only use my monitor at 1920x1080, but this happened to be one of the problematic resolutions, so i created custom resolutions of 1920x1080, all color depths, and at both 59hz and 60hz (both of these appeared as acceptable refresh rates for my monitor, although windows defaulted to 59hz. i really didn't need to create the 60hz custom resolution). this resulted in a total of 6 custom resolutions. it warned that this custom resolution already exists (it didn't, but what it probably meant was that the new custom resolution would override a standard resolution), but i said yes to overwrite.
after rebooting, blacks were black and whites were white. confirmed this with calibration - before the custom resolution, the monitor calibrated to 120 cd/m2 luminance and a .5 black point. afterwards, it calibrated to 140 cd/m2 luminance and a .2 black point with the monitor settings untouched.
the quantization range now shows 'default' instead of 'limited'. however, changing it still has no effect, so if you need to change the range on a regular basis, this fix won't really do much.
hope this helps.
sacrebleu is offline
post #23 of 98 Old 09-29-2011, 04:58 AM - Thread Starter
bryansj's Avatar
Liked: 645
So you basically created a custom resolution that was the same as the standard one that you were already using?
I'll try that when I get home this evening.
bryansj is offline
post #24 of 98 Old 09-29-2011, 08:02 AM
archibael's Avatar
Interesting... implies that the driver is assuming "all digital televisions MUST be limited quantization", but that digital monitors (again, an assumption on the part of the drivers that a custom resolution will be done on non-TV equipment) are permitted to have full quant.
I do not speak officially in any sense for
Intel Corp., Technology Manufacturing Group
but I do work there.
archibael is offline
post #25 of 98 Old 09-30-2011, 01:38 PM
NufNuf's Avatar
...the solution that worked for me was to create custom resolutions to override the ones which have the problem.
hope this helps.
It works!!! Thank you very much!
NufNuf is offline
post #26 of 98 Old 09-30-2011, 02:32 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
Tried it at 1920x1080, 59Hz, all color depths and got a "not supported" reading on my HDTV screen.
I chose this first because that is what was set at default.
Restarted in safe mode and changed to 1920x1080, 60Hz, all color depths.
Working now. Works great.
assassin is offline
post #27 of 98 Old 09-30-2011, 07:00 PM - Thread Starter
bryansj's Avatar
Liked: 645
I think mine works too, but I'm still testing with reboots and such. I also had to do the safe mode thing to change my refresh rate. I think I had to go from 60 to 59.
bryansj is offline
post #28 of 98 Old 09-30-2011, 07:01 PM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
I'm still testing too.
assassin is offline
post #29 of 98 Old 10-06-2011, 02:15 PM
flipside927's Avatar
That custom setting worked. Thanks!!
It does revert back though when i turn of my tv or restart the computer :/
flipside927 is offline
post #30 of 98 Old 01-16-2012, 06:50 PM
dave3's Avatar
I had this problem, too.
With version 8.15.10.2509 of the Intel graphics drivers, I'm able to set a custom resolution for 1920x1080, 32 bit, 60Hz, and change the Quantization Range to "Full."
That seems to fix the problem, and it keeps the settings after turning the monitor off or rebooting, though after rebooting the Quantization Range is "Default" instead of "Full." At least it's not "Limited" and it's still working properly.
After upgrading the Intel graphics drivers to 8.15.10.2559, however, it stopped working properly. The resolution would constantly revert back to 59Hz, and the Quantization Range would revert back to Limited when turning the monitor off & on or rebooting. Even before turning the monitor off, the Full setting had no effect.
So I reverted the Intel graphics drivers back to 8.15.10.2509, and all is fine again.
For what it's worth, I'm using a i7 2600K cpu and an Intel DH67CFB3 mini-itx motherboard.
dave3 is offline
Reply Home Theater Computers
Onkyo Tx Sr805 7 1 Channel Home Theater Receiver Silver
