JRiver Media Center Owner's Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 383Likes
post #91 of 2387 Old 08-11-2011, 10:55 AM
janryAVS's Avatar
Originally Posted by jriver View Post
This may work, depending on what you mean by directly access.
http://yabb.jriver.com/interact/index.php?topic=64420.0
By that, I mean access the recording on the TiVo drive (without transferring it to the PC).
I understand TiVo is now experimenting with streaming from one Premiere to another, so this may be possible soon.
janryAVS is offline
post #92 of 2387 Old 08-11-2011, 11:40 AM
steelman1991's Avatar
Quoted: 296 Post(s)
Liked: 149
Originally Posted by dbone1026 View Post
+1
How ya doing steelman?
Yeah fine mate - nice to see you testing JRiver, I'm sure you'll enjoy it. Looking forward to your assessment it really is a great app - but I won't spoil it too much for you.
steelman1991 is offline
post #93 of 2387 Old 08-11-2011, 11:52 AM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
To get more of the current market (i.e. the Media Browser, My Movies, XBMC, etc... crowd) you would definitely want to have some sort of default views with Eye Candy that require very little tweaking (at that point it can then be up to the user to customize if they want)
I can't disagree with this.
fitbrit is offline
post #94 of 2387 Old 08-11-2011, 12:01 PM
Zon2020's Avatar
Originally Posted by BartMan01 View Post
For example, in Theater View I recently added a 'Unwatched TV Shows' section that sorts the episodes from oldest to newest by show. Once I watch an episode it automatically drops out of that section.
How did you do that? I see that it has all these categories built in, but I haven't figured out how to assign a movie to a category. How do I set up and flag things as, say, sports, concerts, classic movies, comedies, action, etc.
I was hoping it would extract that data from the downloaded metadata, but it doesn't seem to.
Thanks for the help.
I'm going to go ahead and buy it this weekend, because with the help of these threads I'm starting to get it into a workable setup (finally got the manual metadata grab to work), but I still need a lot of help in actually getting things organized. I don't have enough media at the moment that doing it manually is a problem. I just need to learn how. Thanks.
Zon2020 is offline
post #95 of 2387 Old 08-11-2011, 12:27 PM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
You can tag all this, creating your own custom fields if you like, in StandardView (the iTunes-like interface). Just right click on the column headings to display existing categories. You can create new fields in the Options>Library&Folders>Manage Library Fields.
A newly-written Wiki appears here, but it's still being modified according to user feedback.
fitbrit is offline
post #96 of 2387 Old 08-11-2011, 12:31 PM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
What format is the metadata in? Is it in an additional file, or tagged in the files themselves? If the latter, you can just right click on the files in Standard View and go to Library Tools>Update Library (from tags). You can choose as many files as you like and update in one go.
If the metadata is in a supplemental file, there may be a way to convert it into a J. River Sidecar format, but I am not able to help here, I'm afraid.
fitbrit is offline
post #97 of 2387 Old 08-11-2011, 01:05 PM
Zon2020's Avatar
Don't have any idea. It's in whatever form it is saved when you use the built in "get data from Wikipedia" function.
Zon2020 is offline
post #98 of 2387 Old 08-11-2011, 01:09 PM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
Oh! I misunderstood... I thought you had metadata from another, previously-used, program. If you're getting it from Wikipedia from within MC16, it'll be a much easier endeavour for you/us.
fitbrit is offline
post #99 of 2387 Old 08-11-2011, 01:16 PM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
Some screenshots again, salvaged from the closed thread. The last two are from user glynor. I haven't done as much customisation of my views as I'd like, and my second shot doesn't really show what is available for TV shows, except for automatically downloaded and displayed TV backdrops:
fitbrit is offline
post #100 of 2387 Old 08-11-2011, 03:53 PM
whiteboy714's Avatar
Quoted: 13 Post(s)
MC16 works off of the tag data by default, not the folder structure. Step one is to get your tags correct (you can populate tags based on folder structure and file name).
Why would I want to manually "tag" everything. What a pain, my shows are listed like this
Seinfeld
Season 1
S01E01.avi
Is that not good enough? They all also have metadata already included. No worries though its not for me. Doesn't seem like a real front end to me but more like a fancy windows media player.
EDIT^^^ The above post has some decent looking screens. Better then what I saw but I honestly gave it like 5 minutes.
whiteboy714 is offline
post #101 of 2387 Old 08-11-2011, 03:57 PM
video321's Avatar
Quoted: 21 Post(s)
Seinfeld
Season 1
S01E01.avi
Unless things have changed with the newer versions you can also use standard folder structure for browsing. That's what I do for my shows.
video321 is offline
post #102 of 2387 Old 08-11-2011, 03:59 PM
KramerTC's Avatar
Quoted: 79 Post(s)
Liked: 59
Originally Posted by KramerTC View Post
I have searched the jriver's forum but can't find the answer.
Can anyone tell me if subtitles can be moved up or down for Bluray playback? (disk, iso or folders)
Anyone?
KramerTC is offline
post #103 of 2387 Old 08-11-2011, 04:15 PM
BartMan01's Avatar
Seinfeld
Season 1
S01E01.avi
You don't have to manually tag everything. If your folder structure and filenames contain the info you can use that to populate the tags automatically using the 'fill properties from filename' feature.
BartMan01 is offline
post #104 of 2387 Old 08-11-2011, 04:36 PM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
I'm not sure about this, but I can check. Why would you want to do this? Is it so that subtitles can be onscreen on a scope screen?
If so, this is just the sort of feature that I think they'd be quite accommodating with.
fitbrit is offline
post #105 of 2387 Old 08-11-2011, 04:47 PM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
It looks like the subtitles are fixed. I could request this feature and see what happens.
fitbrit is offline
post #106 of 2387 Old 08-11-2011, 05:38 PM
KramerTC's Avatar
Quoted: 79 Post(s)
Liked: 59
Thanks a bunch. Yes, I need this functionality for a wide scope screen.
KramerTC is offline
post #107 of 2387 Old 08-11-2011, 06:55 PM
nwboater's Avatar
Originally Posted by lewispaul View Post
Doesn't J. River have its own interactive forum? Why are we posting here rather than there. Is Fitbrit the 'official' poster to J. River or can anyone post there? Confused.
JRiver has its own Forum http://yabb.jriver.com/interact/index.php?board=22.0 All you have to do is register there. I don't want to send anyone away from here but you will most likely get a lot better coverage of your questions by very experienced users if you post there.
I don't think fitbrit has any 'official' capacity - just a good guy who really likes JRMC and is trying to help folks out here.
Rod
nwboater is offline
post #108 of 2387 Old 08-11-2011, 07:43 PM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
I don't work for J. River. I've enjoyed their software a lot over the past 4 years. I'm trying to help others give it a fair go to see if they see it as a valuable alternative to their current setups. In the process there have been some suggestions that might improve the software overall for others, including myself.
fitbrit is offline
post #109 of 2387 Old 08-11-2011, 07:45 PM
KramerTC's Avatar
Quoted: 79 Post(s)
Liked: 59
Very true. I could have posted on jriver's support forum. I chose to do it here because AVS is where I hang out and feel more comfortable asking here. I'm considering getting back into the HTCP thing after burning out on it back in the DVD days.
KramerTC is offline
post #110 of 2387 Old 08-11-2011, 07:48 PM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
Rod
Thanks Rod. I don't know how much of a 'good' guy I am, but the rest sums it up.
fitbrit is offline
post #111 of 2387 Old 08-11-2011, 08:55 PM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
I should add that I didn't test with BluRay subtitles, but I believe all subtitles are handled similarly. All the ones I tested (just a handful of m2ts files) showed their subtitles on the movie itself, never below on the letterboxed "black-bars". In any case, I've started this thread over at Interact:
Feature requests from AVS users who tried, are trying or are thinking of trying.
To address your other question:
MC16 recognises m2ts files, BDMV folders too. Also the BD playlists are recognised and can be individually tagged (so you can choose your favourite episode of Lost from a disk with many, for example).
For ISO, you may need additional software running in the background like VirtualCloneDrive to mount the disk, and you have to specify ISO as a video type ('cos it could be anything) in order to see the associated metadata.
fitbrit is offline
post #112 of 2387 Old 08-12-2011, 02:56 AM
CountryBumkin's Avatar
Quoted: 219 Post(s)
Liked: 55
Seinfeld
Season 1
S01E01.avi
You don't have to tag anything. I don't. My TV Series are setup the same way yours are except my file name is "Seinfeld s01.e01. Name of Episode. mkv". JRiver handles this fine.
One thing that I do, that is probably different from others, is that I have/use the program MyMovies4. So I use MyMovies to download the IMBD movie data, then JRiver uses that (meta) data for display. I just rip a movie to a named folder and then start MyMovies, which detects the new movie and downloads the movie data. I know you don't need MyMovies, but since I already have it its nice that it works with JRiver program.
CountryBumkin is offline
post #113 of 2387 Old 08-12-2011, 03:00 AM
Quoted: 296 Post(s)
Liked: 149
Surely you would have to undertake some form of tagging, otherwise JRiver, wouldn't know the media sub category of video - ie: Movies from TV Shows?
post #114 of 2387 Old 08-12-2011, 04:18 AM
video321's Avatar
Quoted: 21 Post(s)
You can customize your views for things such as "path does not contain: movies" and only your shows will be listed. Of course all of your movies would have to be a subdirectory under "movies."
video321 is offline
post #115 of 2387 Old 08-12-2011, 04:55 AM
Quoted: 219 Post(s)
Liked: 55
In the JRiver setup section, you have to tell MC where your movies (video), Audio, Pictures, etc. are located. So when setting everything up for each media type, you browse to the directory (such as "\\\\HTPC\\Movies" for example) and JR uses that location and assigns all the folders in that directory as movies (video). Same for the other media types. My TV-Series are all stored in folders (by series name) in its own Directory (called "My TV"). So the TV-series are not added into the Movie listings.
Then you tell MC where the meta data, cover art, etc. is located. You can select "same folder as movie", or point to a different location.
I use MyMovies4 for collecting the movie cover art and meta data. With MyMovies the movie cover art and meta data is created/downloaded and stored in the same folder with the movie. If you use Video_TS format, your movie would be one folder down (in the Video folder). MC knows how to handle this. I don't know how the movie data is gathered by JRiver if you don't have a MyMovies type program.
Now with my Blu-ray movies I create a folder called "movie name [Blu-ray]", then JR adds the movie to the HD category. The "[Blu-ray]" is not used in the title/name display but distingishes the movie as a BD rather than a DVD.
Lastlym I'm still learning MC, so there may be other/better ways to get the job done. This is just how I do it.
post #116 of 2387 Old 08-12-2011, 09:20 AM
fyrfyter71's Avatar
I'm still experimenting with a front end for my HTPC. Started with MediaBrowser, currently I'm using XBMC, and experimenting with jriver as I like what everyone is saying about the playback "just works". But I have to agree with the many users that say it is not very intuitive. It took me hours just to figure out how to move my isos from data to videos even using the jriver forum. This thing has so many customizable options that it makes it completely confusing. I am not giving up yet, but you would think that if they can fully automate Madvr and lav filters being integrated, that it should be easy to import videos of all types like with other media center software.
I don't mean this to be taken offensively, just voicing my opinion.
By the way, what is the easiest way to import my cover art for bluray files? Jriver imports mkvs and isos cover art just fine, but do I have to individually import for each movie from the individual file?
Also would be nice to get some sort of cover flow type display for theater mode. If it's there I'm sorry I just can't figure out how to get to it.
fyrfyter71 is offline
post #117 of 2387 Old 08-12-2011, 09:52 AM
jriver's Avatar
Quoted: 92 Post(s)
Liked: 75
Originally Posted by fyrfyter71 View Post
... it should be easy to import videos of all types like with other media center software...
Tools/Options/Import. You can set up autoimport to watch folders. In the same place, use Edit to select which filetypes to import. You can also exclude folders there.
You should be able to right click on a Blu-ray to get art from Wikipedia. There are other cover art solutions for movies on our Third Party board. Blu-ray is new, so I'm not sure if they will work.
Jim Hillegass / JRiver Media Center
jriver.com or Owners Thread at AVSForum
jriver is offline
post #118 of 2387 Old 08-12-2011, 09:59 AM
Zon2020's Avatar
Am I understanding this correctly that if I create, say, 4 folders, entitled "Movies", "TV", "Sports," and "Concerts", the program will sort the files that I have in those four folders accordingly, without my having to individually tag the files?
Is there something I need to do to tell it to do that?
Zon2020 is offline
post #119 of 2387 Old 08-12-2011, 10:22 AM
fitbrit's Avatar
Quoted: 59 Post(s)
Liked: 53
There's a 3D coverview, which is kind of cool, but still needs some polish IMO. There's also a wall of covers type view as seen in my screenshots above.
I too found the program daunting at first, and to be honest I keep still finding cool features and applications of these after 4 years. I'm very glad I stuck with it. One of my posts above links to a thread in the J.River forum that I made to discuss what you guys want. Feel free to post there.
Many J. River users have been using the software for years and have evolved with the program. So for us, it's not always clear where the improvements are required to get new users to give it a fair chance.
Since MC is so actively developed, with constant improvements often happening everyday, it's hard to write a static manual. I'm going to encourage users and the staff at J. River to post video how-tos - an idea that other users have already proposed and is gaining some support.
fitbrit is offline
post #120 of 2387 Old 08-12-2011, 01:18 PM
Quoted: 219 Post(s)
Liked: 55
I like the 3D cover art too. When you scroll left or right (and hold scroll button down) the rows of cover art (the movie covers) rotate to an angle (and go off into the disatnce) and then the art work scrolls quickly. it's a good way to get through a lot of covers. Once you stop scolling (stop holding right or left scoll button) the image rotates to a forward view and enlarges. I tried to get a screen shot but the action was too fast. Here is the best capture I good get.
Reply Home Theater Computers
