JRiver Media Center Owner's Thread - Page 49 - AVS Forum
 109Likes
post #1441 of 1454 Old 10-18-2014, 05:54 AM
CountryBumkin's Avatar
Quoted: 41 Post(s)
Originally Posted by Edge540 View Post
Hi,
So i just finished building an Asrock Q1900-ITX with the intention of running it as a client with Jriver installed. I've run into a problem of Theater View not working. It gives the error of "Error starting Direct3D engine - adapter 0 not capable of windowed mode". i see a few others have had this error and they are told to update the graphics driver.
I am running Jriver 19.0.163 and all the latest Asrock/Intel drivers/utilities. I have Win7 64bit.
any ideas? or will this not work?
I'm not sure if this is related to your problem or not - but when I was installing new graphic drives I ran into a similar (if not the same) error message. I had JRiver set to start automatically on boot up, and when I installed new graphic/video card drivers, the system did the auto restart to finish driver installation, but it started JRiver program before the driver install finished. That brought up the error. I had to boot into safe mode to be able to stop JRiver program from loading in order to let graphic drivers finish installing. Once the driver update finished I did not have any other problems.
IgorZep likes this.
CountryBumkin is offline
post #1442 of 1454 Old 10-18-2014, 08:58 AM
Djoel's Avatar
Quoted: 65 Post(s)
Liked: 187
I inadvertently unloaded my library( Music, picture, and movies) trying to add some movies from a few of my hard drives, are they're completely lost?
Also I think I successfully changed the Drive where my music where originally being ripped to ( Local C drive),Went to options File Locator, I see it says the M Music drive ( I named it that) I've assigned it to. Would that be correct? I guess best thing is to test this, but I have to format the Music drive correctly before for transferring any music to it. Something about it being Dynamic or something similar.
Djoel
Djoel is offline
post #1443 of 1454 Old 10-19-2014, 12:14 AM
jriver's Avatar
Quoted: 47 Post(s)
Liked: 32
Did you try restoring a backup? MC makes them automatically.
Jim Hillegass / JRiver Media Center
jriver.com or Owners Thread at AVSForum
jriver is offline
post #1444 of 1454 Old 10-19-2014, 06:19 AM
Djoel's Avatar
Quoted: 65 Post(s)
Liked: 187
No, I was trying to add movies from my hhd, I never been able to. I doubt I have space to back them up, I wouldn't try that.
Djoel
Djoel is offline
post #1445 of 1454 Old 10-19-2014, 07:42 AM
sheriff1972's Avatar
Liked: 3
Cascading dither
If you cascade multiple dither levels don't you increase the RMS noise bt 6dB each time?
I am not sure that adding a dither plugin would fix a modulating noise floor either hence the request to enable or disable the dither in JRiver and add a single dither level via a user selectable dither plugin.
sheriff1972 is offline
post #1446 of 1454 Old 10-19-2014, 08:04 AM
Edge540's Avatar
ive tried updating the Intel HD Graphics drivers but it says my hardware is not sufficient. Is it even possible this board does not have the Intel HD graphics installed somehow? It only lists the standard VGA graphics adapter. im sorry for not keeping with the jriver theme here but id like to use this program on this client, if it works.
thanks
eric
Edge540 is offline
post #1447 of 1454 Old 10-19-2014, 08:45 AM
Quoted: 41 Post(s)
thanks
eric
That sounds like your problem. Can you go to Control Panel >Device Manager> Display Adapters and see what it shows. If not what you should have, try updating drivers from there - (although downloading the correct drivers from the Asus website is usually the best method).
post #1448 of 1454 Old 10-19-2014, 09:05 AM
Edge540's Avatar
attached is a screen shot of the device mngr. obviously this must be the problem. im guessing the only recourse is returning this board and getting a new one? I do not find a graphics driver on the asrock website.
Edge540 is offline
post #1449 of 1454 Old 10-19-2014, 09:13 AM
Quoted: 41 Post(s)
Right click on it, and try "update driver software". Or go to Asus site and get the (VGA) driver for your board http://www.asrock.com/mb/Intel/Q1900...load&os=Win764
post #1450 of 1454 Old 10-19-2014, 09:50 AM
Edge540's Avatar
I swear i did the VGA driver update but evidently i did not. I did it, and everything works great now. Thanks huge! looks like this will work after all.
Thanks CountryBumkin!
Edge540 is offline
post #1451 of 1454 Old 10-19-2014, 10:20 AM
jriver's Avatar
Quoted: 47 Post(s)
Liked: 32
Thanks, CountryBumkin.
Edge540, thanks for your patience and perseverance.
jriver is offline
post #1452 of 1454 Old 10-19-2014, 11:14 AM
IgorZep's Avatar
Quoted: 126 Post(s)
Liked: 108
No
IgorZep is offline
post #1453 of 1454 Old 10-23-2014, 12:34 AM
jriver's Avatar
Quoted: 47 Post(s)
Liked: 32
JRiver Media Center can now act as a sound device driver. This lets you route any Windows sounds through MC so you can take advantage of MC's DSP. Requires version 20.0.27 or higher, now at the top of the MC20 board.
http://yabb.jriver.com/interact/index.php?topic=92593.msg637430#msg637430
jriver is offline
post #1454 of 1454 Old 10-23-2014, 08:52 AM
Djoel's Avatar
Quoted: 65 Post(s)
Liked: 187
Is there anyone in NYC that can help brother who's down and out all things JRMC
Just PM me and will discuss compensation, hopefully pizza and beer would suffice
Dan
Djoel is offline
Reply Home Theater Computers
User Tag List
