JRiver Media Center Owner's Thread - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 363Likes
post #1621 of 2351 Old 01-26-2015, 03:06 PM
JimSatala777's Avatar
Quoted: 149 Post(s)
Liked: 35
Originally Posted by LairdWilliams View Post
Originally Posted by JimSatala777 View Post
I am a huge fan of SACD and BluRay audio /DVD audio especially when it comes with a .1 signal, is it possible to get this and other multi channel dsd or the like off my computer using this software?
What exactly do you mean by "off my computer"?
As in, rip discs to files ON the PC and then play them back or stream them over the network to a network music player of some kind? Mostly yes - although you might need other tools to help out. (Certainly with SACDs).
Or "erase the files" perhaps? (That would certainly get them "off your computer" ;-)
I am trying to find a easy way to get as much high quality audio to stream to my processor... multi channel is preferred....I am just using ITunes right now through my apple tv and the quality is not great and only 2.0 stereo no .1 LFE signal
I have been hearing about several sites to download 24/96 and higher detailed
I was going to try this software but have been reading that it's very complex to set up properly
JimSatala777 is offline
post #1622 of 2351 Old 01-26-2015, 04:51 PM
LairdWilliams's Avatar
Quoted: 204 Post(s)
Liked: 225
JRMC will work great with pretty much any audio files you can purchase and download. It functions very well as a DLNA server on the network if you have a DLNA player or renderer that you want to use for playing music. Its tagging features and customizability (especially the browsing structure) makes handling larger collections lots easier. Yes, all of this works with surround, as long as the player/renderer supports the files in question. My own setup is as follows:
1) PC Running JRMC and a 12TB RAID array for storing media, including about 500GB of 5.1 flac and DSF audio files and another 500GB of apples lossless files for audio.
2) An Oppo BDP-103 that functions as a renderer
3) A PS3 with custom firmware that lets me rip my SACDs to ISOs, along with some tools to extract tracks as DSF files from the ISOs. (I also have DSF files that were purchased on-line) Almost all of these DSFs/SACDs are multichannel.
4) A few other tools that let me rip 5.1 flacs from DVD-A, DVD-V, BD, and DTS-CD media
5) Gizmo (free - the android companion for JRMC)
6) JRemote (paid - the EXCELLENT iOS companion for JRMC)
My normal usage is to turn on the Oppo and the surround receiver, fire up jRemote on the iPad, and then use it to control JRMC, which then "pushes" media I select to play to the Oppo for playback on the surround system. It all works great.
This is NOT the only way you can use JRMC for 5.1 audio playback. Gizmo can be a good substitute for jRemote if you want to control things from your android phone or tablet. If your network unit has a built-in DLNA browser as well as a renderer, then you can just control things from there too.
Finally - you don't have to use the LAN at all. You can also connect the PC directly to the surround receiver via HDMI and then play the media directly in JRMC, with the audio going to your surround receiver for processing. I do this in my "remote" location (I commute about 250 miles for work every week - and have an apt. in the work location). I use JRMC installed on a Gigabyte BRIX unit with a 1TB mSATA drive installed with a wireless keyboard connected to my surround unit at the apt. I can also use Gizmo/jRemote to control this. This also works great, as long as you configure a few things properly.
Display: Panasonic P60UT50 (Plasma)
Speakers: (4) Monitor Audio Silver 9i (Front and Surround), (1) Monitor Audio Silver 12i (Center), (4) Monitor Audio Silver 4i (Rear and Wide), (2) Aperion Audio Bravus II 8d (Subwoofers)
Receiver: Pioneer Elite SC-87 AVR (9.2)
Sources: Oppo BDP-103, Roku 3, Cable...
LairdWilliams is offline
post #1623 of 2351 Old 01-26-2015, 05:08 PM
Quoted: 149 Post(s)
Liked: 35
Ok thanks. ..I have a 105D that I was using as the render....I was contemplating going for either a Krell connect or the psaudio directstream with the network bridge but I'm pretty sure neither of those are capable of multi channel
post #1624 of 2351 Old 01-26-2015, 05:11 PM
Quoted: 204 Post(s)
Liked: 225
The Oppos have fantastic renderer implementations - and they have really stabilized in the last year or so.
Oppo+JRMC+jRemote/Gizmo+good surround system is really a very good, robust, easy-to-use (once you configure things) setup for 5.1 music. If you go this route, feel free to PM me for setup help. I've walked this path a few times now.
post #1625 of 2351 Old 01-26-2015, 05:34 PM
Quoted: 149 Post(s)
Liked: 35
Thanks I will, do you think a windows laptop or mac mini is best for storage and server duties with this software?
post #1626 of 2351 Old 01-26-2015, 05:52 PM
Quoted: 204 Post(s)
Liked: 225
If you do a Mac Mini then you will want to put windows on bootcamp or run a VM. The mac version of JRMC is not nearly as full-featured or stable as the windows version.
FYI - I run on a Mac Mini with OS X server for my file/mail/dns/dhcp server. The RAID array is a 12TB Thunderbolt array. I then run Windows 8 under VMWare Fusion on that server so I can run JRMC from there. Works great and very-low power - but no the least expensive way to go for most folks. In my case, the OS X server was already a given, so it was the best way for me. But for most folks I would probably recommend an Intel NUC or Gigabyte BRIX (or similar) running windows - with an mSata boot drive and a big USB3 unit for media storage - would require the least power and space and would be more economical than the mac mini. That would let you leave it on all the time, which is VERY convenient if the box is not in the same room with your AV setup. A decent-but-inexpensive windows laptop would also work - as long as it has USB3 so you can connect a decent (at least 2-disk mirrored) RAID setup to it.
post #1627 of 2351 Old 01-26-2015, 05:55 PM
G_S
G_S's Avatar
I have to look into it. Thank you.
G_S is offline
post #1628 of 2351 Old 01-26-2015, 05:55 PM
Quoted: 149 Post(s)
Liked: 35
K thanks
post #1629 of 2351 Old 01-28-2015, 12:17 AM
Sound&Life's Avatar
Quoted: 23 Post(s)
Hi,
When outputing JRMC in 4096 x 2160 32 bits (video settings), does that mean chroma/luma scaling (eg jinc 3 taps) is done for this resolution ?
I want to know if SD --> 4K or HD --> 4K upscaling is possible if we have the hardware to go with.
thx
Sound&Life is offline
post #1630 of 2351 Old 01-28-2015, 06:49 AM
desertdome's Avatar
Quoted: 1223 Post(s)
Liked: 1370
Originally Posted by Sound&Life View Post
Hi,
thx
Yes, you will get chroma/luma scaling to whatever resolution you are outputting. If you get the newly released Nvidia GTX 960 you will also get 10-bit output.
desertdome is offline
post #1631 of 2351 Old 01-28-2015, 07:24 AM
Sound&Life's Avatar
Quoted: 23 Post(s)
Thanks for the feedback.
Is the Nvidia GTX 960 enough for the following settings (SD --> UHD and HD --> UHD) ?
Output resolution: 4096x2160
Image downscaling: Catmull-Rom + Anti-Ringing Filter + Scale in Linear Light
Image upscaling - Jinc (3 taps)
Chroma upscaling - NNEDI3 (64 neurons)
Image doubling: always + 64 neurons
post #1632 of 2351 Old 01-28-2015, 08:02 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
Don't think the GTX 960 would be fast enough for those settings. Its still a low-mid-range card afterall, and NNEDI3 64 for 1080p to 2160p is a lot of work.
4K output is still a bit in the land of the unknown, as not many people have screens for that, and considering the GTX 980/970/960 are the first graphics cards to even support HDMI 2.0 so far... not much experience around in the community yet, I'm afraid.
Nevcairiel is offline
post #1633 of 2351 Old 01-29-2015, 03:51 AM
Sound&Life's Avatar
Quoted: 23 Post(s)
thanks, maybe we have to wait for the next GPU generation.
Whith my current GTX 750, I've lot of droped/delayed frames with the following setup.
Output resolution: 1920x1080
Chroma upscaling - NNEDI3 (32 neurons)
Image doubling: always + 32 neurons
As you can see, no UHD neither 64 neurons was set.
So best for me is to keep with Jinc 3 taps for both image/chroma upscale.
post #1634 of 2351 Old 01-29-2015, 06:08 AM
rwpritchett's Avatar
Have you tried "eos" for JRiver playback on Andriod yet? If not give it a try. My problem with Gizmo is it transcodes audio to mp3 instead of streaming the file untouched, which kinda sucks for high res audio. Eos will stream audio untouched. It's not as good as JRemote (yet) and it's not free, but it's worth a couple bucks to the developer to avoid transcoding.
https://play.google.com/store/apps/d...rose.eos&hl=en
rwpritchett is offline
post #1635 of 2351 Old 01-29-2015, 10:22 AM
eljr's Avatar
Quoted: 1067 Post(s)
Liked: 8082
On another forum I read that when ripping CD's you need to use a bit perfect program like Exact Audio Copy (EAC) or info could be lost.
Use JRivers to then play them.
I have been ripping my CD's using JRiver right into the JRiver library on a lap top, are these inferior rips?
eljr is offline
post #1636 of 2351 Old 01-29-2015, 01:53 PM
desertdome's Avatar
Liked: 1370
JRiver rips bit perfect and performs up to 16 rereads of the disc in Secure mode (default mode) in order to guarantee accurate ripping. No, your rips are not inferior.
eljr likes this.
post #1637 of 2351 Old 01-29-2015, 03:33 PM
Quoted: 204 Post(s)
Liked: 225
The manner in which I am recommending the use of Gizmo will result in zero transcoding. I.e. Use gizmo to push media from jRiver to another device. I don't really care about playback ON the phone or tablet. Their sound systems are lousy anyway.
jriver likes this.
post #1638 of 2351 Old 02-04-2015, 11:27 PM
CalJake's Avatar
Song selection change chirps
I'm using Media Center 20.063 and have noticed an annoying issue. If I'm playing a song and then double-click on another to play, it stops the song currently playing, then it plays about 1/4 to 1/2 second of that song before stopping again and then playing the next song. Any ideas how to stop this? This is playing the music on a Win 7 box the Media Center is installed on, with the music files on a 1-gb wired network to a NAS. I've tried various track change settings in options => audio device.
CalJake is offline
post #1639 of 2351 Old 02-09-2015, 06:42 AM
Mike_WI's Avatar
Quoted: 174 Post(s)
Liked: 121
Under Tools -> Options -> Audio...
-> Audio Device
Buffering set to ?
-> Settings
What is pre-buffering at?
Any options set in DSP Studio?
I'm not an expert on this, just troubleshooting.
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & output x1 cards} - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520]
HT Details: link
Mike_WI is online now
post #1640 of 2351 Old 02-09-2015, 09:59 AM
eljr's Avatar
Liked: 8082
Is there a way to have my dedicated lap top (with JRiver already installed and working fine) talk to my Oppo105 so I can listen to files wireless in that room?
eljr is offline
post #1641 of 2351 Old 02-09-2015, 11:27 AM
Quoted: 204 Post(s)
Liked: 225
Assuming that both are on the same wireless network - just enable the "Media Network" on JRiver. You can then use the regular JRiver UI on the laptop to push music to the Oppo (by setting the "play" zone to the Oppo rather than the "Player".) You won't even need your TV turned on for audio. You will probably want to learn how to turn OFF transcoding in JRiver - which takes about a minute.
eljr likes this.
post #1642 of 2351 Old 02-09-2015, 11:47 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1155 Post(s)
Liked: 1143
^ And there are other options too, such as using the JRemote iOS app to play the content to the Oppo. The end result as far as how the content is actually transported to the Oppo is the same, it's just that you can use an iPad/iPhone/iPod Touch to select what to listen to instead of sitting in front of the computer.
eljr likes this.
gsr is offline
post #1643 of 2351 Old 02-09-2015, 12:35 PM
eljr's Avatar
Liked: 8082
I swore off Apple. Is their an application for my windows phone that will allow me to control the flow of music from the lap top to the oppo wireless?
eljr is offline
post #1644 of 2351 Old 02-09-2015, 12:37 PM
eljr's Avatar
Liked: 8082
JRiver UI , what is UI?
With this set up I'd have to physically go to the office to push the music to the oppo wirless if I understand, correct?
eljr is offline
post #1645 of 2351 Old 02-09-2015, 12:42 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1143
If their web gizmo feature will work on Windows phone, that might work, but I don't use Windows Phone... Oppo also has their own app available, but not for Windows Phone at this time.
UI = User Interface, as in using the mouse and keyboard on your laptop / PC. Another option is to pull content from JRiver using the file browser on the Oppo, which would require having your TV turned on.
eljr likes this.
gsr is offline
post #1646 of 2351 Old 02-09-2015, 12:55 PM
eljr's Avatar
Liked: 8082
I just did this, amazing how easy it was. No artwork or anything but all my JRiver music!
eljr is offline
post #1647 of 2351 Old 02-09-2015, 12:56 PM
Quoted: 204 Post(s)
Liked: 225
UI is standard computer terminology for "User Interface"
The way I described it to you, yes - BUUUUT - if you want to leave the laptop in the office and you have an android or iOS (iPhone, iPad) phone or tablet, then you can put gizmo (android - free) or jRemote (iOS - has to be purchased) and control the whole setup remotely if you want to leave the laptop in your home office.
eljr likes this.
post #1648 of 2351 Old 02-09-2015, 01:07 PM
desertdome's Avatar
Liked: 1370
You can use several methods:
eljr likes this.
post #1649 of 2351 Old 02-09-2015, 01:27 PM
eljr's Avatar
Liked: 8082
I downloaded this onto my windows phone and when I open it, it asks for Host and Port, the port has a number already in the box. What do I put for Host?
eljr is offline
post #1650 of 2351 Old 02-09-2015, 01:32 PM
desertdome's Avatar
Liked: 1370
I think Host would be the IP address of your laptop that is running JRiver.
Reply Home Theater Computers
