JRiver Media Center Owner's Thread - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 382Likes
post #1891 of 2382 Old 05-16-2015, 06:30 PM
fitbrit's Avatar
Quoted: 57 Post(s)
Liked: 53
Today's JRiver challenge, send audio signal out the USB connection to DAC.
Only plays on PC.
Media Center does not appear in Windows 8.1 Control Panel, Playback Options.
Under PC and devices > other devices > HA1 USB Audio 2.0 Dac (driver error)
I did the trouble shooting, no fix.
1) Which build of MC20 are you running? In a recent update, the WDM driver was removed unless you go into options within MC and select it as a feature in General. That's why Media Center is not under playback options (I'm assuming that's the equivalent of Playback Devices in Win7).
2) Is the USB DAC selected as an output device within MC?
3) Is the USB DAC driver correctly installed? Reinstall it and go back to 2 above. It looks quite clear from the info you've posted that the USB driver isn't working properly.
4) Which sample rates can the DAC cope with - you may have to tell MC what to up/downsample in order to play properly if you want to use exclusive mode.
fitbrit is offline
post #1892 of 2382 Old 05-16-2015, 06:31 PM
eljr's Avatar
Quoted: 1185 Post(s)
Liked: 8881
Originally Posted by JimSatala77 View Post
Sorry it didnt work..did you try uninstalling the drivers and reinstalling them
of course
guess I have to uninstall the program and re install it. What a pain with that whole they send you a license and you get 10 or whatever nonsense
not looking forward to it
thanks for replies
question, if I now upgrade to 20.... will it be another nightmare?
I have it on two lap tops, one with a library and a remote on my phone, NMedium.
Everything is so delicate with it, I don't want to go back to square one.
ELJR's "listening to" blog.
eljr is offline
post #1893 of 2382 Old 05-16-2015, 06:41 PM
eljr's Avatar
Liked: 8881
it worked prior....
The USB driver will no longer work, correct.
DAC is HA1 Oppo, never had a sample rate issue with anything I threw at it
MC 19
eljr is offline
post #1894 of 2382 Old 05-16-2015, 06:56 PM
fitbrit's Avatar
Quoted: 57 Post(s)
Liked: 53
Don't worry about the 10 restores - they will give you more if you ask, and are a legit MC customer.
Ignore the stuff I wrote about WDM - that's MC20 specific.
eljr likes this.
fitbrit is offline
post #1895 of 2382 Old 05-16-2015, 07:36 PM
fitbrit's Avatar
Quoted: 57 Post(s)
Liked: 53
If the driver is corrupted or broken, as appears to be the case, then it may only accept inputs of a certain sample rate as a default. That's what Windows is probably adjusting to, so you can still play sounds from it, or any other non-exclusive mode app.
Any chance you could post a screenshot of what you playback device setup looks like in MC? My guess is that you may be able to get sound out to the DAC using Directsound in MC.
fitbrit is offline
post #1896 of 2382 Old 05-17-2015, 06:46 AM
eljr's Avatar
Liked: 8881
again, it plays on the this lap top, ASUS, it does not send the signal out the USB to DAC, HA1 Oppo.
eljr is offline
post #1897 of 2382 Old 05-17-2015, 06:52 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1262 Post(s)
Liked: 1328
This sounds like a problem with the Oppo HA-1 driver, not an issue with JRiver. Can you add a screen shot showing this error? I'd also post that info in the Oppo HA-1 thread and/or contact Oppo for assistance. It may be as simple as removing and reinstalling the driver for the HA-1. I'd also suggest trying a different USB cable as people have found that some USB cables work well with USB DAC's and some don't (no idea why). Though I'm an Oppo beta tester, I haven't been testing their personal audio products and am not overly familiar with the HA-1.
gsr is offline
post #1898 of 2382 Old 05-17-2015, 07:00 AM
eljr's Avatar
Liked: 8881
You can see in this short that the DAC is missing as an option to play the sound.
Here you can windows knows there is a problem.
Here you can see the problem, code 10. ?????
eljr is offline
post #1899 of 2382 Old 05-17-2015, 07:06 AM
eljr's Avatar
Liked: 8881
Originally Posted by gsr View Post
This sounds like a problem with the Oppo HA-1 driver, not an issue with JRiver. .
Yes it does, I should have thought of this.
I did not think of it because I can plug the other laptop in (with the library on it) and it works just fine.
But of course if the driver on the ASUS LapTop is corrupted it would not effect the driver on the other.
eljr is offline
post #1900 of 2382 Old 05-17-2015, 11:09 AM
Brian Hampton's Avatar
Quoted: 584 Post(s)
Liked: 312
I saw this "Driver Can Not Start" error in Windows once and spent frustrating hours re-installing drivers.
After giving up sometime during the night it occurred to me I may have to plug in headphones for the driver to install properly and that actually worked....... for real.... not kidding.
It couldn't complete it's install process without having some type of speakers hooked up.
Guess this won't help but ... it did happen to me.
-Brian
Brian Hampton is offline
post #1901 of 2382 Old 05-17-2015, 09:37 PM
fitbrit's Avatar
Quoted: 57 Post(s)
Liked: 53
fitbrit is offline
post #1902 of 2382 Old 05-18-2015, 12:14 PM
splotten's Avatar
Quoted: 285 Post(s)
Liked: 135
Intermittent crackling sound with convolution
Hey forum. I have been playing around with the convolution feature in Jriver. I have exported 44.1/16bit stereo filters ( for 44.1 music files) from REW based on a room measurement, and overall Im happy to notice a reduction in the "boominess" that usually plague my living room. Trouble is there is also some intermittent crackling going on during playback, when the filter is engaged. Filter off and the crackle goes away. I have monitored the peak-level meter and it stays below 100%. The filter runs at ~25 x real time.
Does anyone have a clue whats going on?
splotten is offline
post #1903 of 2382 Old 05-18-2015, 07:31 PM
tvuong's Avatar
Quoted: 1789 Post(s)
Liked: 1083
I did a search and can't find what I am looking for. I have added some filters in jriver DSP parametric eq and would like to measure my FR using REW thru jriver. Can someone detail what I need to do please? I have MC20.37. Thanks.
tvuong is offline
post #1904 of 2382 Old 05-19-2015, 12:06 AM
splotten's Avatar
Quoted: 285 Post(s)
Liked: 135
I cant explain in minute detail, but if you want to route sound through Jriver you need to activate the WDM driver:
Tools, options, general, features, WDM.
Then you can choose Jriver as audio output device in REW.
splotten is offline
post #1905 of 2382 Old 05-19-2015, 07:58 PM
tvuong's Avatar
Liked: 1083
^^ Sound real simple. I will try when I get home. I read about loop back, open URL, open Live, etc...not needed for MC20? Thanks.
tvuong is offline
post #1906 of 2382 Old 05-19-2015, 10:15 PM
splotten's Avatar
Quoted: 285 Post(s)
Liked: 135
Its the same as otherwise except Jriver is inserted in the output path. Normally its REW > Soundcard out. With Jriver its REW > Jriver > soundcard out. I havent needed to open live. You may?. If you do a loop back calibration, the filters must be Off for the calibration measurement. Otherwise their effect will be canceled out by the generated calibration file and wont show up in subsequent measurement.
splotten is offline
post #1907 of 2382 Old 05-20-2015, 05:52 AM
desertdome's Avatar
Quoted: 1303 Post(s)
Liked: 1513
With the WDM driver available in V20, the Open Live > Loopback is no longer necessary.
desertdome is offline
post #1908 of 2382 Old 05-20-2015, 06:37 AM
tvuong's Avatar
Liked: 1083
Great. Thanks guys.
Any of you guys use REW EQ to enter the its filters in jriver parametricEQ? What is your method of EQ'ing a 7.2 system with Audyssey XT32 subeqHT AVR?
tvuong is offline
post #1909 of 2382 Old 05-20-2015, 09:16 AM
splotten's Avatar
Quoted: 285 Post(s)
Liked: 135
Haven't used it for anything else than stereo. I'm still experimenting. I have exported the filters generated in REW as an impulse response .wav filter and imported said filter in to the convolution engine i Jriver, to avoid manually typing all the filters in to Jriver. I still have some crackling in the sound, so I might revert to entering the filters manually.
splotten is offline
post #1910 of 2382 Old 05-20-2015, 06:30 PM
|Tch0rT|'s Avatar
Quoted: 185 Post(s)
Liked: 128
I use REW to generate PEQ's that I input into JRiver on my desktop system with JBL LSR305 + 310S. On my HT I use a miniDSP nanoAVR-HD (got it for free) to use PEQ's REW generated, it fundamentally works the exact same way as JRiver's PEQ, it's just easier to import the filters. Thinking about testing out rePhase with JRiver's convolution feature at some point in near future.
My Home Theater/Video Gaming/HTPC/2 Channel rig (Mitsubishi, MartinLogan, Marantz, DIYMA, and others)
|Tch0rT| is offline
post #1911 of 2382 Old 05-20-2015, 08:12 PM
tvuong's Avatar
Liked: 1083
I am not so sure how jriver parametricEQ works with Audyssey XT32 receiver. Audyssey calibrates speakers/subs using its internal tone independ of the source (jriver). If I measure my FR, eq it in REW, and enter filters to jriver parametricEQ to flatten the response within +-3db, should I turn Audyssey OFF when playing a movie on jriver (with parametricEQ turned on)? If I turn Audyssey on, does it correct my corrected FR from jriver, thus over eq my FR which might make my FR no longer +-3db? I like the dynEQ feature that boost bass as my norm listening level is -15; unfortunately this option is not available when aud is turned off. So my question really is should I turn Audyssey OFF when using jriver parametricEQ? Is there a way to use Audyssey in conjunction with jriver parametricEQ? Thanks.
tvuong is offline
post #1912 of 2382 Old 05-20-2015, 09:55 PM
splotten's Avatar
Quoted: 285 Post(s)
Liked: 135
Yes it would be really cool if there were a way to import a filter set from REW in to Jriver, like if Jriver was able to read .req filter files. Entering all those filters is a chore.
EDIT: How do you import the filters into miniDSP?
splotten is offline
post #1913 of 2382 Old 05-20-2015, 11:02 PM
|Tch0rT|'s Avatar
Quoted: 185 Post(s)
Liked: 128
Since you have XT32 I'd either use Audyssey or PEQ but not both at the same time unless Audyssey is missing something with EQing your sub. You could use both at the same time but the problem is then you're probably EQing to two different target curves and I don't think there's a way to exactly know what the curve is for Audyssey presets so you'll end up potentially correcting something then negating it (for a sub this wouldn't be a big deal but other channels I would not do both). I don't use Audyssey, never have and never probably will as I'd go Dirac Live first IMO.
Yeah it would be nice just to be able to export a file and import it to JRiver (hint hint JRiver team ). In REW you first setup which miniDSP processor you have, setup your target EQ curve and calculate it for each channel you want to EQ, then you use "Send Filters To EQ" option under Filter Tasks in the EQ section of REW (it's really easy to miss this part), it makes a text file and then you can import it using the miniDSP software for your particular device. It's easy peasy.
|Tch0rT| is offline
post #1914 of 2382 Old 05-21-2015, 01:20 AM
splotten's Avatar
Quoted: 285 Post(s)
Liked: 135
Yes. That was what I was thinking. Export a file containing the peq filters that can then be imported into Jriver. That would save a lot of work and make experimenting with different target curves much more straight forward. That was the reason for going with convolution, but it seem to introduce some latency and crackling that I cant track down. There should also be an export option in REW under generic filter, or a dedicated Jriver option in REW. Hope someone from REW and Jriver reads along ;-)
splotten is offline
post #1915 of 2382 Old 05-22-2015, 04:18 AM
Quoted: 517 Post(s)
Liked: 59
This may sound stupid, but what do you guys mean by "convolution"? That is a mystery term for me. Lol
Tip24/96 is offline
post #1916 of 2382 Old 05-22-2015, 04:24 AM
jriver's Avatar
Quoted: 92 Post(s)
Liked: 75
Here's the topic on our wiki:
http://wiki.jriver.com/index.php/Convolution
Jim Hillegass / JRiver Media Center
jriver.com or Owners Thread at AVSForum
jriver is offline
post #1917 of 2382 Old 05-23-2015, 04:45 AM
Quoted: 517 Post(s)
Liked: 59
I have several questions that I could not find answers to in the wiki.
First, can typical PEQ type filters be used in conjunction with convolution filters? Or do convolution filters make any addition PEQ'ing meaning less? Let's say that i take an in room frequency response sweep and that my in room frequency response is pretty ragged, with various peaks and dips throughout say 20hz to 20,000hz range. Would using something like RePhase or Acurate to measure and generate convolution filters that could then be imported to JRiver offer the same or better results to instead use the more traditional method of using PEQ to flatten the peaks and moderately boost the dips? Would it be reasonable and/or possible to take the FR that is generated with a convolution filter and add any additional PEQ'ing that could be tweaked by hand to optimize the FR? Or does generating a convolution filter using RePhase or Acurate and importing it to JRiver unable to further tweak the resultant frequency response?
Tip24/96 is offline
post #1918 of 2382 Old 05-23-2015, 05:26 AM
jriver's Avatar
Quoted: 92 Post(s)
Liked: 75
First, can typical PEQ type filters be used in conjunction with convolution filters? ...
Please try a Google search for JRiver Convolution. You'll find several threads on our forum and others.
jriver is offline
post #1919 of 2382 Old 05-23-2015, 08:21 AM
splotten's Avatar
Quoted: 285 Post(s)
Liked: 135
You can use REW ( Im not really familiar with the other ones you mention) to generate a set of filters to counter the rooms and speakers "nonlinearities". That filter set can be exported as an impulse response in a .wav file that can be imported in to Jrivers convolution engine. If you wish, on top, you can add shelving, peq or any other filter you wish to modify the result. At least thats how I do it. Im just a beginner and this may not be the best way to do it, but it sure is easy to just export/import the filter impulse response from REW and then tweak to taste on the fly. IMO not much tweaking is needed if you figure out at good target curve, but the option is there if needed. - Keep an aye out for digital clipping. It sounds nasty, but can be monitored in Jrivers peak-level monitor.
EDIT: Forgot I had a bookmark that looks interesting.
http://yabb.jriver.com/interact/index.php?topic=87538.0
splotten is offline
post #1920 of 2382 Old 05-24-2015, 05:34 PM
colleycol's Avatar
Quoted: 23 Post(s)
I am running an HTPC with a Intel Core i3-2105 Sandy Bridge (HD3000) and thinking of getting JRMC. I am pretty sure I need to get an external card to run with Red October/Mad VR without compromise.
Can any one recommend a low profile card just for my MKV rips. No gaming will be done, strictly blu-ray playback.
_________________________________________________
JVC RS4810, Screen Excellence 4K 115 inch wide
Lumagen Radiance 2021
Onkyo 818, Emotiva Amp
B&W CT700 Series Speakers, (2) PowerSound Audio XS30s
HTPC running Emby, 12TB Server for storage
colleycol is offline
Reply Home Theater Computers
