JRiver Media Center Owner's Thread - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 363Likes
post #1981 of 2351 Old 07-17-2015, 01:08 PM
jriver's Avatar
Quoted: 92 Post(s)
Liked: 73
Here are the instructions:
http://yabb.jriver.com/interact/index.php?topic=98668.0
Djoel likes this.
Jim Hillegass / JRiver Media Center
jriver.com or Owners Thread at AVSForum
jriver is offline
post #1982 of 2351 Old 07-17-2015, 01:29 PM
CountryBumkin's Avatar
Quoted: 218 Post(s)
Liked: 55
Originally Posted by |Tch0rT| View Post
it's happened twice to me that paid upgrades are announced so close to my purchases, I would've waited if I had known.
First time - shame on JRiver. Second time - shame on you.
CountryBumkin is offline
post #1983 of 2351 Old 07-17-2015, 01:32 PM
Quoted: 218 Post(s)
Liked: 55
Originally Posted by Djoel View Post
Question.
If I want to take advantage of 18.98 introduction fee, do I have to use my HTPC where I have JRMC 19 running to download it or can I start the process with my laptop and then move to htpc?
Djoel
You just need to enter your MC19 license number (on the website purchase form) when you buy the upgrade so JRiver can confirm you have an existing license to upgrade from. It doesn't care which computer you buy from.
post #1984 of 2351 Old 07-17-2015, 03:06 PM
Djoel's Avatar
Quoted: 543 Post(s)
Liked: 417
Thanks, but all I'm doing is going around in a circle
Thanks thou.
Djoel
Djoel is offline
post #1985 of 2351 Old 07-17-2015, 03:09 PM
Djoel's Avatar
Quoted: 543 Post(s)
Liked: 417
Never mind, I just arrived at the right page with the right discounted prices.
Thanks all
Djoel
Djoel is offline
post #1986 of 2351 Old 07-17-2015, 03:54 PM
|Tch0rT|'s Avatar
Quoted: 185 Post(s)
Liked: 128
Nah it wasn't JRiver's fault the first time. I wasn't familiar with their upgrade cycle. I somewhat am now and no longer on the end of life cycle for the versions I have licenses for so it's all good.
My Home Theater/Video Gaming/HTPC/2 Channel rig (Mitsubishi, MartinLogan, Marantz, DIYMA, and others)
|Tch0rT| is offline
post #1987 of 2351 Old 07-18-2015, 07:47 AM
eljr's Avatar
Quoted: 1067 Post(s)
Liked: 8082
OK, today neither my OPPO or mMedium can correct to the JRiver server.
Sure it's a familiar tale but honest, is there any way to trouble shoot it?
I lost hours.... hours trying to get this thing to connect. The last two weeks it's worked perfectly for the first time ever... now today.
Generally when it does not see the Oppo I go ito the Oppo and pull the files. Today the Oppo finds no server to pull from. This is a first.
eljr is offline
post #1988 of 2351 Old 07-18-2015, 04:24 PM
jriver's Avatar
Quoted: 92 Post(s)
Liked: 73
A flakey connection may mean a flakey network, but make sure you're using MC20.0.131. It's on the MC20 board on the JRiver forum.
jriver is offline
post #1989 of 2351 Old 07-19-2015, 11:27 AM
alex014's Avatar
Quoted: 16 Post(s)
I downloaded the Jriver trial and everything is great. However when I select a ripped dvd it plays the main title. Does Jriver support dvd menus? I would like it to automatically go to the main menu instead. Thanks for any help
alex014 is offline
post #1990 of 2351 Old 07-19-2015, 03:55 PM
rec head's Avatar
Quoted: 112 Post(s)
Liked: 88
DVD or BD? MC does support DVD menus but not bluray menus.
rec head is offline
post #1991 of 2351 Old 07-20-2015, 06:46 AM
alex014's Avatar
Quoted: 16 Post(s)
Regular dvd mostly ones that are collection of TV episodes from Disney channel like Mickey Mouse clubhouse. Is there a way to make MC automatically go to main menu instead of the main title
alex014 is offline
post #1992 of 2351 Old 07-20-2015, 07:41 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1155 Post(s)
Liked: 1143
It should go to the main menu by default. How exactly are you ripping your DVD's?
gsr is offline
post #1993 of 2351 Old 07-20-2015, 10:51 AM
alex014's Avatar
Quoted: 16 Post(s)
I use anydvd and I rip the full disc to a video ts folder
alex014 is offline
post #1994 of 2351 Old 07-20-2015, 11:34 AM
Quoted: 218 Post(s)
Liked: 55
I think this may be your problem (if your using a drive over 2TB). This thread describes issues with Microsoft's DVD Navigator (which JRiver uses) when drives are 2TB or larger and the DVD rip is a "file". http://yabb.jriver.com/interact/index.php?topic=97895.0
The fix seems to be to rip your DVDs to ISO then use VirtualCloneDrive http://www.slysoft.com/en/virtual-clonedrive.html or similar to mount the ISO - which is then treated as if it's an "optical disc" by DVD Navigator.
I only rip the main movie, so I have not had this issue my self.
Try it and report back if it works.
post #1995 of 2351 Old 07-20-2015, 11:39 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1143
I've ripped a bunch of DVD's to VIDEO_TS folder structures on a 6TB drive and they all play as expected in JRiver MC.
JimSatala77 likes this.
gsr is offline
post #1996 of 2351 Old 07-20-2015, 01:35 PM
Quoted: 218 Post(s)
Liked: 55
Someone else in that link also said he/she was not having problems with VOB/IFO files on their large drives.
It may still be worth a try to OP. I don't have any other suggestions (except you could try ripping to MKV and see if that format works).
Good Luck
post #1997 of 2351 Old 07-20-2015, 05:38 PM
alex014's Avatar
Quoted: 16 Post(s)
Thanks for the help I will try it again I might have just missed something.
alex014 is offline
post #1998 of 2351 Old 07-20-2015, 08:20 PM
lukeamdman's Avatar
Quoted: 1191 Post(s)
Liked: 1422
Originally Posted by desertdome View Post
It would be nice if you could automatically set your refresh rate to match your media . . . which is why you can.
In madVR's settings go to devices > "your device" > display modes set it up like below. Now the refresh rate will automatically switch for video based on its refresh rate and then switch back to the desktop resolution when not watching a movie. You can't use resolutions your display doesn't support.
I have a couple of blu-ray concerts that are 29fps and my display stays at 60fps. I added 1080p29 and 1080p30 to the list to no avail.
The video doesn't stutter but the timing between the audio and video is off.
lukeamdman is offline
post #1999 of 2351 Old 07-21-2015, 06:41 AM
desertdome's Avatar
Quoted: 1224 Post(s)
Liked: 1370
Displays don't do 1080p29 or 1080p30. They use either 1080p59 or 1080p60. There are a lot of Blu-ray concerts that are interlaced (1080i). This taxes the video card more when using madVR. Use Ctrl+J to see the madVR stats during playback and see if any frames are dropping. It will also show if deinterlacing is on. You may need to force either video or film deinterlacing.
For a while I used a separate zone for Blu-ray concerts that are interlaced and had ZoneSwitch setup to automatically switch to that zone if my Media Subtype is Concert. This Blu-ray concert zone used Red October Standard instead of Red October HQ and can play interlaced content better, but with some loss of image quality.
desertdome is offline
post #2000 of 2351 Old 07-21-2015, 08:29 AM
lukeamdman's Avatar
Liked: 1422
These do have de-interlacing on when viewing the settings with Ctrl+J.
"Force film mode" seems to have fixed the Cream blu-ray, but on the Eagles Farewell I blu-ray it's now dropping multiple frames every second and video playback is very bad. Un-watchable.
post #2001 of 2351 Old 07-21-2015, 08:40 AM
desertdome's Avatar
Liked: 1370
I remember having trouble at dlbeck's with the Eagle's Blu-ray, too. Did you try using Red October Standard? My current video card is the GTX 960 and plays the Eagles blu-ray just fine, but my former card couldn't handle it. I'll have to check it out this evening if I get some time.
When you get the Eagles blu-ray playing fine, can you see what peak SPL you get with just your mains from the stereo PCM track of Dirty Laundy. Here is what I got when messing around last week. This is about 1M from one speaker using Omnimic. To me, that track is even more dynamic than the Cream drum solo. I need to measure the drum solo.
post #2002 of 2351 Old 07-21-2015, 09:29 AM
lukeamdman's Avatar
Liked: 1422
I need to figure out how to have just the Eagles blu-ray use Red October Standard...
I measured this from the LP about 9ft from the mains. Stereo PCM track, no subs.
post #2003 of 2351 Old 07-21-2015, 09:56 AM
desertdome's Avatar
Liked: 1370
Right Click Playing Now and select Add Zone.
Call it Blu-ray Concerts or Red October Standard and copy your existing zone.
Set existing zone to Red October HQ and new zone to Red October Standard.
Go to Player > Zone > ZoneSwitch, click enable, click add and create two rules.
The first rule can use just the Album name if you want and send it to the Red October Standard zone. This is a way to specify the exact album. Otherwise you can specify any criteria or combination of criteria.
The second rule will send all other files to the Red October HQ zone.
Be sure to set each rule to stop playback in the other zone.
ZoneSwitch doesn't really work for a playlist which contains items that would go to different zones. This is because each zone has its own playlist.
I may have missed something since I typed this up quick. Let me know if you have any questions.
I use zones for Blu-ray Movies, Blu-ray Concerts, DVD, Stereo Music, Multi-channel Music and TV because I do bass management and some other stuff different depending on content.
WOW! However, you have less difference between peak and max than I do. This is what I'm curious about. I also need to compare my Omnimic to a mic with REW to see how they differ.
I forgot to mention that I calibrated my SPL using JRiver's Tools > Advanced > Audio Calibration > Volume Calibration and calibrated the mains to 83 dBC slow.
HTPCat likes this.
post #2004 of 2351 Old 07-21-2015, 10:23 AM
lukeamdman's Avatar
Liked: 1422
That seemed to work.
I think I was maxing out my mic. Those last few DB didn't raise the peak but did raise the max
post #2005 of 2351 Old 07-21-2015, 10:48 AM
Djoel's Avatar
Quoted: 543 Post(s)
Liked: 417
I would like to rip some new Blu Rays that I have collected ever since the last time I rip movies about a year and half ago, It was dreadful to say the least using MakeMkv as I wasn't sure if it was ripping or not and when I did make a copy the cover looked different than the few my friend did for me, or I had multiple covers, with what? Who knows?
Any way I would like to take a second stab at ripping Blu Rays and was wondering if I can some who associate JRiver with what ever method of ripping MKV's as easy and smoothly as possible? So I what I'm asking is there a Blu ray ripping program that would play nice with JRMC?
Djoel
Djoel is offline
post #2006 of 2351 Old 07-21-2015, 10:58 AM
BllDo's Avatar
Quoted: 594 Post(s)
Liked: 392
JRMC does rip blu ray discs. Here is a post from @desertdome describing the process
I use MakeMKV. There have only been a couple of the +300 discs I've ripped that have had issues. I use MCM for metadata.
BllDo is offline
post #2007 of 2351 Old 07-21-2015, 11:30 AM
JimSatala77's Avatar
Quoted: 396 Post(s)
Liked: 139
Djoel
I Use Anydvdhd for copy protection removal and clonebd for discs..it is simple to use and makes any quality from full to just a fraction of the size
JimSatala77 is offline
post #2008 of 2351 Old 07-21-2015, 11:51 AM
Djoel's Avatar
Quoted: 543 Post(s)
Liked: 417
Thanks guys I'll look into both methods, and see which will be to my liking.
Djoel
Djoel is offline
post #2009 of 2351 Old 07-21-2015, 12:00 PM
3ll3d00d's Avatar
Quoted: 1636 Post(s)
Liked: 600
what is the difference between ripping a bd in jriver vs using clonebd?
3ll3d00d is online now
post #2010 of 2351 Old 07-21-2015, 12:13 PM
Quoted: 396 Post(s)
Liked: 139
Thumbs up
clonebd shows you every playlist and sound stream and lets you decide what exactly you want..just the movie..bits and pieces of extras..different soundtracks and subtitles..and lets you start directly to the movie..i have used both jriver and clonebd and clonebd is better at the ripping..i use Jriver for all my playing and sorting
3ll3d00d likes this.
Reply Home Theater Computers
