A HTPC for a college kid - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-11-2011, 04:49 PM - Thread Starter
iff2's Avatar
Hey guys, I will be purchasing a 1080p projector for my apartment next semester and I would like to use an old laptop as a htpc.
Essentially, my college only provides composite cables for TV, so I need to buy a hd-tv tuner, like this one:
http://www.amazon.com/dp/B000OLSJNU/...net_mp-2611-20
Then I need to run the signal to my PC, and output the image through either an HDMI or VGA cable to my projector. I have a Lenovo T60 (a laptop), with an ATI X1300 graphics card and a centrino duo processor with 1GB of RAM running XP SP3. My concern is that the integrated graphics card will not be enough for smooth 1080p video, so would it be possible if I purchased a mini-pci-e card for the T60? I know it's not the best computer, but I got it for free and I think it's worth a shot. I'm open to suggestions for any hdtv tuner or graphics card, so feel free to suggest your input. Thanks guys!
iff2 is offline
post #2 of 9 Old 08-12-2011, 11:28 AM
bjterry62's Avatar
So you plan to do OTA HDTV on a 5yr old lappy to an 1080p HD projector over VGA? Doesn't sound like a winning combination. There's no way you would consider a Mini HTPC with decent storage and graphics? I believe Assassin's guide has some in the low hundreds cost-wise.
BT
Just remember, to the MPAA "We're all guilty until..............."
bjterry62 is offline
post #3 of 9 Old 08-12-2011, 11:48 AM
fitbrit's Avatar
Quoted: 57 Post(s)
Liked: 53
Your concerns over video are well founded. 1080p won't be a good experience for you.
fitbrit is offline
post #4 of 9 Old 08-13-2011, 01:39 PM - Thread Starter
iff2's Avatar
BT
I would consider a mini htpc, but I thought I would give the T60 a shot first before I jumped the gun. I have a bunch of old laptops and netbooks that I thought I could put to use- my Dell Mini 1010 has an HDMI port but the integrated GMA500 card is probably worse than the X1300. I'll probably be getting a projector like the Optoma HD20 for about a $1000 to give you an idea about the "1080p" quality that I will be utilizing. I'm also willing to upgrade the T60 if you think that it could handle the job with a better graphics card or ram. I'll look in to Assassin's guide too, thanks for the post.
I figured the graphics card and processor weren't going to cut it, but I wasn't sure if this could be a minimum spec rig to get the job done. However in regards to the tv tuner, do you have any recommendations? I might end up using my newer laptop (core i7, SSD, 1GB vid ram, etc. etc.), which can easily handle 1080p, since it maybe only option to use OTA. However, do you think I could run 720p on the T60 with a lower-end projector? I'm just curious...
iff2 is offline
post #5 of 9 Old 08-15-2011, 09:40 AM
dbc
dbc's Avatar
If it's just OTA HD, the video on your T60 doesn't sound like a deal breaker.
Everything will depend more on the system requirements of your specific tuner dongle.
If you want to playback other types of HD sources, then it starts getting more complicated.
dbc is offline
post #6 of 9 Old 08-15-2011, 10:10 AM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Ur in college? layoff the toys, hit the books. Come up with the next Facebook!
MrBobb is offline
post #7 of 9 Old 08-15-2011, 10:23 AM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
Go to the parties, hit on the girls.
almostinsane is offline
post #8 of 9 Old 08-15-2011, 10:58 AM
ljo000's Avatar
You could always get a media player instead of a full HTPC. I have an Xtreamer that I added a 500gb drive (total cost ~$200) and it does 1080p mkv via HDMI with no problems. You can transfer files to/from it and your laptop over your network.
ljo000 is offline
post #9 of 9 Old 08-15-2011, 12:35 PM
hceuterpe's Avatar
BT
You guys need to read up on Thinkpads. Saying the OP has to use VGA for his video is a silly statement. You can stick with a digital (DVI) output by getting a docking station. They are easily under $50 used on eBay. The docking stations for T60/T61/T400 are all interchangeable (and I think many more models). I also suggest the Silicon Dust HDHomerun network (via ethernet) tuners. A dual tuner is under $100. Hopefully you got a router that serves IP addresses through DHCP.
The bigger question will be whether your CPU can handle 1080p video. Probably with MPEG-2, but you might be pushing it for H.264 and VC-1 even. I'd try some 1080p H.264 material first to see if you want to shell out for addons.
Alternatively, may want to consider using the T60 just to record content and then use your newer laptop to watch it. You can definitely test all this out first before you spend any money. A networked tuner like the HDHomeRun will definitely be better for an older machine then a USB tuner. Also, you may want to look for the "advanced" dock as it has a PCI express slot and an expresscard slot so that will give more options. That unit is 250310U.
hceuterpe is offline
Reply Home Theater Computers
