New HTPC Build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-17-2011, 08:37 AM - Thread Starter
Jiminybillybob's Avatar
Hi guys.
Been looking out for a HTPC for quite some time now, and I've finally found a setup that looks quite appealing.
Asus F1A75-I Deluxe
AMD A8-3850 Llano
Antec ISK 300-150
Then getting 4-8gb of ram, probably start out with xbmc live from a USB flashdrive and then getting a small SSD and setting up win7+xbmc ontop of that.
How do you guys think this would handle playing 1080p material(streamed from another pc) and very light gaming(emulators, old school LAN games etc)?
Should I go for an i3 sandy bridge setup instead?
I'm very much digging the remote that comes with the motherboard.. looks to be the absolute best mb for a htpc atm.
So.. Any thoughts?
Jiminybillybob is offline
post #2 of 4 Old 08-17-2011, 01:05 PM
jeffkro's Avatar
Originally Posted by Jiminybillybob View Post
Hi guys.
Asus F1A75-I Deluxe
AMD A8-3850 Llano
Antec ISK 300-150
So.. Any thoughts?
Depends what you mean by light gaming. Llano should do an excellent job for your HTPC tasks, but for gaming core i3 with something like a gts450 would obliterate it. You really need to look at what game and at what resolution you are going to run it to know if its playable. My guess is that any game older than 2 years will play or if setting are turned way down modern games should play fine.
jeffkro is offline
post #3 of 4 Old 08-18-2011, 02:22 AM - Thread Starter
In gaming I'm talking about emulators(nes, gameboy, n64) and playing older games like diablo 2, Unreal tournament, warcraft 3 etc..
post #4 of 4 Old 08-18-2011, 04:47 AM
jeffkro's Avatar
I think you would be fine with that system
jeffkro is offline
Reply Home Theater Computers
