Setting Up The HDHR Prime + Tuning Adapter (Cablevision) - AVS Forum | Home Theater Discussions And Reviews
Old 08-29-2011, 08:17 AM - Thread Starter
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Quick question, I just picked up the HDHR Prime and since I use Cablevision I am required to use a Tuning Adapter as well. I already have the Prime set up with the cablecard and installed on my PC. The next step is to get it added in WMC. I see that when I go through the WMC setup at some point I will need to call Cablevision to get an activation code. Also, on the Tuning Adapter instructions it tells me I need to call Cablevision to activate the TA. Any ideas if I should be calling to activate the TA first before I start with the WMC activation process, or it probably doesn't matter?
On a side note, trying to get in touch with Customer Service to activate a cable card during a hurricane is probably not the best idea lol. I will have to try again tonight when I get home from work.
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
Old 08-29-2011, 05:27 PM
jbcain's Avatar
Liked: 64
activate the card ahead of time, trust me !
jbcain is offline
Old 08-29-2011, 06:07 PM - Thread Starter
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Thanks, hope to do tomorrow when i get home.
Cheers,
Damian
