Advanced MPC-HC Setup Guide - Page 101 - AVS Forum | Home Theater Discussions And Reviews
 140Likes
post #3001 of 4262 Old 06-13-2014, 12:18 PM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
You need to actually enable bitstreaming in ReClock, or it'll fail and fallback to other random components, as happened here.
Its called "Accept Bitstream Formats" in the options.
Note that ReClock cannot do its magic properly if you're bitstreaming, so its not recommended if you actually need/want ReClock to fix the video refresh.
pasiniskanen likes this.
Nevcairiel is offline
post #3002 of 4262 Old 06-14-2014, 10:43 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
Originally Posted by Fredgido View Post
Hello
Can anyone help me find the cause of my screen tearing?
It happens even with any v-sync but if I enable windows aero it disappears...
http://i.imgur.com/ojw8yAB.jpg
It tears always in the same spot with normal if I use the default V-sync.
I searched a lot but can't find the cause or a solution. My gpu is from the HD 5800 series.
it's simple without aero no vsync you can use MadVR fullscreen exclusive mode or d3d fullscreen with EVR(not recommended at all) or aero.
this tearing looks like the normal AMD tearing i get too with my AMD card and no aero. Nvidia works pretty good without aero at least my Nvidia card i got in the past 5 years.
mightyhuhn is online now
post #3003 of 4262 Old 06-15-2014, 08:42 AM
Liked: 0
Hello, after using VLC for years I decided to try MPC-HC, but I'm having some annoying trouble. Basically, when I try to play .flv or HD .mkv files, all I get as video output is a black screen. Sound is fine, I can seek in the file, only there is no video. I tried searching for a solution on the internet, but no luck. Any help will be appreciated!
Anabasis is offline
post #3004 of 4262 Old 06-15-2014, 09:20 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
the informations you provide are not enough. we know you get a black screen in mpc-hc that's all that's nothing.
but here i guess:
you use MadVR with a rotated display?
post #3005 of 4262 Old 06-15-2014, 09:45 AM
Liked: 0
Right, sorry, I forgot. I get a black screen regardless of which renderer I use, MadVR, Sync, Enhanced, all of them. I reinstalled MPC resetting all settings and I still have the same problem. I'm running Windows 8.1 x64 on E4500 and HD4870 512MB.
Anabasis is offline
post #3006 of 4262 Old 06-15-2014, 10:27 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
what did the filter list show.
just right click in the darkness -> filter.
post #3007 of 4262 Old 06-15-2014, 10:48 AM
Liked: 0
I'm attaching a screenshot.
Anabasis is offline
post #3008 of 4262 Old 06-15-2014, 11:16 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
what hardware are you using?
disable DVXA in mpc-hc for a test.
post #3009 of 4262 Old 06-15-2014, 11:28 AM
Liked: 0
You mean in the Hardware Acceleration submenu under Video Decoder? Setting it to "none" gives me a video output, but it stutters badly.
Anabasis is offline
post #3010 of 4262 Old 06-15-2014, 09:34 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
the problem is your hardware looks like is too old. the dxva decoder in lavfilter is dxva 2 so you may need a dxva 1 decoder with your gpu.
try mpc-be this version still uses the old internal codecs and the dxva decoder supports partial acceleration. if i remember correct it is disabled by default.
post #3011 of 4262 Old 06-16-2014, 12:31 AM
Liked: 0
I'm not sure it's about the hardware. MPC-BE gives me exactly the same problems as MPC-HC. VLC uses DXVA2 and plays those videos with no trouble at all.
Anabasis is offline
post #3012 of 4262 Old 06-16-2014, 03:41 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
you can report this to nevcairiel in doom 9:
http://forum.doom9.org/showthread.php?t=156191
and mpc-be:
http://forum.doom9.org/showthread.php?t=165890
your driver version is needed too.
post #3013 of 4262 Old 06-17-2014, 12:02 PM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
I have a HD4850 for testing (which is even a bit slower than your 4870), and videos play just perfectly on that. It must be something in your setup.
post #3014 of 4262 Old 06-17-2014, 02:05 PM
Liked: 0
If it helps, I'm using the latest legacy drivers, 13.4 Beta.
Anabasis is offline
post #3015 of 4262 Old 06-18-2014, 11:16 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
Uh, they have 13.9 for the "legacy" cards, I would suggest to go try that instead.
post #3016 of 4262 Old 06-18-2014, 12:17 PM
Liked: 0
Thanks, I'm updating. For some reason, AMD's internal search kept pointing me to v13.1/13.4.
Anabasis is offline
post #3017 of 4262 Old 06-18-2014, 01:08 PM
Liked: 0
Looks like 13.9 isn't even compatible with Windows 8.1. I'll switch back to 13.1 and see what happens.
Anabasis is offline
post #3018 of 4262 Old 06-18-2014, 02:43 PM
Liked: 0
...and what happens is that I keep getting a black screen. I've had enough, I'm going back to VLC for good.
Anabasis is offline
post #3019 of 4262 Old 06-22-2014, 12:57 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
you should be able to software decode most 1080p videos though with that e4500. Maybe a modest overclock is needed for really high bitrate (~35 megabit) videos.
I had a 4870 previously. Idk if it was because it had uvd 2.2, or because I was using pci express x16 v1.1, or because it was an old version of lav, but copyback wasn't fast enough for 1080p. This was before madvr supported native dxva and copyback was the only hardware option. I have the nvidia counterpart as well, the gtx 260, and it worked fine with cuvid.
anyway, as for the black screen, do you think that might be something specific to the video you're testing? Or does it happen with all h264 videos?
MlNDBOMB is offline
post #3020 of 4262 Old 06-24-2014, 09:27 AM
jhughy2010's Avatar
Quoted: 846 Post(s)
Liked: 276
Quick question. I noticed on some titles the audio is defaulted to DTS-HD 7.1 does it matter that my audio setup is only 5.1 or should I manually change it?
jhughy2010 is offline
post #3021 of 4262 Old 06-24-2014, 09:42 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
you need to down mix it to 5.1. if you use bitstream your AVR will do it. without bitstreaming you need to down mix it somewhere in your filter chain.
you can do this with Lavfilter
post #3022 of 4262 Old 06-24-2014, 10:26 AM
jhughy2010's Avatar
Quoted: 846 Post(s)
Liked: 276
Ok so I think I have nothing to worry about then because I believe I have MPC set-up to bitstream.
Another question. I cannot seem to make it so that force subtitles work. For example, I ripped Life of Pi via MakeMKV and I unchecked all subtitles except "english forced subtitles". Anyhow, during playback the forced subtitles do not automatically play unless I manually select english subtitles. Right now, forced subtitiles is selected by default.
This may belong in a different thread but should I adjust the way that I rip using makemkv?
post #3023 of 4262 Old 06-24-2014, 12:42 PM
steelman1991's Avatar
Quoted: 226 Post(s)
Liked: 119
Sometimes MakeMKV doesn't set the 'forced' flag properly. Open MKVmerge (part of the MKVtoolnix programme) from there open Header Editor (File/Header Editor) load the file, identify the correct subtitle stream, change/add 'forced' flag and save.
jhughy2010 likes this.
steelman1991 is online now
post #3024 of 4262 Old 06-24-2014, 02:08 PM
jhughy2010's Avatar
Quoted: 846 Post(s)
Liked: 276
Ok where do I download MKVtoolnix from?
When I am about to rip the movie using makemkv, do I check only the "Subtitles English (forced only)" check-box or do I check both in their drop down like I have been?
post #3025 of 4262 Old 06-24-2014, 02:17 PM
Quoted: 226 Post(s)
Liked: 119
http://lmgtfy.com/?q=mkvtoolnix
I just rip all english subs and then set the forced flag as necessary.
post #3026 of 4262 Old 06-24-2014, 08:29 PM
jhughy2010's Avatar
Quoted: 846 Post(s)
Liked: 276
Great advice thank you! It seems to have worked for a few that have been causing me a headache.
post #3027 of 4262 Old 06-24-2014, 08:45 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
you can change the way LavSplitter is loading subtitle
or just press S.
there are codecs on bluray you can't bitstream and LPCM is used for this. so you should still enable a mixer.
post #3028 of 4262 Old 06-24-2014, 08:55 PM
Liked: 0
Nice tutorial But I am really surprised that this thread does not mention the use of SmoothVideo Project (SVP) running in contrast with MPC-HC
http://www.svp-team.com/
It turns MPC-HC into a Hi-Def player
No matter what setting you apply to MPC-HC, you are not really enjoying your movies unless you have (SVP) running in the background.
Thanx for this thread! I learned a lot
Any chance at posting some tweaks to enjoying my 3D movies with MPC-HC?
One more thing in regards too 3D movies, I've noticed that KMPlayer has a Scene Depth filter for it's player.
But it's a independent filter.
Would you know if there are any Scene Depth filters available for MPC-HC somewhere?
SABERWOLF357 is offline
post #3029 of 4262 Old 06-24-2014, 09:09 PM
jhughy2010's Avatar
Quoted: 846 Post(s)
Liked: 276
or just press S.
I appreciate your response. Could you be a little more specific though?
1. How would I know that the codec on the specific bluray cannot be bitstreamed? All of my BD movies say either DTS-HD or Dolby TrueHD on my AVR screen. This leads me to believe that it is properly decoding the audio. If it wasn't bitstreaming properly I would expect to see PCM on the AVR screen. Furthermore, how would I enable a mixer?
2. I have ignorantly played around in the LavSplitter with all its settings and cannot seem to figure it out. What should the settings be?
post #3030 of 4262 Old 06-24-2014, 09:10 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 251
@SABERWOLF357
you can destroy your picture quality as much as you want with SVP but this is not a must have for HI DEF.
steelman1991 and Nevcairiel like this.
Reply Home Theater Computers
