Advanced MPC-HC Setup Guide - Page 104 - AVS Forum | Home Theater Discussions And Reviews
 140Likes
post #3091 of 4260 Old 07-14-2014, 03:54 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
DXVA runs on a ASIC so the GPU it self is not really working it's a extra chip on it.
but there are some AMD card that lose about 50 % of there power by using DXVA.
for some reason some AMD card stay in medium powerstate when DXVA is used so it a possibility. you can check this with GPU-Z. don't judge playback with open GPU-Z this tool tends to produces dropped frames when running.
DXVA scaling is very bad on AMD and NVIDIA...
mightyhuhn is offline
post #3092 of 4260 Old 07-14-2014, 04:15 PM
Makaveli6103's Avatar
Quoted: 20 Post(s)
Oh good to know. What would you recommend for my card then?
Makaveli6103 is offline
post #3093 of 4260 Old 07-14-2014, 05:00 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
this depends on what type of file you may play.
1440x1080x30i 60f 16/9 TV transportstream is pretty hard and totally normal...
i personally pref spline 3 AR you can try spline without AR and have a look at the rendertimes.
you may think about profiles to make sure 1080p doesn't use bilinear for chroma.
for 30 FPS you need lower rendertiems than: ~33 ms and for 60 fps: ~16 ms
post #3094 of 4260 Old 07-15-2014, 06:30 AM
Liked: 0
Originally Posted by SABERWOLF357 View Post
Thanx for the speedy reply
I was just thrown off by the description which it says in the thread heard "run the installer for it" "XySubFilter", which it's a batch download, but it does have a install.bat.
I did what you said... I created a folder in MPC-HC an named it "XySubFilter", ran the XySubFilter.bat, it installed with no problem.
I set XySubFilter too preferred
It looks like it's recognized in MPC-HC
So my question too you is, what is the clear advantage of using this filter? I see no difference between the way subs are loaded by default using MPC-HC compared too this filter?
Unless I am not using it (set it up) right?
Also... how do I disable subs from loading automatically in MPC-HC? I thought it was by unticking this box?
Thanx in advance
You think you can help me here mightyhuhn?
I don't know weather I appied or using it right?
What difference am I suppose to see?
SABERWOLF357 is offline
post #3095 of 4260 Old 07-15-2014, 07:27 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
try this test sample http://www.file-upload.net/download-...Space.mkv.html with ISR and xy subfilter.
it's a complicated topic about colorspaces and things like that and has to a lot to do how ASS subtitles are created.
xy subfilter is faster anyway.
post #3096 of 4260 Old 07-15-2014, 01:18 PM
Liked: 0
I got it now!
Thanx very much for the example!
very niffty tool! in deed!
post #3097 of 4260 Old 07-15-2014, 07:26 PM
Quoted: 20 Post(s)
I inputed spline 3 AR for chrome and image upscaling.
post #3098 of 4260 Old 07-15-2014, 09:37 PM
Pastuch's Avatar
Quoted: 40 Post(s)
Liked: 32
Running Catalyst 14.7 RC I'm getting INSANE dropped frames. Many per second. Doesn't seem to matter what MADVR settings are used. Hell, even the default MPC-HC setup drops frames. It's so bad I've been forced to used VLC for the first time in 5 years.
Anyone had any luck?
R9 290
Windows 8.1
MPC-HC 32bit
clean install of everything.
Uninstalled old copy of lav splitter and cleaned registry.
Pastuch is offline
post #3099 of 4260 Old 07-16-2014, 01:13 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
I don't see any problem. The behavior is close to 14.4 and 14.6 RC2. Did you clean the registry by AMD Clean Uninstall Utility (amdcleanuputility.exe v1.4.0.0)?
renethx is offline
post #3100 of 4260 Old 07-18-2014, 06:17 AM
Liked: 0
Nice tutorial But I am really surprised that this thread does not mention the use of SmoothVideo Project (SVP) running in contrast with MPC-HC
http://www.svp-team.com/
It turns MPC-HC into a Hi-Def player
No matter what setting you apply to MPC-HC, you are not really enjoying your movies unless you have (SVP) running in the background.
Thanx for this thread! I learned a lot
Any chance at posting some tweaks to enjoying my 3D movies with MPC-HC?
One more thing in regards too 3D movies, I've noticed that KMPlayer has a Scene Depth filter for it's player.
But it's a independent filter.
Would you know if there are any Scene Depth filters available for MPC-HC somewhere?
Still wold like to know if there are any 3D scene depth filters available for MPC-HC
Like other players have
If anyone knows plz! re-ply
post #3101 of 4260 Old 07-22-2014, 03:24 AM
Skylinestar's Avatar
Quoted: 1110 Post(s)
Liked: 198
On the first post, under the section "What you need to download", why is LAV filters not listed?
Does that mean the built-in filters are ok?
Skylinestar is online now
post #3102 of 4260 Old 07-22-2014, 05:18 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
build in filters in mpc-hc is lavfilter so they are ok.
post #3103 of 4260 Old 07-22-2014, 09:23 AM
Liked: 0
Need Help New on this
Hi
I wanted to check if anyone can help me with my settings.
I've installed CCCP and MDVR.
I run with HTPC Dual core 3.0GHz
Windows XP
Radeon HD6450 1GB DRR3
I have Epson TW 7200
and Yamaha HTR 4065
speaker 5.1
I plugged the HTPC HDMI -> Yamaha -> Epson.
What settings should I have on the MPC and MDVR.
I look only at 1080p movies size of the films around 15GB.
Thanks in advance
Abotiz is offline
post #3104 of 4260 Old 07-29-2014, 05:44 PM
Dropkick Murphy's Avatar
Quoted: 72 Post(s)
Liked: 89
I'm a noob with MPC-HC & MadVR and I thought I followed this guide pretty well but I'm having some trouble with really low quality DVD files (MKV). Everything I have has been ripped with MakeMKV. Blu-ray movies and most DVD's look great but some of my movies get pixelated really bad (see attached pic). I just don't know where to begin to try and correct this, any help would be appreciated.
System Info:
AsRock Z87M Pro4
Intel Core i5-4570
Asus R9 270
8 GB RAM 1600Mhz
Win 7 Pro 64 bit
MPC-HC 1.7.6
LAV Filters
madVR v0.87.10
I have tried the same files with VLC and they play without a problem (except for the massive tearing that led me to build this machine and try madVR in the first place).
Dropkick Murphy is offline
post #3105 of 4260 Old 07-29-2014, 05:45 PM
Quoted: 72 Post(s)
Liked: 89
Sorry, double post.
post #3106 of 4260 Old 07-30-2014, 12:43 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
disable DXVA and try again looks like a the hardware decoder can't handle the stream.
post #3107 of 4260 Old 07-31-2014, 06:09 AM
Quoted: 72 Post(s)
Liked: 89
Would I find that in the madVR settings, or the video card settings?
post #3108 of 4260 Old 07-31-2014, 06:20 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
look at the "Video Decoding" of this guide.
select none
Dropkick Murphy likes this.
post #3109 of 4260 Old 07-31-2014, 04:11 PM
Quoted: 72 Post(s)
Liked: 89
select none
Thank you very much, that was it.
post #3110 of 4260 Old 08-05-2014, 12:28 AM
devoz's Avatar
I have just upgraded to latest MPHC 1.7.6...and MadVR 0.87.10
I run Windows 7...32bit with Geforce 550Ti
My question is the MPHC external filters appearance I have normal?..ie should they be there in External Filters?
I thought they were internal?
When I do a right click in active MPHC ...the filters dont look right?
What is the File Source(Async)? and why is the LAV Splitter showing low merit?
ID:	197217   Click image for larger version
ID:	197225   Click image for larger version
devoz is offline
post #3111 of 4260 Old 08-05-2014, 04:01 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
[quote=devoz;26301985]My question is the MPHC external filters appearance I have normal?..ie should they be there in External Filters?
I thought they were internal?[quote]
you are using the internal mpc-hc filter in this case. it's working as intended so what external problem are you talking about.
When I do a right click in active MPHC ...the filters don't look right?
looks totally normal to me. looks like you have not installed a lavfilter(not needed with newer MPC-HC version) so it uses the internal. just leave the settings at default and everything is fine no need for changes.
this is a filter that loads to different file for playback looks like it loads an eternal subtitle file in this case. not sure i don't have your files can be audio or everything else too.
you deselected it for most cases so it falls back it. because it is disabled for the source you are playing right now it's shown as low merit.
i recommand you to reset the settings. i don't know about subtitles in your case. looks like you have installed a normal vsfilter not recommended by me. you set the internal lavfilter as external filter for what ever reason and even a avi filter what ever that is. and the filter without name is even more strange.
most of your settings are unneeded and even ignore.
post #3112 of 4260 Old 08-05-2014, 07:37 AM
devoz's Avatar
[quote=mightyhuhn;26303409][quote=devoz;26301985]My question is the MPHC external filters appearance I have normal?..ie should they be there in External Filters?
Yes... so I installed MPHC latest version...which includes the LAV filters built in
so as far as the Subtitle filter I have to check and make sure its the correct one
it was setup using only the info provided by this guide.
Subtitles are displaying perfectly ...
So I am asking why if LAV filters are the internal ones ...they are showing up
as External ones...is it possible
I have remnants of old LAV filters left over
(I always uninstalled when using separate LAV Filters..ie before they were incorporated into MPHC)
Its why I included the screen captures of my MPHC setup...so you can see
This is the Subfilter being used when playing Movie(see picture)
devoz is offline
post #3113 of 4260 Old 08-05-2014, 07:52 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
the external filters are used to force a high merit to be blocked or a low merit filter to be used/set higher.
at the moment you load a lavfilter(most likely the internal) as external filter. i don't know why you did this you have to tell me that.
in the end MPC-HC will use any filter it can use without settings this up.
reset the settings and choice madVR and everything should be fine. about subtitle follow the guide.
devoz likes this.
post #3114 of 4260 Old 08-05-2014, 08:08 AM
devoz's Avatar
I think when I installed the new version it has picked up the old settings
which included when I was using Externally installed LAV Filters
(ie version of MPHC before LAV Filters were made internal)
So I took your suggestion removed the External filters from the list
and Reset...MPHC.
Now my filters look better when playing a Movie
see pic below
Still not sure about Subtitles though...
devoz is offline
post #3115 of 4260 Old 08-05-2014, 08:34 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
for ASS subtitles xy vsfilter or xy subfilter are the most accurate and fastest one but they are buggy with PGS subs from BD sometimes.
the internal subtitle filter from MPC-HC doesn't have problems with dvd/BD subs at all.
post #3116 of 4260 Old 08-05-2014, 08:34 AM
gerall's Avatar
Quoted: 50 Post(s)
MPC was working fine - now will not play dvds from computer's drive and freezes and displays error message for 1/2 of mkv files. Reinstalled player - same thing. Using Gateway 6803-35, 2.8 GHz Intel Core i7-930 processor, ATI radeon HD 5850, 9GB DDR3 RAM. WMP works fine, but I can't seem to get the dts dll file to work with WMP - blu ray files with dts ma play with core audio. Using 32 bit version, computer is 64 bit. Had same problems with 64 bit version. Not using MAD VR. Any help would be greatly appreciated - either to fix problem with mpc or suggestions for another player or how to get the dts file to work with wmp. thank you.
gerall is offline
post #3117 of 4260 Old 08-05-2014, 08:50 AM
devoz's Avatar
As shown below...and checked with info from first page..this is the one I have installed
So are saying the internal subfilter can be better in some circumstances than the one recommended
on First page...ie xy subfilter...beta??
devoz is offline
post #3118 of 4260 Old 08-05-2014, 09:03 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
yes, but it is terrible at ASS subs compared to this one.
post #3119 of 4260 Old 08-05-2014, 09:19 AM
devoz's Avatar
Okay ...good ...then I will stick with my current setup then
MPHC etc all seems to be fixed now...Thanks for your help
devoz is offline
post #3120 of 4260 Old 08-06-2014, 03:23 PM
gerall's Avatar
Quoted: 50 Post(s)
Any help would be appreciated. mpc still crashing. can't seem to get dts dll to work with wmp....thanks!
gerall is offline
Reply Home Theater Computers
