Advanced MPC-HC Setup Guide - Page 109 - AVS Forum | Home Theater Discussions And Reviews
 140Likes
post #3241 of 4260 Old 12-04-2014, 01:47 PM
Quoted: 18 Post(s)
Liked: 1
Originally Posted by mightyhuhn View Post
doesn't have any effect. because it is never used with madVR.
see this guide at:
MadVR Config
I got this sample, in 4K
its total slideshow, 100% cpu usage, why is that? format is MPEG-TS..48 megabits...
dazed81 is offline
post #3242 of 4260 Old 12-04-2014, 06:37 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
Originally Posted by jhughy2010 View Post
Are you sure? Recently I played a "re encoded" HEVC movie (granted 1080p) utilizing MPC-HC and it didn't even bother my i7. Why would UHD make that much of a difference?
you can play a astra UHD 50 FPS 18 mbit stream with a i7 but thanks to the 64 bit version this is not possible or at least a lot harder with the 32 bit version we are using here in this thread.
so it's not that simple. but 18 mbit is a lot less than a blu ray uses for 1080p right now.
high quality UHD will run at atleast 25-50 mbit and i'm pretty sure my i7 is not up to that task.
of cause a i7 can play a UHD HEVC clip with 8 or lower mbit with no problem what so ever.
I said a i7 can't play high quality UHD HEVC. let's change this to: an i7 can't play a high quality UHD HEVC video with more than ~25 mbit. I'm not even sure the 32 bit version of lavfilter can do 15 mbit UHD HEVC. and lavfilter is pretty fast in HEVC decoding.
mightyhuhn is offline
post #3243 of 4260 Old 12-04-2014, 06:49 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
https://www.youtube.com/watch?v=5Na9F4UbrVc
the linked youtube file is a maximum 1080p AVC file at about 4.3 mbit nothing special.
the MPEG.TS is a container usually used for TV transportstreams (TS) you can add easily HEVC to the m2ts version of this container not sure about the normal TS version playing 48 mbit HEVC is an most likely not possible with current hardware. the 48 mbit could be everything from HEVC to mpeg2. the version of youtube is not 48 mbit.
dazed81 likes this.
post #3244 of 4260 Old 12-04-2014, 09:41 PM
jhughy2010's Avatar
Quoted: 846 Post(s)
Liked: 276
I'm sorry mightyhuhn but I'm having a hard time understanding what you are saying.
Your first sentence contradicts itself (maybe edit your response).
Your second sentence says that an i7 (which I'm assuming your talking about Haswell) cannot handle 25-50 Mbps?
In the last second I cannot discern anything you are saying (maybe really edit this response). Sorry
jhughy2010 is offline
post #3245 of 4260 Old 12-05-2014, 01:06 AM
Quoted: 18 Post(s)
Liked: 1
I posted that video just to show what it is....i got 4K version of it in the format i stated on my pc, is it possible with some tweak to play it without total lag?
dazed81 is offline
post #3246 of 4260 Old 12-05-2014, 05:08 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
MPEG-TS didn't say what codec is used. if it is HEVC forget with your CPU. it it is AVC it should work.
I just make it totally simple. it's not a good idea that I try to write something complicated.
a 3830x2160 HEVC 24 FPS file with 100 mbit is a huge problem for a CPU.
a 3840x2160 HEVC 24 FPS file with 2 mbit is easy to decode.
there could be a simple to decode 80 mbit file to because encoding settings play a big rule too.
in the future 20 mbit and a lot more will be used for TV broadcast and for the new 4K BD. and that's still a problem for a high end CPU's.
you can read this thread to get an idea.
http://forum.doom9.org/showthread.php?t=171219
post #3247 of 4260 Old 12-05-2014, 08:30 AM
jhughy2010's Avatar
Quoted: 846 Post(s)
Liked: 276
Hmm ok. Still hard to understand. I'll take a look at that thread.
So far, HEVC seems to be promising. Playback of a re-encoded blu ray movie via MPC-HC is rock solid. HEVC allows for a drastically smaller file size over H.264 which is great for storage on a nimble external hard drive. I am wondering how much more efficient transcoding will be with HEVC. I'm tempted to experiment around with it, however, my i5 (server) does a fine job at transcoding on the fly.
post #3248 of 4260 Old 12-05-2014, 03:26 PM
Quoted: 18 Post(s)
Liked: 1
Can't be offloaded to the GPU?
dazed81 is offline
post #3249 of 4260 Old 12-06-2014, 06:29 PM
Moritzio's Avatar
Can I adjust embedded PGS subtitles to make them smaller? None of the settings seems to affect playback in either M2TS or MKV files. Specifically, I want to make them smaller and lower in the frame or full screen mode.
If not, can I scale an external SUP file?
I am aware how to convert them, but I want to save time because I am not saving the files after viewing.
Moritzio is offline
post #3250 of 4260 Old 12-06-2014, 07:58 PM
thu
thu's Avatar
I put in a new R9-270 today with a fresh of install of Windows 7 so I could try out Mindbomb's guide with all the upper settings in MPC-HC and MadVR.
It it mostly working, but I think I've run into a problem with MadVR and auto refresh rate switching.
The videos that are 23.976 switch the tv to 23.976 and there are no dropped frames.
Some of the videos I play says "movie 29.970 fps" but MadVR switches the tv to "display 23.976". Then these videos drop frames like crazy.
And the weird thing is I saw at least one or two "movie 29.970 fps" were switched to "display 59.93 and those played with no dropped frames.
My tv's available resolutions and the MadVR switching settings I'm using are attached along with some examples.
So everything seems to be fine except the cases of 29.97 movie rate running at 23.96 display rate. How do I get MadVR to swith to 59.93 for those?
Is there an option somewhere in MPC or MadVR that I may have missed that would cause this?
ID:	406306   Click image for larger version
ID:	406314   Click image for larger version
Name:	madvr settings.PNG
thu is offline
post #3251 of 4260 Old 12-06-2014, 09:35 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
don't use interlaced mode for display mode. to get this working properly you need to disable deinterlacing not a good idea.
you use madVR force film mode on a file that is not 3:2 (film in interlaced) this simple doesn't work.
@dazed81
there is no real 100% hardware HEVC DXVA so no chance.
dazed81 likes this.
post #3252 of 4260 Old 12-07-2014, 12:47 AM
thu
thu's Avatar
Thanks mightyhuhn. I think you fixed it.
I UNchecked "disable automatic source type detection" "force film mode" and then replayed the same files as in the examples I posted. They both now show "movie 29.97" and "display 59.97" with no dropped frames.
So it looks like it was that setting that was messing everything up. The guide said to check that setting because it wasn't working right when the guide was made. Maybe it is working now? Hard to say for sure with only a couple of test files. But so far so good.
thu is offline
post #3253 of 4260 Old 12-10-2014, 03:45 AM
Liked: 0
I have a problem with the settings listed here in "Display Modes" (about refresh rate).
I've configured everything properly, but when I play a video on my Samsung tv (1920x1080 @60) the refresh changes like it should and the resolution doesn't, but actually the image on the screen goes a little out of the tv, and closing MPC put everything back to normal.
What can I do?
a8213711 is offline
post #3254 of 4260 Old 12-10-2014, 09:28 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
first of all you should never change the resolution. all current display device have a native resolution and this resolution should be use.
there is a problem with your TV.
for some reason the over scan from your TV actives.
if you use PC mode you can easily get in huge problem with samsung. most samsung only support PC mode with 60 hz leaving 60 Hz can create a bunch of problems.
a8213711 likes this.
post #3255 of 4260 Old 12-10-2014, 10:11 AM
Liked: 0
I don't want to change the resolution, neither the tv report it different than when MPC is closed, still there is this annoyance!
What is this 'PC mode' and how can I disable it?
Thank you.
EDIT:
Ok, I found out that I have renamed my HDMI to PC and that enabled it, but I also read that disable it takes some downside (I don't remember why I enabled it in the first place), so the question is how should I set my pc/tv? (I never play games on it, if that helps, also I wouldn't want to rely too much on 'Smooth Motion' since I have a low budget laptop)
a8213711 is offline
post #3256 of 4260 Old 12-10-2014, 11:03 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
sorry no way to really help you all settings depends on how your TV behavior, your GPU and what you like to achieve.
post #3257 of 4260 Old 12-10-2014, 12:33 PM
Roussi's Avatar
Quoted: 46 Post(s)
Liked: 36
What can I do?
Adjust the overscan while switched to the refresh rate that is problematic (e.g. change the refresh rate to 24 Hz, fix the overscan, change back to 60 Hz). The overscan setting should be retained next time it auto swithes to 24 Hz.
Roussi is offline
post #3258 of 4260 Old 12-11-2014, 03:30 AM
Liked: 0
Thank you, I think I solved!
There is "Screen Fit" on picture option on my Samsung which seems to be remembered, and it solves the problem. (although I still haven't tried with more refresh than 60 and 24)
a8213711 is offline
post #3259 of 4260 Old 12-12-2014, 03:16 AM
Liked: 0
Actually I have another problem: my tv doesn't set the appropriate refresh rate (25Hz) even if supports it (from
Spoiler!
I tried 2 files with 25fps (as seen in tag 'says source filter' in MPC) and:
- the first put the tag Display on 59.94, infact the tv goes on 59Hz
- the second shows Display on 50, tv on 50Hz.
In MadVR I wrote 1080p25, then why the refresh isn't set at 25?
a8213711 is offline
post #3260 of 4260 Old 12-12-2014, 03:18 PM
MattAlex151's Avatar
Hey everyone, I'm having some crackling / lipsync issues with MPC-HC/madVR/Reclock and was hoping to get a few more eyes on my thread. Thanks!
avsforum.com/forum/26-home-theater-computers/1803322-lip-sync-crackling-w-mpc-hc-madvr-reclock.html
MattAlex151 is offline
post #3261 of 4260 Old 12-13-2014, 02:31 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
Spoiler!
is there any 25 hz source out there? isn't everything 50i with pal? or with other words if the source is interlaced it is 50 fps after deinterlacing.
post #3262 of 4260 Old 12-15-2014, 04:01 AM
Liked: 0
Sorry mightyhuhn, I can't understand what you're saying.
I have in MadVR
Spoiler!
and I tryied with 2 different files (disabled smooth motion meanwhile, but before doing it, it was still the same):
Spoiler!
Spoiler!
in control panel there are:
Spoiler!
Spoiler!
The last 2 pictures don't say respectively that my TV and my GPU are capable of 25Hz?
a8213711 is offline
post #3263 of 4260 Old 12-15-2014, 08:24 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
in this post 50 hz was not listed:
you have tried 2 file one is 25i (better know as 50i) and one is 25p. the 25i file should switch 60 hz because your Tv didn't reported 50p in this screen.
but with the new screens it should work....
post #3264 of 4260 Old 12-16-2014, 04:11 AM
Liked: 0
In that post the image is taken from OP; in the later post the 2 images are from my pc, so you say it should work at 25, but it doesn't..any tips?
Also how do you see if they are at 25p or 25i?
a8213711 is offline
post #3265 of 4260 Old 12-18-2014, 12:44 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
The force film mode deinterlacing will convert things to 23.976 fps. The reason to do this is that hdtv broadcasts and dvd doesn't support 23.976 fps, they only support 29.97 fps, so video fps will be upped to work in those mediums. When you use film mode deinterlacing, you change it back to the native form.
Some things are actually 59 fps when they are in the form of 29.97i. You sorta have to use your best judgement on what the original fps was. Anything going for a cinematic look will most likely be 23.976 fps. Sports, reality shows, talk shows, that's usually 59 fps.
That explains your second picture, but the first one is still 23.976 hz even without deinterlacing. Idk, maybe there was some mistake in making that video where it was given the wrong fps?
MlNDBOMB is offline
post #3266 of 4260 Old 12-18-2014, 11:38 PM
thu
thu's Avatar
Thanks for the explanation MINDBOMB. I understand about different sources using different frame rates, but I get confused when to use what setting on which files. And then there is the 3:2 pulldown and stuff like that that I still don't really understand.
Luckily using "automatic source type detection" and not "force film mode" has been working so far.
Most of my stuff is old SD shows and movies from who knows where as well as a lot of SD Tivoed material and to a lesser degree DVD & Bluray rips. So maybe that makes it easy for MPC-HC to figure out what to do.
And thank you for the great guide. Got everything set up now with the top settings in madVR and everything looks and sounds great.
Quick question. Does madVR play nice with SVP or is it one or the other?
I've been a little afraid to try it because I didn't want to mess up madVR. But after seeing I'm getting 10-20ms frame rendering times, I'm really tempted to try it for anime. If I understand it correctly, I just need to keep those rendering times below the movie frame interval.
thu is offline
post #3267 of 4260 Old 12-19-2014, 04:31 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
madVR works with SVP.
SVP needs 2.5 times as much GPU as a 24 fps source so you need rendertimes of lower than 16 ms while doing 2.5 times the normal 24 fps work.
I personally think frame interpolation is a very bad thing and SVP does a very bad job on anime. not sure if any interpolation is better than SVP but this is what I saw when I tested it.
post #3268 of 4260 Old 12-19-2014, 08:47 AM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
afaik, there is no automatic source detection atm. It will always assume it is video (59 fps) rather than film (23.976 fps). I believe it's on the to-do list for madvr to have something that automaticallly determines film vs video, but tbh, how prevalent are interlaced videos nowadays anyway.
MlNDBOMB is offline
post #3269 of 4260 Old 12-19-2014, 11:48 PM
thu
thu's Avatar
@mightyhuhn - I was thinking about trying SVP just to smooth out the panning scenes in anime. I think you might be right though that it isn't worth it. I looked around a little today to see what people thought about it. Some of course liked it and some didn't, but the ones "in the know" seem not to like it. Plus, I only have an i3, so I wouldn't be able to crank up the settings very much anyway. So I'll just keep madVR settings high and live with the occasional jerky pans.
@MiND bom - Gotcha. Now that I think about it, I just reinstalled everything like 2 weeks ago and haven't tried out a wide range of videos yet. I'll try some real movies and see what happens. At least I know the setting to use now if the movies aren't playing right.
I think I saw something about profiles in MPC-HC. Maybe that is what I need to handle the different sources.
thu is offline
post #3270 of 4260 Old 01-03-2015, 08:32 AM
Gurba's Avatar
Quoted: 399 Post(s)
Liked: 193
The setup guide in the first post doesn't match newer Versions of some of the apps but otherwise it's great.
jhughy2010 likes this.
Gurba is offline
Reply Home Theater Computers
