Advanced MPC-HC Setup Guide - Page 112 - AVS Forum | Home Theater Discussions And Reviews
 139Likes
post #3331 of 4248 Old 03-10-2015, 09:52 AM
Liked: 0
I can't cycle through XySubFilter subs with keyboard. Is there even a way?
a8213711 is offline
post #3332 of 4248 Old 03-10-2015, 01:59 PM
Liked: 0
Hello to all
I have one question
While i choose at options-->output-->Directshow video-->Madvr when i start play something at right click ,filters dont show me madvr to choose.
Has anybody idea why this happening?
Thanks in advance.
Droper88 is offline
post #3333 of 4248 Old 03-10-2015, 03:17 PM
Onkyoman's Avatar
Quoted: 144 Post(s)
Liked: 63
Yes, "Next Subtitle" should do this. If it doesn't, something is at fault with your LAV Splitter settings or subtitle settings in MPC.
Onkyoman is offline
post #3334 of 4248 Old 03-11-2015, 09:59 AM
Liked: 0
Are you sure?
"Next subtitle" is the one in Keys with ID=954? Because that doesn't work for me.
I followed the guide so there shouldn't be any problem with my config, also isn't that shortcut for the MPC-HC subs render which I disabled?
a8213711 is offline
post #3335 of 4248 Old 03-11-2015, 10:38 AM
Scott231's Avatar
Time to build another HTPC to tap into my home network and connect to projector. Thought I would simply throw the $4 to ReneTHX for the latest Guide. What do I get? The same edition I used to build my first HTPC back in 2011, Weak!!
Scott231 is offline
post #3336 of 4248 Old 03-12-2015, 03:59 AM
BlueChris's Avatar
Quoted: 210 Post(s)
Liked: 86
Guys i want your expertise. Atm i upscaling everything with madvr to 2160p and im on my limit with my 970 so question is if i force madvr to upscale to 50 or 60p will be better as matter the motion? Keep in mind that i am a fan of crisp image and that's why in my 55ub950v i use the truemotion setting.
BlueChris is offline
post #3337 of 4248 Old 03-13-2015, 08:02 AM
BlueChris's Avatar
Quoted: 210 Post(s)
Liked: 86
I tried it and i didn't saw to much difference.
post #3338 of 4248 Old 03-13-2015, 11:42 AM
mightyhuhn's Avatar
Quoted: 732 Post(s)
Liked: 250
how to upscale refreshrates what are you doing?
mightyhuhn is offline
post #3339 of 4248 Old 03-13-2015, 11:47 AM
mightyhuhn's Avatar
Quoted: 732 Post(s)
Liked: 250
works fine for me pressing S using MPC-HC.
Originally Posted by Droper88 View Post
Hello to all
I have one question
Thanks in advance.
what software do you use ?
madVr doesn't work with 64 bit mpc-hc.
post #3340 of 4248 Old 03-13-2015, 04:08 PM
BlueChris's Avatar
Quoted: 210 Post(s)
Liked: 86
I just set in madvr monitor refresh rates only 2160p50 or 2160p60 and everything that madvr plays is going to this refresh but i dont know if madvr has the ability to create frames so maybe this is useless.
post #3341 of 4248 Old 03-13-2015, 05:05 PM
mightyhuhn's Avatar
Quoted: 732 Post(s)
Liked: 250
it will repeat frame/drop frames to match the output refreshrate and with smoothmotion it will blend them. so it does nothing useful for your TV settings.
post #3342 of 4248 Old 03-13-2015, 06:52 PM
BlueChris's Avatar
Quoted: 210 Post(s)
Liked: 86
Thx ... btw if i enable smooth motion i see trails in image... is this normal? I don't like it at all so is off for me.
post #3343 of 4248 Old 03-14-2015, 03:24 AM
mightyhuhn's Avatar
Quoted: 732 Post(s)
Liked: 250
madVR SM and motion interpolation is not a good idea.
you could see all types of issue with your motion interpolation. i highly recommend not to use it together.
the aim of madVR SM is to show the video in it's intended way. so a 24 hz movie on a 60 hz screen still looks like a 24 hz movie.
without motion interpolation the picture may looks a bit more blurry or you may see ghost.
post #3344 of 4248 Old 03-14-2015, 10:59 AM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
the S key should do it. If there are a lot of subtitles, it may be easier to just manually pick one then scroll through all of them.
i agree with mightyhuhn in that you can't use motion interpolation on your tv with smooth motion in madvr. Let me add that if your tv has these features, then you probably have a 24hz refresh rate available to you as well, so use that. Smooth motion should automatically turn itself off if the frame rate and refresh rate match or if the refresh rate is a multiple of the frame rate.
MlNDBOMB is offline
post #3345 of 4248 Old 03-14-2015, 01:34 PM
BlueChris's Avatar
Quoted: 210 Post(s)
Liked: 86
Thx guys i thought when i enabled sm in a 24hz movie and playing it in native 24hz that was something like the truemotion setting that the tv has which is in specific to add intermitiate frames to make the image smoother in fast scene movements but as i see is not the case here so i play everything in its native mode and im happy.
post #3346 of 4248 Old 03-16-2015, 08:54 AM
Liked: 0
When I save a screenshot with the built-in function in MPC-HC it is saved with the resolution of the file and not of the (bigger) output, is this normal? If not, where could be the problem between MPC-HC and madVR (both are updated)?
Also to those saying that pressing S will cycle through XySubFilter subs: are you sure you don't have in playback autoload subtitles checked?
a8213711 is offline
post #3347 of 4248 Old 03-16-2015, 09:56 AM
mightyhuhn's Avatar
Quoted: 732 Post(s)
Liked: 250
that's normal
i don't see an option like this under playback. i'm using mpc-hc 1.7.8.95
post #3348 of 4248 Old 03-17-2015, 06:24 PM
evil.'s Avatar
Liked: 0
Sorry if I'm being slightly off topic;
Do you guys prefer to demux/remux the BDMV/.m2ts into a .mkv, or just watch the .m2ts?
Also, do I lose any quality by performing any of the above?
And finally, do you use LAV splitters to select the audio stream/subs etc. you want for your movies (Filters -> LAV Splitter -> ...), or you remux the full package into a new one , leaving only the audio stream you need? Some people say, MPC-HC can get buggy if you change streams on-the-fly?
Oh and yes, what's the usual audio bitrate a Blu-ray usually offers? ~1509kbps?
evil. is offline
post #3349 of 4248 Old 03-18-2015, 06:10 AM
mightyhuhn's Avatar
Quoted: 732 Post(s)
Liked: 250
i personally highly prefer MKV i usually don't care about menus and stuff like this. i always reencode pcm to flac which is 100% lossless.
a simple remux is lossless.
yes I use lavfilter to select the audio and subtitle stream.
i can't remember any problems when switching the audio stream on the fly.
but you have to know what you need and what not.
if you encounter some issue feel free to report them:
http://forum.doom9.org/showthread.php?t=166689
depends on codec, channel, bit deep and khz.
1536000 bit per (~1500kbit) sec is 16 bit 48 khz stereo LPCM.
dd trueHD and dts hd ma are both lossless codecs and don't have a fixed size.
5.1 24 bit 48khz can easily have over 7000 kbit. LPCM can reach up to 27.648 Mbit/s.
i know that japanese anime BDs usually use 24 bit 2 channel LPCM which is about 2450 kbit.
but i'm sure hollywood movies use more because they are usually 5.1 or 7.1
so there is no general answer to this.
post #3350 of 4248 Old 03-18-2015, 06:37 AM
evil.'s Avatar
Liked: 0
Exclamation
That's interesting. I really haven't watched a movie above ~1500kbps. Or do I have to decompress the audio somehow? Or is MediaInfo not reliable/trustworthy?
evil. is offline
post #3351 of 4248 Old 03-18-2015, 06:48 AM
mightyhuhn's Avatar
Quoted: 732 Post(s)
Liked: 250
you may need to look more closely. you may have looked at a DTS core not the DTS HD MA stream.
or you may haven't muxed the HD track at all and only the default core AC3 or DTS strack.
and don't forget lavfilter can't decode DTS HD MA on is own yet just look at the guide in this thread.
post #3352 of 4248 Old 03-18-2015, 10:12 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
I just rip/remux the main title with the preferred audio into a single .m2ts file.
JDLIVE is offline
post #3353 of 4248 Old 03-18-2015, 01:57 PM
evil.'s Avatar
Liked: 0
Why not a .mkv? Or you just don't want the extra steps
evil. is offline
post #3354 of 4248 Old 03-18-2015, 02:32 PM
BlueChris's Avatar
Quoted: 210 Post(s)
Liked: 86
M2ts are fine for me also no need extra steps ... also my samsung bd player is happy to play 3d m2ts files ripped from original blurays so thats a perfect container for second reason for me.
post #3355 of 4248 Old 03-19-2015, 10:37 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
No real reason, sometimes the main film is just a single .m2ts file and I just copy it instead since stripping out an audio channel doesn't really save that much space. I also used to own a Popcorn Hour streaming device that could play an m2ts file just fine but would choke on mkv files, so that's probably part of it, too.
JDLIVE is offline
post #3356 of 4248 Old 03-23-2015, 06:33 AM
Brian Hampton's Avatar
Quoted: 572 Post(s)
Liked: 302
Edit - Setup MPC HC as external player but had a problem with it finding my movies. I knew that I had to re-define the "path" to my videos so that MPC HC would know where to look so I guess I've soved the problem I had so nevermind.
-Brian
Brian Hampton is offline
post #3357 of 4248 Old 03-26-2015, 06:24 AM
Liked: 0
Hey,
Is dtsdecoderdll.dll necessary if your PC is plugged directly into an amplifier with DTS-HD support? I'll add that there's no soundcard; it goes PC -> amplifier -> amplifier out -> tv all via HDMI cables.
kseniasolo is offline
post #3358 of 4248 Old 03-26-2015, 06:38 AM
steelman1991's Avatar
Quoted: 216 Post(s)
Liked: 117
Providing your CPU has the ability to pass DTS-HD - then no its not needed.
steelman1991 is online now
post #3359 of 4248 Old 03-26-2015, 08:06 AM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
That is true, but also, the newer lav audio builds can decode dts-hd with no external files now. I'll be updating the guide soon, I think when it makes it's way into the latest stable mpc hc.
MlNDBOMB is offline
post #3360 of 4248 Old 03-26-2015, 09:31 AM
Quoted: 216 Post(s)
Liked: 117
Knew it was being worked on - didn't realise Henrik had been successful brilliant.
Reply Home Theater Computers
