Advanced MPC-HC Setup Guide - Page 114 - AVS | Home Theater Discussions And Reviews
 32Likes
post #3391 of 3399 Old 04-24-2015, 06:36 PM
ColdsnapBryan's Avatar
Quoted: 39 Post(s)
Originally Posted by mightyhuhn View Post
you just don't have to decode the stream on your PC that's it. but you lose volume control on your PC.
Thank you, one last question. On the dynamic range compression what does the 1% - 100% option actually mean? Default is 100% and that's where I leave it at.
ColdsnapBryan is offline
post #3392 of 3399 Old 04-25-2015, 06:06 AM
mightyhuhn's Avatar
Quoted: 464 Post(s)
Liked: 150
i know what DRC is but i don't know where you got that option from.
mightyhuhn is online now
post #3393 of 3399 Old 04-27-2015, 07:49 AM
hifiaudio2's Avatar
Quoted: 230 Post(s)
Liked: 79
I am having an issue with dropped frames on both video (29 and 30fps) and 23.976 MKV blu ray playback. Mostly 1080p (some video is camcorder 1440 x 1080p) and a little 4k / 30p from a newer camcorder. All drops frames, and it is much worse in fullscreen mode. I have recently installed the 64 bit version of LAV, MPC-HC, and madVR. I have a core i7 at 4.5 ghz overclocked and GTX 980.
I have madVr set to use NNedi3 16 neurons chroma upscaling, 32 neurons Luma doubling, Jinc 8 taps AR / LL image upscaling, and Lanczos 8 taps downscaling. Outputting to a Dell 2560x1600 30" monitor.
Some of the vids drop a LOT of frames.. 20-30 per second(even though it tells me it should drop one ever 20 seconds or so). My cpu utilization is around 17-20% for MPC. Software renderer selected in LAV.
Messing with most of the settings I just mentioned, including using the minimum Neurons, or moving to the "lower" tier of options in each field, did not seem to reduce the dropped frames. Smooth motion on or off also did not seem to fix anything.
hifiaudio2 is offline
post #3394 of 3399 Old 04-27-2015, 01:45 PM
Onkyoman's Avatar
Are you going over the rendering queue? If so, you need to reduce your settings.
Onkyoman is offline
post #3395 of 3399 Old 04-27-2015, 02:42 PM
hifiaudio2's Avatar
Quoted: 230 Post(s)
Liked: 79
Which readout tells me the rendering queue? But also like I said, reducing the settings a great deal, turning off luma doubling, moving down to Jinc, etc, did not result in less dropped frames. And my HTPC horsepower should be more than sufficient for what I was trying, let alone the reduced settings. Is there another possibility for settings that affect the drops?
post #3396 of 3399 Old 04-27-2015, 10:01 PM
mightyhuhn's Avatar
Quoted: 464 Post(s)
Liked: 150
do you have a sample from your camcorder?
can you make a screen from the OSD?
and why would someone use something terrible like jinc 8?
post #3397 of 3399 Old 04-28-2015, 04:20 PM
tanwn1's Avatar
Quoted: 31 Post(s)
if i have multiple clips of 4k content recorded from a videocam, how can i play all the clips seamlessly without any pause (black out) in between? thanks.
tanwn1 is offline
post #3398 of 3399 Old Yesterday, 11:10 PM
Liked: 0
No Video just Audio on some MKVs
Hi,
I followed this guide and it works great most of the time.
For some reason I get only audio and no video on some MKV files, any ideas why?
Should the internal filters of MPC-HC be all disabled?
Clonimus74 is offline
post #3399 of 3399 Old Today, 12:22 AM
steelman1991's Avatar
Quoted: 56 Post(s)
Liked: 83
For those who DO NOT bitstream and prefer audio to be decoded in the PC, there is now no need for the dtsdecoderdll.dll to decode DTS-HD audio streams. LAV Audio filters are now capable of decoding DTS-HD streams.
steelman1991 is online now
Reply Home Theater Computers
