Advanced MPC-HC Setup Guide - Page 118 - AVS Forum | Home Theater Discussions And Reviews
 141Likes
post #3511 of 4296 Old 07-04-2015, 06:23 AM
Skylinestar's Avatar
Quoted: 1160 Post(s)
Liked: 209
Originally Posted by mightyhuhn View Post
are you sure both videos have the same frame rate?
you can post a screen from the OSD (control+j) if you like.
The video lag & aliasing with increasing "presentation glitches" only occurred in window mode. Once I run the video in fullscreen, everything is perfect (presentation glitches=0).
Skylinestar is offline
post #3512 of 4296 Old 07-04-2015, 06:28 AM
Liked: 209
What's the best setting for "image doubling"?
super-xbr sharpness 100? neuron with biggest number?
post #3513 of 4296 Old 07-04-2015, 01:17 PM
mightyhuhn's Avatar
Quoted: 750 Post(s)
Liked: 256
nnedi3 is better with more neuron unlike other scaler higher is better in this case.
some people don't like nnedi3 in general so the best is what looks best to your eyes.
mightyhuhn is offline
post #3514 of 4296 Old 07-05-2015, 12:20 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
technically nnedi3 with the highest neuron number. But the performance is very low and it doesn't work well on AMD hardware. Super xbr sharpness is basically preference, seems like a lot of ppl like the 100 value.
jhughy2010 likes this.
MlNDBOMB is offline
post #3515 of 4296 Old 07-08-2015, 12:38 AM
bran82's Avatar
Quoted: 18 Post(s)
Hi guys,
I'm using latest madVR and MPC-HC. Playing more or less only 720p/1080p videos (no anime) on my 3440*1440 screen.
I do however feel I ain't getting as much sharpness as I want? Using nnedi3 (used for 1.5x and above) 128 neurons and jinc atm.
What would your suggestion be for the scenario above? Graphics card is 980 GTX Ti, so there is some grunt available.
bran82 is offline
post #3516 of 4296 Old 07-08-2015, 07:02 AM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
check if nnedi3 is actually being used with ctrl+j. you might have to go down to 1.2x scaling factor for 1080p videos, depending on aspect ratio. You can try lanczos 4 with antiringing if you want more sharpness than jinc, but it has more aliasing too. And you can try super xbr with maximum sharpness too instead of nnedi3.
MlNDBOMB is offline
post #3517 of 4296 Old 07-09-2015, 02:41 PM
gerall's Avatar
Quoted: 50 Post(s)
I use mpc hc - is it possible to play Blu-ray discs and what is the most trouble free way to do this? I used make mkv but would like to just pop in a disc and play it like a dvd. Thank you
gerall is offline
post #3518 of 4296 Old 07-09-2015, 08:01 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
MPC-HC doesn't decode BD. You'll need something like PowerDVD or Total Media Theater.
jhughy2010 is offline
post #3519 of 4296 Old 07-10-2015, 03:44 AM
Postmoderndesign's Avatar
Quoted: 278 Post(s)
Liked: 113
MPC-HC will play blu ray discs if you have Sly Soft's decrypter AnyDVD HD
Postmoderndesign is online now
post #3520 of 4296 Old 07-10-2015, 08:43 AM
gerall's Avatar
Quoted: 50 Post(s)
Thank you. Does this require an internet connection to play blu-rays?
gerall is offline
post #3521 of 4296 Old 07-10-2015, 08:58 AM
Quoted: 278 Post(s)
Liked: 113
You will need to purchase AnyDVD. I got a lifetime license quite a number of years ago. AnyDVD is regularly updated via the internet but the software resides on your computer. I believe the decryption takes place on your computer and not over the internet.
post #3522 of 4296 Old 07-10-2015, 10:31 AM
gerall's Avatar
Quoted: 50 Post(s)
Thank you very much. So all I do is download and install and it works perfectly with MPC HC - just play the Blu-ray like any other DVD?
gerall is offline
post #3523 of 4296 Old 07-10-2015, 12:34 PM
Quoted: 278 Post(s)
Liked: 113
Yes, anyDVD HD stays resident and will automatically scan discs and remove encryption when inserted into you optical drive. The scanning process will show on your monitor. When the scanning finishes you can go to Files in MPC-HC and open disk.
Extra Benefit that you did not ask about: Also, you may install virtual CloneDrive a free program from Slysoft.com if you also want to play files you have ripped to .iso. Install Virtual CloneDrive and assign a drive letter and play .iso files. MPC.HC will locate your movie as a disc on that virtual drive.
post #3524 of 4296 Old 07-14-2015, 11:13 AM
Quoted: 47 Post(s)
Liked: 37
Menus will not work. It just plays the main title. I think it gives you the option of selecting another title on the disk, I have not used that.
Roussi is online now
post #3525 of 4296 Old 07-15-2015, 07:19 AM
Quoted: 278 Post(s)
Liked: 113
Yes, MPC-HC just plays the main title. Some people like that. If you don't try PowerDVD to get menus which I find helpful on discs which contain a number of TV episodes.
post #3526 of 4296 Old 07-20-2015, 03:16 PM
gerall's Avatar
Quoted: 50 Post(s)
Thank you. Are there any quality or usability differences between powerdvd or mpc-hc with any dvd hd for Blu-ray playback?
gerall is offline
post #3527 of 4296 Old 07-20-2015, 04:16 PM
Quoted: 278 Post(s)
Liked: 113
For Blu-ray on a 1080 display they look and sound the same to me. For DVD I prefer MPC-HC but then I have an older version of PowerDVD -11.
post #3528 of 4296 Old 07-21-2015, 09:49 AM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
MPC-HC really stands out for ripped media (like Blu Ray MKV files). Especially when coupled with madVR. I have found that the only way to reliably switch to 24Hz with ripped media is to use MPC-HC/madVR. Furthermore, MPC-HC works seamlessly with Emby, Kodi, etc. PowerDVD not so much (unless playing ISO files and/or 3D I think).
post #3529 of 4296 Old 07-21-2015, 10:16 AM
JDLIVE's Avatar
Quoted: 96 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
+1
A big reason why I used that combo. Most of my content watching is Blu-Ray so MadVR really doesn't do much for me, but the refresh rate switching and ease of use in a CIH setup are why I still have it.
JDLIVE is offline
post #3530 of 4296 Old 07-29-2015, 07:02 PM
Liked: 0
Spdif problem
hello
i have this problem with my spdif out.
i download movies in MicroHD format and if audio is AC3 multichannel my home cinema is decoding the DTS or Dolby.
But if the mkv file has AAC 48KHz 6 channel AAC(LC) is decoding like PCM 2 channel and it has strangeDistortion.
this is the output :
SPLITTER
if audio is AC3 : Dolby AC3 48000Hz 6ch 512kbps -> Audio: S/PDIF 48000Hz stereo 1536kbps
if audio is AAC :Audio: AAC 48000Hz 6ch -> Audio: IEEE Float 48000Hz 6ch 9216kbps
Thank you
jim788e is offline
post #3531 of 4296 Old 07-30-2015, 04:24 AM
mightyhuhn's Avatar
Quoted: 750 Post(s)
Liked: 256
spdif can't bitstream 5.1 aac so it is not possible to get this codec as 5.1 to the receiver using spdif.
you have to realtime reencode it or use hdmi or analog to get 5.1 to the receiver. spdif is a very bad choice anyway.
post #3532 of 4296 Old 08-02-2015, 03:27 AM
ttnuagmada's Avatar
Quoted: 133 Post(s)
Liked: 127
I was hoping someone could give me a quick suggestion on quality settings I should be using for 1080p content on a 1080p television. I've used MadVR for a long time and im familiar with smooth motion and whatnot , but it seems they've added a ton of scalers and whatnot in recent versions, and im not sure what i should be aiming for here. HTPC is pretty powerful (2500K and Nvidia 780)
ttnuagmada is offline
post #3533 of 4296 Old 08-02-2015, 03:21 PM
JDLIVE's Avatar
Quoted: 96 Post(s)
Liked: 51
Just IMO, you'll be hard pressed to see significant improvement in PQ from MadVR in that case.
JDLIVE is offline
post #3534 of 4296 Old 08-05-2015, 10:13 AM
bran82's Avatar
Quoted: 18 Post(s)
Try the image refinement/sharpening options?
bran82 is offline
post #3535 of 4296 Old 08-06-2015, 03:20 PM
Derko's Avatar
I just went through the whole set up after installing a fresh copy of Windows 10. For some reason, after a minute or so of playing any file, the video will freeze and audio will still continue playing, but then later on freeze up and go in and out. Time stamp according to MPC is that it's playing like normal.
I am using 2x7970s connected via HDMI to an NR1008, and a 54in VT25 Panasonic plasma.
The issue is 100% related to madVR and will happen every time with the latest build after a couple of minutes. With older builds, it'll happen a bit more randomly and no matter whether I've used the default settings or not.
I've attached a freeze report to see if anyone can give me a hand. Been dealing with this for 2 days and I'm about to pull my hair out cause I can't figure it out!
Derko is offline
post #3536 of 4296 Old 08-18-2015, 06:52 PM
Pastuch's Avatar
Quoted: 41 Post(s)
Liked: 35
I can't figure this out, whenever bit-streaming is enabled in MPCHC my video freezes and won't play. Any ideas?
Edit: Also in WIndows 10
Pastuch is offline
post #3537 of 4296 Old 08-19-2015, 08:54 AM
Sunset1982's Avatar
Quoted: 48 Post(s)
any suggestions for setting up madvr for upscaling 1080p to a 4k TV? Using mpc/madvr on a i5, R9 280.
What settings do i have to use in imagedoubling?
Sunset1982 is offline
post #3538 of 4296 Old 08-21-2015, 01:17 PM
Onkyoman's Avatar
Quoted: 152 Post(s)
Liked: 68
Profile: "4K High-Quality"
  • Chroma: super-xbr150 + AR or NNEDI332
  • Image: Jinc3 + AR
  • Luma Doubling: 2x or greater - NNEDI3 32 to 256 neurons
  • Luma Quadrupling: 3x or greater - NNEDI3 32 to 256 neurons
  • Downscaling: Catmull-Rom + AR + LL
  • Upscaling Refinement: SuperRes (strength: 1)
  • Artifact Removal - Debanding: Medium/High
  • Image Enhancements: Off
  • Dithering: Error Diffusion 2
Onkyoman is online now
post #3539 of 4296 Old 08-21-2015, 04:49 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
I have a Gateway HTPC. I am using the onboard graphics card. I get tearing video playback during bluray disc. Check out pic. Do I need a new graphics card? I am using MPC HC video player. I would love some help fixing this.
bori is offline
post #3540 of 4296 Old 08-22-2015, 05:21 AM
Quoted: 278 Post(s)
Liked: 113
A graphics card could be the solution. Post the designation of your CPU and graphics, probably in you Gateway manual and open up the case and see what kind of open slots you have on your motherboard, for example PCI-e. Also state the maximum resolution of your display, for example 1080i, 24 Hz. Addiitionally post the player software you are using
Reply Home Theater Computers
