Advanced MPC-HC Setup Guide - Page 120 - AVS Forum | Home Theater Discussions And Reviews
 60Likes
post #3571 of 3575 Old 08-27-2015, 11:33 AM
Liked: 0
Just giving my earlier post a bump - would love any ideas or advice. If there would be a more appropriate thread or forum to post this question in, please let me know. Thanks!
Originally Posted by oso101 View Post
I'm having trouble switching between headphones & HDMI audio using ReClock with MPC-HC.
I have everything set up according to this guide. The trouble is that when a video is playing and I plug in headphones, the audio doesn't automatically switch from HDMI out to the headphones. If I stop the video, close MPC-HC and start it again, then I'll have headphone audio. But then if I unplug the headphones, I won't get HDMI audio. I need to close and reopen the player again for it to switch.
I solved the problem by switching MPC-HC's audio renderer setting from ReClock to system default - everything works fine and I can plug in & unplug headphones and the audio will switch appropriately.
So, is this an inherent limitation of ReClock, or is there a way I can both use ReClock AND be able to easily switch between headphones & HDMI audio?
I'm running Windows 8.1, wiwth RealTek audio drivers.
oso101 is online now
post #3572 of 3575 Old 08-30-2015, 07:33 PM
Liked: 0
I noticed that xySubFilter is no longer included in the guide, is MPC's internal renderer better now? I don't quite understand the difference in the first place...
gotmoo is offline
post #3573 of 3575 Old 08-30-2015, 10:52 PM
mightyhuhn's Avatar
Quoted: 541 Post(s)
Liked: 179
xy subfilter is still better but it's not a huge thing. 99% of all user doesn't gain anything.
mightyhuhn is online now
post #3574 of 3575 Old 08-30-2015, 11:50 PM
bori's Avatar
Quoted: 122 Post(s)
Liked: 95
I am on windows 10. Does anyone have any idea why my monitor turns on by itself. I switch the power off manually. Then hours later it's back on.
bori is online now
post #3575 of 3575 Old 09-01-2015, 10:25 AM
Orta's Avatar
Is there any setting or tweak that will make scrubbing/seeking real time? When I drag the seek bar with my mouse, it doesn't scrub by frame, it just jumps around in long intervals based on where I start/stop. I've tried unchecking and checking everything related to fast seek, and setting jump distances to 0ms, but nothing seems to alleviate the behavior. With a 4790k/970 on an SSD, I can only assume this isn't hardware or horsepower related. I'm using basically default settings, no MadVR or anything.
Orta is offline
Reply Home Theater Computers
