Advanced MPC-HC Setup Guide - Page 121 - AVS Forum | Home Theater Discussions And Reviews
 141Likes
post #3601 of 4263 Old 10-12-2015, 01:25 PM
Postmoderndesign's Avatar
Quoted: 268 Post(s)
Liked: 100
I did not find what formats your Samsung HT-F6550W supports. I just saw that it supports 5.1. It may not support DTS-HD and Dolby True HD
Does your Samsung HT-F6550W have display that posts the audio format?
Have you configured windows with your speaker set up by right clicking the speaker symbol in the lower right windows task bar, selecting your playback device, Samsung HT-F6550W. and then configuring your playback device in windows?
I think that if you use MPC-HC for playback you can set the program up to do the decoding. However, I use an AVR so I am not sure. But I am not sure you can then bypass the Samsung HT-F6550W.
Postmoderndesign is offline
post #3602 of 4263 Old 10-13-2015, 12:59 AM
Liked: 0
I tried add the link to the specs but the foeum wouldn't allow it cause i'm a newbie , so just remove the spaces to get the link
w w w .samsung. c o m/uk/consumer/tv-audio-video/audio-video/home-theatre-systems/HT-F6550W/XU
You can find it by clicking on "TECH SPECS" , & then "show more specs"
Medo is offline
post #3603 of 4263 Old 10-13-2015, 01:16 AM
steelman1991's Avatar
Quoted: 228 Post(s)
Liked: 121
If its a HT in a box (all in one solution) sometimes those units only recognise all the formats played directly from that unit and restrict playback from external devices via HDMI to core DD and DTS.
Yeah as I suspected there is limited playback support for audio codecs when playing files from external sources (rather than directly from the BluRay player head unit) - see page 8 of your units manual - http://www.produktinfo.conrad.com/da...e_en_fr_it.pdf
Your unit supports LPCM, so rather than bitstream, you could have the player decode the signal and send to the unit. You won't get the recognition of DTS-MA or TrueHD lighting up the front of your unit, but its the same quality just delivered in a different manner.
steelman1991 is offline
post #3604 of 4263 Old 10-13-2015, 03:33 AM
Liked: 0
Yeah thanks steelman that helped a lot. Any suggestions for a good player & its configuration that can decode the signal without any loss in quality ?
Medo is offline
post #3605 of 4263 Old 10-13-2015, 07:54 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 252
mpc-hc.
mightyhuhn is offline
post #3606 of 4263 Old 10-13-2015, 08:21 AM
Quoted: 228 Post(s)
Liked: 121
LOL you're in the thread for one - see first post.
post #3607 of 4263 Old 10-14-2015, 03:41 AM
Liked: 0
Thanks mightyhuhn
Lool guess you are right again steelman
Medo is offline
post #3608 of 4263 Old 10-16-2015, 01:44 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
Originally Posted by bori View Post
I am trying to playback the blu ray of Casino Royale. When using power dvd it playback fine. When using MPC the video and audio stutters. Can someone help pls.
Here is a pic of my specs.
Originally Posted by mightyhuhn View Post
system specs?
bori is offline
post #3609 of 4263 Old 10-17-2015, 12:44 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 252
should be the scaling settings in madVR.
the 730 gt is very very slow.
could be a GK108 which has no processing power at all or a GK208 which is about 3x faster than the GK108 but still slow. that's not possible to judge from the screen.
i can do a better guess with the system informations from the driver (nvidia control panel).
under help -> system informations.
looks like this: http://abload.de/img/gpu0gacn.png
try DXVA2 scaling.
post #3610 of 4263 Old 10-17-2015, 03:12 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
try DXVA2 scaling.
bori is offline
post #3611 of 4263 Old 10-17-2015, 03:27 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
bori is offline
post #3612 of 4263 Old 10-17-2015, 05:26 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
Why do I have so many onkyo 805 in my MadVR settings. I have my PC connected to my receiver and use my projector as the monitor. What should I set my onkyo to in these settings?
bori is offline
post #3613 of 4263 Old 10-17-2015, 07:52 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 252
it's a GK208 so it could be worse.
no clue about the device "issue". this settings isn't important you don't have to set anything there. it will not harm picture quality.
setting it to projector gives one new option for projector with anamorphic lenses.
the issue should be scaling.
can you make a screen shoot from the madVR osd (control + j)?
post #3614 of 4263 Old 10-17-2015, 09:08 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
it's a gk208 so it could be worse.
No clue about the device "issue". This settings isn't important you don't have to set anything there. It will not harm picture quality.
Setting it to projector gives one new option for projector with anamorphic lenses.
The issue should be scaling.
Can you make a screen shoot from the madvr osd (control + j)?
bori is offline
post #3615 of 4263 Old 10-17-2015, 09:08 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
I am not getting any audio from playback on bluray disc from pc.
bori is offline
post #3616 of 4263 Old 10-17-2015, 09:16 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 252
madVR is not the issue on this screen.
you have a terrible clock deviation. I can only guess why.
no clue about your audio problem. a lot depends on your setup.
and with your current selected scaler a 60 hz file will not run what so ever.
post #3617 of 4263 Old 10-17-2015, 09:58 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
It's funny cause the audio was working fine earlier. Then I messed around with madvr and it got screwed up. So what do you recommend for me to do regarding the clock deviation?
bori is offline
post #3618 of 4263 Old 10-17-2015, 10:24 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 252
reset everything to default.
install only MPC-HC and madVR nothing else and try it with default settings first.
post #3619 of 4263 Old 10-17-2015, 10:28 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
Won't need the lava and haali or ffshow filters? Sorry might of spelled them wrong.
bori is offline
post #3620 of 4263 Old 10-17-2015, 11:54 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 252
no you don't need that for normal playback.
post #3621 of 4263 Old 10-17-2015, 12:36 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
What are they need for?
bori is offline
post #3622 of 4263 Old 10-17-2015, 12:49 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 252
lav filter is part of MPC-HC.
haali is just a splitter and the splitter from lavfilter is just better.
ffdshow is only need for SVP as a decoder lavfilter is simply the better one.
bori likes this.
post #3623 of 4263 Old 10-17-2015, 01:29 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
Do I need these if I want to bitstream audio to my receiver?
bori is offline
post #3624 of 4263 Old 10-17-2015, 01:57 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
I answered my own question. I just installed MPC-HC. Ticked the bitstream of audio in the decoder settings. Now everything is working. Take a look at pic to see what u think now.
bori is offline
post #3625 of 4263 Old 10-17-2015, 01:58 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
bori is offline
post #3626 of 4263 Old 10-17-2015, 04:03 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
I added madvr and this video at 1080p60 starts to stutter. Without madvr it plays fine.
bori is offline
post #3627 of 4263 Old 10-17-2015, 04:50 PM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
Attachment 1001857
How do you reset the settings in madvr?
bori is offline
post #3628 of 4263 Old 10-17-2015, 09:54 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 252
sorry i have to sleep from time to time.
there is a restore default settings.bat in the madVR folder to reset madVR.
and forget the settings other user usually use like jinc3 AR a 730 gt can't do this for 60 FPS.
nvidia DXVA native has an issue with madVR try DXVA copy back.
post #3629 of 4263 Old 10-18-2015, 09:49 AM
bori's Avatar
Quoted: 193 Post(s)
Liked: 126
I don't get why MadVR can not play this 3d movie 1080p60. When I uninstall it, it plays fine with just the default settings on MPC-HC. Is there another filter that is just as good as MadVR I can try?
bori is offline
post #3630 of 4263 Old 10-18-2015, 10:08 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 252
your GPU isn't fast enough with your scaling settings.
Reply Home Theater Computers
