Advanced MPC-HC Setup Guide - Page 137 - AVS Forum | Home Theater Discussions And Reviews
 123Likes
post #4081 of 4110 Old 07-04-2016, 03:45 PM
Quoted: 79 Post(s)
Liked: 8
I use MPC HC with lav video filter and madvr.
For bluray standard, what is the best configuration of level RGB ( limited or Full) in madvr, in Nvidia Panel and in Display?
Marco Rasero (marco803) is online now
post #4082 of 4110 Old 07-04-2016, 07:14 PM
Onkyoman's Avatar
Quoted: 110 Post(s)
Liked: 46
Try this post: http://forum.kodi.tv/showthread.php?...942#pid2238942.
Onkyoman is offline
post #4083 of 4110 Old 07-05-2016, 12:11 AM
Liked: 0
Originally Posted by VBB View Post
It's the right section, but it's 4th of July weekend, and also probably not to many madVR users also use the Netflix app. Have you tried to remove everything you installed recently and see if that makes the app work again? madVR shouldn't cause any issues, but perhaps the LAV filters did, if you installed them outside of MPC-HC.
Thanks man. I uninstalled the LAV filters and set the windows media player as default player but still have the same problem. Thing is I spent a considerable amount of time configuring MPC-HC and madvr so don't want to have to remove it again. I know everything works without MPC-HC but I want to keep it and find a way to make it work.
Turns out I can play netflix on my chrome browser but as soon as I enter full screen it freezes my computer and I get a blue Windows error screen saying "driver_irql_not_less_or_equal (dxgmms1.sys)....
fraussie is offline
post #4084 of 4110 Old 07-05-2016, 04:39 AM
Quoted: 79 Post(s)
Liked: 8
In my Samsung, how should I set the black level to get RGB Limited?
post #4085 of 4110 Old 07-05-2016, 09:53 AM
Onkyoman's Avatar
Quoted: 110 Post(s)
Liked: 46
Set the HDMI black level to HDMI Normal.
Onkyoman is offline
post #4086 of 4110 Old 07-05-2016, 10:00 AM
Quoted: 79 Post(s)
Liked: 8
In other forum it wrote that :
HDMI black level to HDMI Normal (for RGB Full)
HDMI black level to HDMI Low (for RGB Limited)
post #4087 of 4110 Old 07-05-2016, 02:08 PM
VBB
VBB's Avatar
Quoted: 961 Post(s)
Liked: 815
If all you have installed now is MPC-HC with built-in LAV filters and madVR, it should not interact with anything else in your system. The BSOD error points to a DirectX component, possibly related to a video driver issue. Have you tried to re-install the latest Nvidia drivers?
Henry
Vizio M70-C3, Sharp LC-70LE857U
Onkyo HT-RC360
Synology DS1813+ & DX513 x2
X-Rite i1Display Pro, ArgyllCMS, DisplayCAL, madVR, HCFR
HTPC running Kodi with MPC-HC + madVR, Plex for remote streaming
VBB is offline
post #4088 of 4110 Old 07-06-2016, 12:26 AM
Liked: 0
I fixed the Chrome issue by disabling hardware acceleration in the Chrome settings but the problem remained with the Netflix app, Edge and IE. To be honest I don't really care about Edge or IE but the app is important because it allows me to stream with 5.1 sound.
I have now "fixed" the issues by uninstalling MPC-HC and Madvr but I also had to manually uninstall and reinstall all Nvidia drivers. No idea what is going on... This does not make me happy though as I really want to use MPC-HC/Madvr - the video and sound quality is so much better than with VLC...
fraussie is offline
post #4089 of 4110 Old 07-06-2016, 07:01 AM
Brahmzy's Avatar
Quoted: 395 Post(s)
Liked: 258
Just some questions. I've been a long time MPC-HC user and have recently switched some gear out and want to see if it's worth messing around with MadVR - If I have enough video hardware to see any benefit.
I have a GTX950 / Overclocked Haswell 4670 / Sony 940D 4K set.
Does MadVR work with the x64 MPC-HC? At one point it didn't.
With just a 950, are there any settings that would provide benefit to my old 1080p Blu-Rays? I run MPC-HC in 1080p mode because the upscalar is so fantastic in the 940D.
Would MadVR upscale better than the TV?
HTPC | 12TB NAS | Harmony Elite | DENON X4200W | Sony XBR75X940D
Philips BDP7501 | Klipsch RF7II,RC64II,CDT5650CII | SVS SB2000 x2
Brahmzy is online now
post #4090 of 4110 Old 07-06-2016, 09:55 AM
Onkyoman's Avatar
Quoted: 110 Post(s)
Liked: 46
madVR is 64-bit.
SuperRes in upscaling refinement would benefit any upscaled source. Try setting 1080p -> 2160p to SuperRes 3.
madVR should do a better job of upscaling than the TV.
Onkyoman is offline
post #4091 of 4110 Old 07-06-2016, 01:06 PM
Brahmzy's Avatar
Quoted: 395 Post(s)
Liked: 258
madVR is 64-bit.
Thanks for this. I installed MadVR and set to Super3 (looked great).
I got about 30min of movie time before a bunch of flickering and jerking started. GPUZ showed the 950 was running super hot. I could let it cool and have more play time before the flickering started again. All other settings are default. I enabled the Default Renderer and everything was fine.
Any ideas? Need more GPU/better cooling?
post #4092 of 4110 Old 07-06-2016, 01:50 PM
VBB
VBB's Avatar
Quoted: 961 Post(s)
Liked: 815
The 950 is not the most powerful card, but it should be pretty good with madVR. I use a 960, by the way. It really comes down to settings. Don't use NNEDI3, for example. Use super-xbr instead. Also lower SuperRes a bit. My card never really breaks a sweat scaling anything to 4K.
Henry
Onkyo HT-RC360
VBB is offline
post #4093 of 4110 Old 07-06-2016, 02:26 PM
Brahmzy's Avatar
Quoted: 395 Post(s)
Liked: 258
^^ what Sharpness setting are you using for super-SBR? Or are you using anti bloating? If so, what setting?
And what boxes did you check? There's double luma, double chroma res, quad luma and quad chroma res.
Oh, and under image upscaling, are you using the default Lanczos? 3 taps?
post #4094 of 4110 Old 07-06-2016, 03:26 PM
VBB
VBB's Avatar
Quoted: 961 Post(s)
Liked: 815
For super-xbr I use 100% (no anti-bloat) across the board, along with double luma and chroma (quad and higher checked). Your 950 should not have any trouble doing that. Play with different SuperRes number. Ideally, you want to create a separate profile for every possible resolution/frame rate combo, and then tweak each one accordingly.
Good reads:
http://forum.doom9.org/showthread.php?t=171787
madVR Player Support Thread
Henry
Onkyo HT-RC360
VBB is offline
post #4095 of 4110 Old 07-10-2016, 05:58 AM
Brahmzy's Avatar
Quoted: 395 Post(s)
Liked: 258
Have an annoying one. Ever since I installed MadVR 4-5 days ago, MPC-HC won't open full screen anymore when launched from WMC/MyMovies. It launches in a box about 1/5 the size of the display in the top left. I have checked the box 'launch files in full screen'. Any ideas?
This happened a while ago for a short time and I think an upgrade of MPC-HC ended up fixing it, but I can't remember.
post #4096 of 4110 Old 07-10-2016, 02:29 PM
VBB
VBB's Avatar
Quoted: 961 Post(s)
Liked: 815
Which version of MPC-HC are you using? Latest nightly? I use Kodi as my front-end, for GUI and metadata only. See if the same thing happens if you change the renderer to something other than madVR. That should narrow it down.
Henry
Onkyo HT-RC360
VBB is offline
post #4097 of 4110 Old 07-11-2016, 07:53 AM
John Moschella's Avatar
I have a quick question. I want to put Win10 on my computer and save the MPC-HC settings. Problem is the option for "save settings in .ini file" is grayed out.
I have Win7 using the 32-bit latest version and its installed in C:\Program Files (x86).
Google searched and really couldn't find anything.
John Moschella
John Moschella is offline
post #4098 of 4110 Old 07-11-2016, 07:10 PM
Liked: 0
Hi guys. I have a Core i7 Asus laptop plugged to my PC via HDMI through my Denon AVR 1912. My video card is Nvidia GE Force GT630M 2GB. Which Madvr processing settings do you think would be optimal for that set up. I'm using the 64 bits versions of MPC-HC and Madvr.
fraussie is offline
post #4099 of 4110 Old 07-13-2016, 01:49 PM
Iggy SLO's Avatar
Liked: 2
Could you tell me where this option is so I can check for a possible solution?
There's very little chance that anyone can just tell you the best setup. Everyone has their own system and there are a ton of settings in madVR, so I can't think of a better answer than trial and error. I believe your GPU is pretty good though, so I think you can crank up a lot of the settings.
You can check out this page that explains a lot about different madVR settings.
And here are my settings if you're interested. I have a GTX970, but it's not really taxed.
yukinok25 likes this.
Iggy SLO is offline
post #4100 of 4110 Old 07-13-2016, 03:57 PM
VBB
VBB's Avatar
Quoted: 961 Post(s)
Liked: 815
Try running MPC-HC as admin (right-click -> run as...). Sounds like it doesn't have write access to the folder.
Henry
Onkyo HT-RC360
VBB is offline
post #4101 of 4110 Old 07-14-2016, 06:47 AM
That worked. I really thought I had tried that, but I guess I didn't. Thanks.
John Moschella
post #4102 of 4110 Old 07-19-2016, 10:56 AM
PixelQ's Avatar
Liked: 1
Hello there, I have a question, is there a way to show fps during fullscreen? I can only see them while windowed ("show stats" only appears below video). Thanks!
PixelQ is offline
post #4103 of 4110 Old 07-19-2016, 02:03 PM
VBB
VBB's Avatar
Quoted: 961 Post(s)
Liked: 815
Press CTRL+J to see stats. Not sure if this works without madVR, though.
PixelQ likes this.
Henry
Onkyo HT-RC360
VBB is offline
post #4104 of 4110 Old 07-19-2016, 03:36 PM
PixelQ's Avatar
Liked: 1
Thanks, I tried that already but didn't know which value should've checked. No stat seems to be fps.
PixelQ is offline
post #4105 of 4110 Old 07-19-2016, 08:59 PM
VBB
VBB's Avatar
Quoted: 961 Post(s)
Liked: 815
What exactly are you looking for when you say fps? The current frame rate of the display or the original frame rate of the file being played, or something else entirely? Are you using madVR with MPC-HC?
Henry
Onkyo HT-RC360
VBB is offline
post #4106 of 4110 Old 07-20-2016, 10:02 AM
PixelQ's Avatar
Liked: 1
I want to check the fps like when I use fraps while playing a videogame. Yes, I'm using MPC-HC + MadVr, used the guide here to set it up. Thanks!
PixelQ is offline
post #4107 of 4110 Old 07-21-2016, 09:22 AM
Krispy Kritter's Avatar
Quoted: 28 Post(s)
If you are using a TV as a display, won't it always be 60fps? Unlike a game, it shouldn't change. It will be the fps of the encode or the output to the TV (as noted above). It shouldn't be anything else.
PixelQ likes this.
Krispy Kritter is offline
post #4108 of 4110 Old 07-21-2016, 10:57 AM
PixelQ's Avatar
Liked: 1
Oh I see thanks, so which stat should I be paying attention if I notice the video is not running smoothly?
PixelQ is offline
post #4109 of 4110 Old 07-21-2016, 02:38 PM
JL-F1's Avatar
Dropped frames
PixelQ likes this.
JL-F1 is online now
post #4110 of 4110 Old Today, 04:02 AM
ikbenben's Avatar
Liked: 0
I've recently switched from Windows 7 to 10 and i'm reinstalling MPC-HC.
I use it mostly for watching movies in mkv format. When I watch a movie I switch the pc screen to my Panasonic 55VT60 plasma connected to a AVR Denon 3313. The pc is connected to the Denon via a HDMI cable.
As I understand from the OP I have to use bitstream so my AVR will use it own decoders and I don't need Reclock in my case. Am I correct?
Edit 1 :
Installed and tested. I have a couple of other questions.
Using the scaling options I think my GPU (Sapphire Radeon HD7850) is a bottleneck. I've seen frequent framedrops but it gets better when the movie plays a while. Will my GPU scale better with lanczos? Also is it better in my case to not use Image Doubling or will my GPU suffice to still use it? Also when I select super-xbr at Image Doubling I have choises for sharpness ranging from 25 to 150. I can't just select super-xbr on it's own, for now I've selected sharpness 100.
Edit 2 : my processor is an i5 3550 3.3GHz and 8GB RAM DDR3 1600MHz and running on Windows 10.
ikbenben is online now
Reply Home Theater Computers
