Advanced MPC-HC Setup Guide - Page 142 - AVS Forum | Home Theater Discussions And Reviews
 138Likes
post #4231 of 4248 Old 02-07-2017, 02:41 PM
JohnDorian's Avatar
Liked: 0
20
Originally Posted by mightyhuhn View Post
look normal to me.
try down mixng to 2.0
not normal ac3 allows only 3 channel without bitstream. What is down mixing?
JohnDorian is offline
post #4232 of 4248 Old 02-07-2017, 04:36 PM
Quoted: 16 Post(s)
Liked: 2
I was following the guide in the OP when I noticed my version of madvr doesn't have "image doubling." Anyone know whats up with that?
psnblahblah is offline
post #4233 of 4248 Old 02-07-2017, 05:09 PM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
AC3 support up to 5.1 bit streaming has nothing todo with this.
down mixing is a process to change the channels down to 2.0 for example.
it is pretty normal that the C channel is used only for long periods of time. for some at least for me unknown reason the speaking of persons is usually only on the C channel with is totally dump IMHO but that how it works.
what type of connection are you using?
mightyhuhn is online now
post #4234 of 4248 Old 02-07-2017, 06:00 PM
JohnDorian's Avatar
Liked: 0
analog wires from motherboard directly to the subwoofer. I don't know but without bitstream it doesn't work with ac3. And i don't know unfortunately how to enable down mixing...
post #4235 of 4248 Old 02-07-2017, 09:08 PM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
lav audio -> mixing - enable mixing.
you can't bitstream with an analog connection.
post #4236 of 4248 Unread 02-08-2017, 08:42 AM
JohnDorian's Avatar
Liked: 0
maybe but without it doesn't work... So its only 4.1-7.1 and mono-stereo. Which should i pick?
post #4237 of 4248 Unread 02-08-2017, 01:53 PM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
i would select the same as your setup.
2.0 or 2.1 is the "same".
post #4238 of 4248 Unread 02-08-2017, 02:37 PM
JohnDorian's Avatar
Liked: 0
there is no 2.0 or 2.1... Maybe i should try legacy or smth?
ID:	1952913   Click image for larger version
post #4239 of 4248 Unread 02-09-2017, 09:32 AM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
stereo is 2.0
JohnDorian likes this.
post #4240 of 4248 Unread 02-09-2017, 11:01 AM
JohnDorian's Avatar
Liked: 0
Cool Turk
stereo is 2.0
Daum ty. I can't imagine how but it works. With "speaker fill" feature enabled. Perhaps thats why. I'm stressed out by those tests but with "stereo" rear sound is more clear. Im not sound specialist but all those manipulations its not how that supposed to be, am i right? Because now all channels are at same volume lvl. And players shows only 2 channels.
post #4241 of 4248 Unread 02-09-2017, 01:34 PM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
sorry i don't know what type of system you are using and how it is cabled.
post #4242 of 4248 Unread 02-09-2017, 01:50 PM
JohnDorian's Avatar
Liked: 0
Spa 2600
Audio input for data
3 x 3.5 mm jack
Cable length
2 x 5m and 3 x 1.5 m
Connector
3.5 mm stereo
Power
AC 220 V 50 Hz
post #4243 of 4248 Unread 02-09-2017, 02:51 PM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
are you using 3 correctly connected jacks connection or not ?
post #4244 of 4248 Unread 02-09-2017, 03:46 PM
JohnDorian's Avatar
Liked: 0
yep
post #4245 of 4248 Unread 02-09-2017, 04:09 PM
mightyhuhn's Avatar
Quoted: 731 Post(s)
Liked: 250
set the mixing to 5.1 and test it with this file: https://www2.iis.fraunhofer.de/AAC/multichannel.html
post #4246 of 4248 Unread 02-09-2017, 06:46 PM
JohnDorian's Avatar
Liked: 0
I tried first one. Works perfectly.
post #4247 of 4248 Unread 02-09-2017, 09:59 PM
Liked: 0
MPC doesn't work for me!
I'm not sure if I'm doing something wrong but I'm not able to get smooth playback in MPC-HC or MPC-BE.
I aim to play 30-50gig h264/5 videos in MKV container with DTS, DD sound tracks. My CPU is new i5 7500 with integrated Intel 630 graphic connected to a display via DP 4k@60Hz.
What I've tried so far:
MPC-HC out-of-the-box - CPU 100% video is vey choppy. Unusable.
MPC-HC with EVR and LAV with DXVA on - CPU 10-30% video is not smooth and this is especially noticeable in panning scenes. Sound is not affected and video is watchable but not "fluid". I think that the technical term for this issue is video judder.
MPC-HC following OP guide - madVR and LAV, disabled bitstreaming. It's slightly worse than with EVR the video is more jerky in panning scenes.
I've installed ReClock but for some reason it isn't listed in MPC-HC audio filter list!?
If I didn't play all my videos in Win10 default player "TV & Movies" I would think that something is wrong with my hardware, files etc, but all those files play perfectly smooth in Win10 default player. Also if I resize the player window or switching from window mode to full screen and vice versa - the win10 player does that transition very smoothly while MPC needs a few seconds to resize, sync and continue. Why is that?
Any idea what I can try setting wise that could help my video judder issue?
eremic is offline
post #4248 of 4248 Unread Today, 03:00 PM
gerall's Avatar
Quoted: 50 Post(s)
I was hoping someone could elaborate on the below from the guide:
Mixer
This is mostly for people having volume issues with multichannel audio. The low volume occurs when Windows downmixes your audio, and to avoid this, you can do a downmix within MPC-HC instead. To access the mixing options of MPC-HC, go to options, internal filters, click Audio Decoder at the bottom, then go to the mixing tab.
Select your speaker configuration and check the option in the upper right called “Don’t mix stereo sources” to leave mono and stereo audio untouched by the mixer. Don’t touch any of the sliders.
I am having trouble with very low volume with downmixed audio - when I enable mixing and raise the volume from .71 to 1.0 for the center and surrounds it increases the volume to an acceptable level - is this appropriate or will there be an imbalance in the channels with the center and surrounds being louder than they should be?
thanks to all
gerall is online now
Reply Home Theater Computers
