Advanced MPC-HC Setup Guide - Page 145 - AVS Forum | Home Theater Discussions And Reviews
 144Likes
post #4321 of 4335 Old 06-15-2017, 03:10 PM
acefr's Avatar
Quoted: 522 Post(s)
Liked: 479
USB-C to HDMI 2.0 adapter that do not support HDR10 pass-thru:
Anker Do not support HDR10 pass-thru. No plans to add the support.
Club3D Do not support HDR10 pass-thru. Working on firmware update to add support, but ran into technical difficulties, so no HDR support for the near future.
I am still searching for an adapter that does. Looking into Cable Matters and UpTab. The UpTab one is interesting, as the MFR claims HDMI2.0a while no other MFRs claim the "a". (HDMI2.0a was created to support HDR10, while b for DV) I am not sure this is what was intended, or the MFR just failed to recognize the "a" is for HDR10. The chip is Parade PS176, which was also used in Club3D adapter. I have yet seen users mentioning about HDR10 support anywhere.
acefr is offline
post #4322 of 4335 Old 06-15-2017, 06:24 PM
long_pn's Avatar
Quoted: 18 Post(s)
I'm too interested in those adapters because my HTPC mainboard has DP1.2 port which enables 4k@60Hz. It's not clear to me if the issue of HDMI 2.0 adapter that do not support HDR10 pass-thru relates to bandwidth limits, or the conversion chip or something else. And there may be a typo with "a" or "b" following HDMI2.0 sometime as well.
long_pn is offline
post #4323 of 4335 Old 06-15-2017, 07:06 PM
acefr's Avatar
Quoted: 522 Post(s)
Liked: 479
It is the LSPCON chip inside that does not properly pass thru the HDR10 meta data. Maybe a firmware update will fix it, or maybe not. All Intel Graphic will have the same issue as they need a LSPCON chip no matter it is desktop or laptop since Kaby Lake processor does not support native HDMI2.0 (a or b). At least on the desktop you can get a discrete HDMI2.0 graphic card to avoid the LSPCON issue.
acefr is offline
post #4324 of 4335 Old 06-28-2017, 06:07 PM
Liked: 1
I'm looking for advice on how to correctly play 25p material with MadVR and Reclock.
When I start playback of a 25p source, MadVR tells my Samsung tv to switch the refresh rate to 25p (probably 100hz in actuality). However, my MadVR playback stats show that I'm having frame drops every 1 second or so.
And when I open the Reclock window during playback, it looks like Reclock thinks the source is actually 23.976 fps.
I can manually change the source framerate in Reclock to 25p. This causes a message to appear in the Reclock Media Adaptation section saying "Cannot sync this CINEMA video to your hardware. Please set your monitor refresh rate near to a multiple of 24 Hz." When I then uncheck the PAL Speeddown (force to 24fps) option, the message changes to "PAL adaptation: media speed changed to 25.000 fps. Audio resampled at 48000 Hz". But I still get frame repeats every 1-2 seconds.
The best workaround I've found is to select the MadVR option for "Treat 25p sources as 24p", so MadVR slows the video down to 24p and sets my tv to 24p. Then I have to manually open the Reclock window during playback and set the source framerate to 25fps and chek the PAL SpeedDown option. This gets me to 1 frame drop every 2 minutes or so.
But this needs to be done manually every time I start a new 25p video. And still gets me nowhere close to the perfectly smooth playback I get with 24p content.
Any advice on how to set up MadVR and Reclock to handle 25p content correctly and automatically?
oso101 is offline
post #4325 of 4335 Old 07-02-2017, 01:34 PM
Liked: 0
I'm looking for optimal settings of madVR for playing 1080p movies.
I'm using a Lenovo Ideapad laptop i7 6700hq, GTX950M, ssd , 8gb ram conected to Samsung Tv 55JU7500.
So far I used MadVR default settings with MPC-HC but I can't see a improvement image quality compared with EVR render (screenshots comparison).
ccryd is offline
post #4326 of 4335 Old 07-03-2017, 04:42 AM
mightyhuhn's Avatar
Quoted: 770 Post(s)
Liked: 263
try super XBR maybe even ngu low but a 950m is maybe not up to the task if the output resolution is UHD.
mightyhuhn is online now
post #4327 of 4335 Old 07-03-2017, 07:02 AM
iTTT's Avatar
thanks for sharing. just setup my mpc and works very good.
iTTT is offline
post #4328 of 4335 Old 07-16-2017, 10:41 AM
Iggy SLO's Avatar
Quoted: 28 Post(s)
Liked: 7
v1.7.13 is released and farewell
Pretty bummed out that this seems to be the end of development for this wonderful player. Are there any others like it? I heard some stuff about MPC-BE or something like that, but not really sure what the difference is.
Iggy SLO is offline
post #4329 of 4335 Old 07-16-2017, 09:12 PM
Brahmzy's Avatar
Quoted: 469 Post(s)
Liked: 358
Yes ^^
Really sucks!!!
HTPC | 12TB NAS | Harmony Elite | DENON X4200W | Sony XBR75X940D
Philips BDP7501 | Klipsch RF7II,RC64II,CDT5650CII | SVS SB2000 x2
Brahmzy is online now
post #4330 of 4335 Old 07-17-2017, 05:57 AM
mightyhuhn's Avatar
Quoted: 770 Post(s)
Liked: 263
MPC-HC will still be updated by clsid.
it is just unlikely we will see major new features.
the decoding side is pretty save too because MPC-HC uses lavfilter which is updated as usual.
MPC-BE is a fork from MPC-HC even up to this day they still share a lot of code and profited from each other.
MPC-BE is major difference is it uses it's own FFmpeg based decoder which is at least to my eyes clearly inferior to lavfilter so it is a little bit of work to switch from the internal decoder to lavfilter.
Iggy SLO likes this.
post #4331 of 4335 Old 07-22-2017, 06:56 AM
Quoted: 21 Post(s)
Liked: 0
Whenever i play movies with MPC-HC i have low sound. From both speakers and headphones. 9/10 movies happen this. On contrary with BS Player the sound is very high, maybe at level of distortion.
Maybe it happens cause the movies have DTS sound? Most movies are Bluray x264
lazostat is offline
post #4332 of 4335 Old 07-22-2017, 07:20 AM
mightyhuhn's Avatar
Quoted: 770 Post(s)
Liked: 263
depends on the down mixing and if the player allows for more than 100% volume something that should never be used.
DTS has nothing todo with it it is just an audio codec. it is possible to encode audio louder by using the dreaded DRC.
mixing could be an issue you can try the mixing in lav audio. alternatively you can install AC3 filter and use the DRC function.
what so ever BDs are generally "lower" in volume at the same audio setting as audio CD the reason for that is simply CD are DRC to death so they are "louder" while BD audio is using a higher dynamic range to get better audio quality.
post #4333 of 4335 Old 07-23-2017, 01:31 PM
Quoted: 21 Post(s)
Liked: 0
I guess depends on the settings mentioned on the 1st page, which i made. As i said BS Player and other players have higher sound on the same movies. But if its for better quality, i give up!
lazostat is offline
post #4334 of 4335 Old Yesterday, 01:54 PM
Liked: 0
Im trying to use reclock but there's no sound
can somebody helps me please
Khaled1323 is offline
post #4335 of 4335 Old Yesterday, 04:36 PM
mightyhuhn's Avatar
Quoted: 770 Post(s)
Liked: 263
your error massage is very clear change the output format to 24 bit or 16 bit and try again.
Reply Home Theater Computers
