Advanced MPC-HC Setup Guide - Page 146 - AVS Forum | Home Theater Discussions And Reviews
 146Likes
post #4351 of 4367 Old 09-08-2017, 07:27 PM
Liked: 0
sorry double post, I can't edit
why no active hardware accelerator?
Rippner is offline
post #4352 of 4367 Old 09-09-2017, 12:26 PM
mightyhuhn's Avatar
Quoted: 779 Post(s)
Liked: 265
there could be a lot of reason for this.
the file is using a codec that can't be accelerated by the card.
4K on AMD was a huge issue back in the time so it could be blocked to prevent system crashes.
mightyhuhn is offline
post #4353 of 4367 Old 09-10-2017, 12:51 PM
Liked: 0
Originally Posted by Rippner View Post
hello! I have mpc-hc + madvr (madvr output+dxva2 copy-back), but ****ty fps on a 4k movie
Bit rate: 52.9 Mb/s - Frame rate: 23.976 (24000/1001)
mpc use all cpu and gpu only 20/50%
fps drop from 24 to 15 or less
with powerdvd it play smooth but madvr is madvr
I have an i5 3450 + 7950 3gb + 8gb ram+paging
what can I do? .-. change hardware?
anyone?
Rippner is offline
post #4354 of 4367 Old 09-10-2017, 06:50 PM
mightyhuhn's Avatar
Quoted: 779 Post(s)
Liked: 265
something wrong with my answer.
with old AMD cards you are playing with fire if it comes down to UHD decoding.
post #4355 of 4367 Old 09-11-2017, 05:47 AM
Liked: 0
oh, thanks and sorry, I thought your previous answer was just about hardware accelerator
so I can't do nothing with this hardware, understood
Rippner is offline
post #4356 of 4367 Old 09-12-2017, 02:25 AM
Liked: 0
Hi,
I have a chance to get an older Dell Precision T7500 graphics workstation in following configuration for quite cheap:
Dual CPU Xeon X5570 - 8 cores 2.93ghz
32GB ddr3 Ecc registered 1333 memory (I can easily upgrade to 64gb if it helps, ecc RAM is very cheap)
256gb ssd Samsung for OS
3 x 3tb Western Electric Green HDD
Windows 10 64gb
AMD 7750 1gb graphic card.
Is this unit appropriate and fast enough for MPC-HC and Madvr with "high end" settings? If so, should I use software or hardware docoding?
I know this graphic card is not the best one but I could spend some money on a better one like GTX 970 4gb, or somethig better if you can suggest.
At the moment I use a smaller Dell T3500 and I absolutely loved it. Unfortunately with one X5570, 24gb ddr3 and AMD 7750 it was to slow.
I watch mostly 1080p and 720p, ocassionally some SD DVSs. For Bluray I use Powerdvd16, otherwise MPC-HC with MAdvr which mops the floor with Powerdvd16 in terms of picture quality.
I want to get the best possible picture out of this unit.
What do you guys think?
derik736 is offline
post #4357 of 4367 Old 09-12-2017, 03:22 AM
mightyhuhn's Avatar
Quoted: 779 Post(s)
Liked: 265
CPU is not important the important part is the GPU. or with other words it doesn't change anything.
post #4358 of 4367 Old 09-14-2017, 08:54 PM
Liked: 0
ehm I quote myself because something strange happened!
I've formatted my PC and now I can see the same video at 60fps with mpc-hc 64bit + madvr o.o
how is it possible?
Rippner is offline
post #4359 of 4367 Old 09-14-2017, 09:56 PM
long_pn's Avatar
Quoted: 21 Post(s)
how is it possible?
What video is it ? Can you post the video details via MediaInfo or the madVR OSD ?
long_pn is online now
post #4360 of 4367 Old 09-15-2017, 06:29 AM
Liked: 0
2 different video
update: I watched all first video (59mb bitrate), still not good performance. most of the time 60fps but drop to 18/24... well I need a new gpu
ID:	2283106   Click image for larger version
ID:	2283108   Click image for larger version
ID:	2283110   Click image for larger version
Rippner is offline
post #4361 of 4367 Old 09-15-2017, 06:25 PM
long_pn's Avatar
Quoted: 21 Post(s)
2 different video
I have a haswell i5 (similar to yours) and it can cope with 4K hevc hdr video up to 24/30fps, no way 50/60 fps. Luckily, most of movies are 24/30 fps. So it serves well until I get a 4K display.
post #4362 of 4367 Old 09-19-2017, 11:17 AM
Quoted: 24 Post(s)
Liked: 0
Do all these settings may cause conflict if i have enabled movie mode ( with callibration settings ) on my TV too? Should i leave the custom settings and normal mode?
lazostat is offline
post #4363 of 4367 Old 10-05-2017, 05:33 AM
jastonas's Avatar
Liked: 0
Hi, I just bought a used 50" 4k TV, Samsung UE50JU6400 (cant post url because of 0 points (( xxx.reevoo.com/p/samsung-ue50ju6400 ), and I was wondering if there is a fresh guide on setting up mpc-hc to play 4k content optimally. My PC is a i7-4770 // 16GB Ram // GTX 980
(PS. Where should I look for help on setting up my TV?)
jastonas is offline
post #4364 of 4367 Old Yesterday, 12:44 PM
mingus's Avatar
Quoted: 61 Post(s)
I would just use the sharks codecs. they work well and easy to set up.
my HTPC is not quite powerful enough to play 4k h.265 stuff. only Pentium CPU, but I do have GTX 1050 2gb graphics card, I figured that would be enough GPU, doesn't seem to get it. everything else works well. may try experimenting a bit.
mingus is offline
post #4365 of 4367 Old Yesterday, 10:57 PM
Liked: 0
any reason why my post never made it to the topic ?
Geoffxx is offline
post #4366 of 4367 Old Yesterday, 11:03 PM
Liked: 0
sorry never mind, got a little confused lol
Geoffxx is offline
post #4367 of 4367 Old Today, 04:28 AM
Brahmzy's Avatar
Quoted: 479 Post(s)
Liked: 368
IMO, my GTX 1060 6GB is the bare minimum card for 4K. 3GB isn’t enough and I can bury my 1060 with moderate settings pretty easily. That’s said, using profiles, 1 for 480 DVD and 1 for 1080 BD, I’ve got it looking pretty dialed.
MadVR makes most of my 1080 BDs look better than most of my 4K UHD BDs, minus HDR of course.
HTPC | 12TB NAS | Harmony Elite | DENON X4200W | Sony XBR75X940D
Philips BDP7501 | Klipsch RF7II,RC64II,CDT5650CII | SVS SB2000 x2
Brahmzy is online now
Reply Home Theater Computers
