Advanced MPC-HC Setup Guide - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 141Likes
post #541 of 4275 Old 12-22-2011, 07:48 PM
robl45's Avatar
Quoted: 184 Post(s)
i just tried this, with nvidia 23hz selected, i get frame drop every 2.88 min or so, is that right with 24p material? 24hz was worse so i assume this is correct?
robl45 is offline
post #542 of 4275 Old 12-23-2011, 09:53 AM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
Originally Posted by CZ Eddie View Post
Why do you mention FFdshow here? Are we supposed to be installing it?
oh, nice catch, i missed that.
before madvr had deinterlacing, you needed ffdshow or lav cuvid for deinterlacing.
MlNDBOMB is offline
post #543 of 4275 Old 12-24-2011, 07:57 AM
robl45's Avatar
Quoted: 184 Post(s)
did a lot of testing last night, the madvr seems pretty cool, but i'm still not sure what presentation glitches means. I was watching a 25p movie at 50hz and getting lots of presentation glitches , and when I tried it at 25hz, I got no presentation glitches but it was very obvious the movie was jittering.
robl45 is offline
post #544 of 4275 Old 12-24-2011, 08:35 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Simple: "presentation glitches" are glitches that happen somewhere in either Direct3D or in the GPU drivers, not in madVR. The answer may not be so helpful.
renethx is offline
post #545 of 4275 Old 12-24-2011, 08:51 AM
robl45's Avatar
Quoted: 184 Post(s)
cool, thank you for the answer. with 23.976, running the refresh rate right close to there, I had to customize the resolution to get it better, I don't seem to be getting presentation glitches and frame repeat or frame drop is like 1 every 25 minutes, I assume that is decent?
is there like a good set of settings or something to use?
robl45 is offline
post #546 of 4275 Old 12-24-2011, 09:07 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Yes, a frame drop per 25 minutes is good.
A 25p movie? I don't see such a BD movie. Is this a DVD 576i50 movie?
renethx is offline
post #547 of 4275 Old 12-24-2011, 12:38 PM
robl45's Avatar
Quoted: 184 Post(s)
some movies I have end up in 25p, not many, but I still have some.
robl45 is offline
post #548 of 4275 Old 12-24-2011, 11:49 PM
robl45's Avatar
Quoted: 184 Post(s)
i'm getting weird effects happening, its like a stutter and the movie repeats for a second or 2, happens maybe twice through a film, never saw that using evr custom, is there a way to fix that?
robl45 is offline
post #549 of 4275 Old 12-25-2011, 01:37 AM
CZ Eddie's Avatar
Quoted: 59 Post(s)
Liked: 33
Okay, so it's not something that is installed during your setup guide.
Dang, I was hoping I was missing something that might explain the problems I've been having.
Guess I'm back to blaming hardware mismatches then.
"The boom is dead, long live the bass"
CZ Eddie is offline
post #550 of 4275 Old 12-26-2011, 12:16 AM
rinorho's Avatar
Hi to All
There is a guide to configure MPC-HC with SVP ( SmoothVideo Project ) oriented to Blu-ray and DVD files?
I found this:
http://translate.google.com/translat...1%258F_ffdshow
but more important parts are in russian
Rino
rinorho is offline
post #551 of 4275 Old 12-26-2011, 07:51 AM
robl45's Avatar
Quoted: 184 Post(s)
so had it happen again last night. was about hour and 15 minutes into a film with 3 dropped frames in fullscreen mode. then I noticed the film stutter, checked the stats and it was up to 49 dropped frames. then film continued to play normally.
is anyone else using a nvidia gt430 card that has this working correctly? i see all these screenshots of 1 frame drop every hour or something like that and the best I can get is 1 frame drop every 38 minutes or so. I think i've tried 50 different resolution settings for 23.976 at this point.
robl45 is offline
post #552 of 4275 Old 12-26-2011, 11:16 PM
Ickibod's Avatar
I just did this all on Windows 7 on a GT555M, and I'm getting a ridiculously low framerate. And by that I mean I'm getting exactly 1fps, consistently. It's obvious I've done something wrong - is there anywhere I should start troubleshooting first?
Ickibod is offline
post #553 of 4275 Old 12-26-2011, 11:25 PM
Ickibod's Avatar
Below is the performance readout MPC-HC gives me, and everything seems to check out - video's still playing at 1fps, though. It's at the normal speed, but it only shows a frame about every second.
Ickibod is offline
post #554 of 4275 Old 12-27-2011, 04:01 AM
MakaKam's Avatar
Guys, what scaling algorithms should I set in madvr for watching blurays?
MakaKam is offline
post #555 of 4275 Old 12-27-2011, 06:43 AM
M.t.B.'s Avatar
Will mpc-hc ever support screensaver playback while pausing video? Out of the box would be nice to have. Nevertheless there is no resolution to achieve this with tweaks, or is it?
I'm using mpc-hc on my htpc connected to a plasma tv - ticklish issue
M.t.B. is offline
post #556 of 4275 Old 12-27-2011, 10:11 AM
rinorho's Avatar
Hi guys,
No setting for SVP (SmoothVideo Project) tool?
thanks
bye
rinorho is offline
post #557 of 4275 Old 12-27-2011, 12:42 PM
Qaq
Qaq's Avatar
@rinorho
You can ask Chainik in SmoothVideo Project (SVP)/Frame Interpolation (FI) from Russia thread.
Burned by the Audio Inquisition
Qaq is offline
post #558 of 4275 Old 12-27-2011, 05:39 PM
fairchild99's Avatar
Liked: 151
@Ickibod, try settings your chroma upscaling and luma upscaling + luma downscaling to Bilinear. You may also try checking some of the trade quality for performance settings. I suspect your video card is not strong enough for the default settings since your renderer and backbuffer queue are starved.
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
post #559 of 4275 Old 12-28-2011, 06:10 AM
rmmeli's Avatar
In the guide at the beginning it says to put WMVideo DMO ahead of LAV Video. Can someone explain the reasoning behind that please?
rmmeli is offline
post #560 of 4275 Old 12-28-2011, 06:38 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
WMVideo DMO supports interlaced VC-1, while LAV Video Decoder does not. An alternative is Intel software decoder built in madVR.
renethx is offline
post #561 of 4275 Old 12-28-2011, 06:50 AM
rmmeli's Avatar
Ok. Thanks for the info.
rmmeli is offline
post #562 of 4275 Old 12-29-2011, 08:06 AM
CZ Eddie's Avatar
Quoted: 59 Post(s)
Liked: 33
I fixed my WTV & MPC problem by using an older nVidia graphics driver.
Did another fresh install.
But I still get this error when trying to play .WTV files with MPC-HC x86.
MPC-HC plays my .mkv fine. It just wont' play the .WTV and I'm getting frustrated because my googling hasn't worked out yet.
Is there a codec I'm missing maybe?
I get audio but no video. And get this error that I posted a screenshot of.
The latest driver & MPC-HC version combo is giving me perfect video & audio playback on .WTV.
I still get the notification about pins, but after clicking "ok" on it the video plays perfectly.
  • 290.53-desktop-win7-winvista-64bit-international-beta
  • mpc-homecinema.1.5.3.3920_x86
CZ Eddie is offline
post #563 of 4275 Old 12-29-2011, 11:41 AM
lwong180's Avatar
what's a good alternative decoder and renderer for intel hd 2000?
lwong180 is offline
post #564 of 4275 Old 12-29-2011, 08:42 PM
CZ Eddie's Avatar
Quoted: 59 Post(s)
Liked: 33
It turns out there is an option in MPC-HC where you can disable any errors about pins. So after removing that option, I can start up & play WTV files without any problem now.
Anyone know how to make the mouse scroll wheel make the videos skip ahead or backwards like it does in JRiver?
CZ Eddie is offline
post #565 of 4275 Old 12-29-2011, 11:29 PM
jeff lam's Avatar
Can WTV files be launched to play in MPC-HC from Media Center's "Recorded Tv" list? Or do you have to set up the library in Media Browser?
jeff lam is offline
post #566 of 4275 Old 12-30-2011, 07:57 AM
Ruiner's Avatar
Am I accurate in assuming that LAV and madVR will not work properly on Zacate?
Ruiner is offline
post #567 of 4275 Old 12-30-2011, 08:53 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Yes.
renethx is offline
post #568 of 4275 Old 12-30-2011, 11:55 PM
thaxphenomx's Avatar
Try custom resolution of 23.978. There's also another number that is 1125 (can't remember) that I change to 1124. With those changes I get 1 frame drop every few hours.
thaxphenomx is offline
post #569 of 4275 Old 12-31-2011, 02:16 AM
CZ Eddie's Avatar
Quoted: 59 Post(s)
Liked: 33
I always open files from Windows Explorer. Never tried it anyway else.
CZ Eddie is offline
post #570 of 4275 Old 12-31-2011, 08:26 AM
robl45's Avatar
Quoted: 184 Post(s)
have that, in fact I chanted it to 23.979 as that seems to work better, but still best is 1 frame drop every 30 minutes. I watched one movie and it was like 4-5 frame drops through the whole movie, but other movies, there is a definate stutter effect and the frames jump drops shoot up like I mentioned before, I know its not the movies as its done that effect with 2-3 movies. I think the gt430 and x2 64 2200+ can't handle playing 1080p SBS.
robl45 is offline
Reply Home Theater Computers
