Advanced MPC-HC Setup Guide - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 139Likes
post #811 of 4248 Old 03-03-2012, 02:22 AM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
oh wait, you guys, i had the smart subtitle selection setup wrong, i should have wrote
eng:eng|f;engff;*:eng
MlNDBOMB is offline
post #812 of 4248 Old 03-03-2012, 03:10 AM
Peakki's Avatar
Hi!
I've Win7 x64 Ultimate, HD4890OC with the latest Ati drivers.
Everything has been set according to the first post in this thread.
But I'm missing subtitles with .mkv and .mp4 etc files!
I've tried to rename them according to movie file, putting to subfolder (subs) and played with the settings.
I tried fin:fin as also fin:fin||f;finff;*:fin, don't actually know how to set it right...
W and S keys seem to have no function, at least during playback.
Are .srt and .sub subtitles supported?
Any tips are welcome!
Peakki is offline
post #813 of 4248 Old 03-03-2012, 08:22 AM
Luis Gabriel Gerena's Avatar
Quoted: 94 Post(s)
Liked: 63
Originally Posted by MlNDBOMB View Post
sapphire makes a 6670 1gb gddr5 that is passively cooled for $100.
that should be fine for this for the most part. Might have problems with 1080p60.
also asus makes a passive gt 430 that is cheaper if you want to go the nvidia route, but I'm not sure if it is fast enough for some extreme cases. You might have to play around with scaling or deinterlacing, or overclock.
Well one thing I noticed..if I uncheck the option to go to exclusive mode when going to full screen then there are no hiccups, the movie runs smoothly all the way. I wonder what that option does and what am I missing..
Any ideas?
Mario Lemieux is GOD!
Go Pens!!!
Aguante Boca!!!
If dolphins are so smart...why do they live in igloos?
Luis Gabriel Gerena is offline
post #814 of 4248 Old 03-03-2012, 02:01 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
Originally Posted by Peakki View Post
Hi!
Options>playback> check autoload subtitles.
other than that, use up to date lav filters, madvr, and mpc hc.
MlNDBOMB is offline
post #815 of 4248 Old 03-04-2012, 01:21 PM
lordx2's Avatar
MadVR now utilizes the GPU - and supports subtitles.
What is the benefit to installing/using LAV filters?
lordx2 is offline
post #816 of 4248 Old 03-04-2012, 11:36 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
the short answer:
they do different things.
MlNDBOMB is offline
post #817 of 4248 Old 03-05-2012, 08:24 AM
chheber's Avatar
I use MPCHC (1.6.0.4014) on my HTPC and just started using the LAV filters (0.48). It seems if you use LAV (or any external filter?) MPCHC can't "remeber file poistion" anymore? If so it makes the HTPC useless IMO.
chheber is offline
post #818 of 4248 Old 03-05-2012, 08:31 AM
Quoted: 94 Post(s)
Liked: 63
I have two questions about audio.
1) Has anyone been able to get 7.1 audio using analog output? I can set it to 7 channels and doing the THX test within the X-FI configuration panel works fine but the movies only play using 5.1 instead.
2) Is using reclock going to degrade the sound quality of DolbyHD and DTS HD soundtracks?
Go Pens!!!
Aguante Boca!!!
post #819 of 4248 Old 03-05-2012, 08:32 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
What do you mean by this? I find my HTPC very usefull with LAV and MPC-HC.
Sammy2 is offline
post #820 of 4248 Old 03-05-2012, 08:40 AM
chheber's Avatar
It's a setting in MPCHC and is self-explanatory isn't it? Anyway, it makes it so you can resume video at the timestamp you closed it.
edit:
Seems the reason was the way I "exited" MPCHC with EventGhost, by killing the process. I changed it to ALT+X and it now remembers the position fine while using LAV. I don't remember why I setup the process way 2-3 years ago.
chheber is offline
post #821 of 4248 Old 03-05-2012, 08:57 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I hardly see that as making my HTPC useless...
Sammy2 is offline
post #822 of 4248 Old 03-05-2012, 10:39 PM
IrishRally's Avatar
Thanks for this guide. I've used the guide to set up MPC-HC on my htpc to yield results I'm very happy with.
I have a new computer now and would like to transfer over the exact MPC-HC setup so I don't have to go through all the hassle again. Am I better off just starting over?
IrishRally is offline
post #823 of 4248 Old 03-07-2012, 08:36 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Question on MPC-HC speed up and slow down keys..
Do these only adjust the video frame rate or is it both video and audio?
The reason I ask is because it seems that sometimes the two get out of sync. It was especially bad last night with my rip of J. Edgar. Maybe it was a bad rip, but I had to keep stopping the movie to adjust the audio offset. By the end of the movie I had it at 8000ms!
Sammy2 is offline
post #824 of 4248 Old 03-07-2012, 07:16 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Although I think I have a solution does anybody know the answer to this?
Sammy2 is offline
post #825 of 4248 Old 03-08-2012, 05:45 PM
lordx2's Avatar
So can anyone explain to me what LAV filters actually DO? And why they are superior to simply using FFDSHOW?
lordx2 is offline
post #826 of 4248 Old 03-08-2012, 05:54 PM
pokekevin's Avatar
Liked: 102
Aren't most tracks 5.1? Do you have your pre/pro / receiver set to use pl2x?
pokekevin is offline
post #827 of 4248 Old 03-08-2012, 11:14 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
Smart subtitle selection in lav splitter. I didn't think much of this when it first was added, but I cannot live without it now.
more hardware acceleration modes in lav video (nvida cuda, intel quicksync, renderer independent dxva)
dts-hd decoding possible in lav audio
up to 32 float output with intelligent output selection in lav audio
less bugs and problems in general i think
and all of the lav filters are fairly simple to configure.
MlNDBOMB is offline
post #828 of 4248 Old 03-08-2012, 11:30 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
it should be possible. make sure the movie you are watching has 7.1 sound. If it is dts-hd audio, you need that dll from the arcsoft player.
Also, make sure your sound card and windows is configured for 7.1.
And even if the movie doesn't have 7.1, you actually should be able to do an upmix with cmss with that sound card.
if you are bitstreaming them, no. If you aren't, it kinda depends on how much of a purist you are. One man's audio enhancement could be unnecessary processing for someone else. That's assuming you are using reclock to reclock audio. You can also use it simply for wasapi output. If you are doing that, then no, not really. As long as you have reclocking disabled and 24 bit output selected.
MlNDBOMB is offline
post #829 of 4248 Old 03-09-2012, 03:06 AM
DeathPoobar's Avatar
I'm glad you added the DVD workaround. However, I've found that some of my titles (both iso and folder format) will cause MPC to freeze. Not sure it's because of the player or FFDshow.
As this is advanced setup guide, I'd like to see some more options in MPC explained e.g. best settings for keys, refresh rate switching etc. I'm also having trouble with navigating menus in MPC and recall that there is another filter/plug-in you can use as a remedy.
DeathPoobar is offline
post #830 of 4248 Old 03-09-2012, 06:36 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Anyone?
Sammy2 is offline
post #831 of 4248 Old 03-10-2012, 01:48 PM
a1sy's Avatar
I am trying to install MPC and doing probably something stupid:
I install MPC-HC per 1st page guide , downloaded MadVR and installed it.
When open options in MPC, MadVR is grey out. How to make it enabled?
a1sy is offline
post #832 of 4248 Old 03-10-2012, 02:49 PM
pippipseed's Avatar
might be one of two :
Madvr not registered properly "run install.bat as admin"
You installed the x64 version of MPC-HC , madvr works only with 32 bit version
There might be another cause, but that's all I can guess
pippipseed is offline
post #833 of 4248 Old 03-10-2012, 03:58 PM
a1sy's Avatar
Yes, I am running Win 7 64 bit. So it's not supported?
a1sy is offline
post #834 of 4248 Old 03-10-2012, 04:17 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
install mpc hc 32 bit.
MlNDBOMB is offline
post #835 of 4248 Old 03-10-2012, 06:57 PM
a1sy's Avatar
I will try 32bit ver. Thank you
a1sy is offline
post #836 of 4248 Old 03-11-2012, 10:30 PM
skingery's Avatar
Also be sure you don't move MadVR after you install it.
Scott
www.techlifeweb.com | Twitter: @techlifeweb
skingery is offline
post #837 of 4248 Old 03-12-2012, 09:24 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Hey guys, I've always wanted to use MPC-HC as my default 'everything' player in my HTPC but I just couldn't managed to get them right in the past, but I like to revisit option again.
I've had issues particularly with audio bitstreaming in the past, when LAV wasn't around (or was not the reccomended option). Also, MPC-HC seemed to put out a bit dimmer image compared to TMT5 (and Win7 Media Player).
Here's my setup, and I would really appreciate suggestions/reccomendations on how to optimize my system with MPC-HC as the default player.
HTPC: Win7 64bit, Athlon II X4 630, 8GB RAM, ATI Radeon 5670, 64GB SSD for OS, 4TB for media storage
AVR: Integra DHC 9.9 pre/pro, Emotiva UPA-7 amp
Display: Epson 8100 projector, 90" Gray paint screen
HTPC > AVR > Projector all via HDMI
I have also heard that I need to change a few things in ATI Catalyst Control Panel in order for the HTPC to output the proper image?
Basically, what I like to do is have my HTPC output a 'natural' image without any processing, ehancing, etc, that is not necessary. I am calibrating my Epson 8100 PJ with a meter so I don't want the HTPC to be doing anything that would interfere with this process.
Thanks much everyone!
smokarz is offline
post #838 of 4248 Old 03-12-2012, 09:44 AM
maxleung's Avatar
Quoted: 22 Post(s)
A dimmer image may be because MPC-HC (or your renderer) is not configured to output PC levels instead of video levels.
For example, video levels is 16-235 range (when doing standard conversion to RGB), which will seem dimmer or washed out on a display calibrated for 0-255 (PC) levels.
I don't remember what TMT5 uses - it's probably doing 0-255 expansion.
Myself, I use LAV filters + MadVR with levels expansion to 0-255 (to be consistent with the desktop). The image is extremely good.
maxleung is offline
post #839 of 4248 Old 03-12-2012, 10:27 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
I took readings for a 100% IRE windows pattern from the AVSHD 709 disc, both with MPC-HC and TMT5 and noticed that TMT5 is about 1 foot lambert brighter, so I went ahead and calibrated my pj with TMT5.
What graphic card do you user? Did you adjust your graphic card driver settings?
smokarz is offline
post #840 of 4248 Old 03-12-2012, 11:04 AM
maxleung's Avatar
Quoted: 22 Post(s)
I don't remember if my nvidia card is set to pass video levels or not (application controlled or not) - but that doesn't matter as I use MadVR as the renderer with levels expansion (0-255) selected. If you don't use madvr you could tell MPC-HC to do levels expansion and you will get the same brightness as TMT5. You will have to experiment with this.
MadVR requires a somewhat beefy videocard, or at least one that has good shaders and onboard video decoding.
maxleung is offline
Reply Home Theater Computers
