Advanced MPC-HC Setup Guide - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 139Likes
Old 11-27-2012, 06:27 AM
pleh4help's Avatar
Originally Posted by MlNDBOMB View Post
so, when you are setting up lav audio, under bitstreaming formats, don't check anything.
What I did was checked them all, when I got the noise only, I unchecked them one by one, trying mpc after each, to no avail
Do you think setting it back up again, but this time with no checkmark in the first place would do a difference?
My setup:
TV: Samsung plasma 59" pn59d550, DVR: Cisco 8642HD, HTPC: Acer Aspire E1-570,
Peachtree audio DAC-iT, Logitech Harmony 650 remote, Logitech MediaBoard Pro Bluetooth k/b
Receiver: Harman Kardon HK 3490, Speakers: Mission m34i + Mission MS10 sub, Nexus 7 2nd gen
pleh4help is offline
Old 11-27-2012, 06:41 AM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
i think you have to restart the player after you make changes like that, so maybe that is why it didn't work when you did that.
MlNDBOMB is offline
Old 11-27-2012, 08:41 AM
pleh4help's Avatar
Thanks, I will retry it
My setup:
Old 11-27-2012, 09:26 AM
Postmoderndesign's Avatar
Quoted: 221 Post(s)
Liked: 85
Originally Posted by renethx View Post
Originally Posted by Sammy2 View Post
Support where? In LAV or MadVR or??
EDIT: I guess the above is a response to this using the latest MadVR:
I dont' have Radeon but rather nVidia GT-430. Any change there or does the latest MadVR still need GTX-660? I haven't bothered to install it yet because I don't have the h/w for it.
It depends on the algorithm you choose.
- GT 430 - GTX 650: good for Lanczos+AR / any except for Jinc (Luma / Chroma)
- GTX 650 Ti: good for Jinc3+AR / Jinc3+AR (Luma / Chroma)
- GTX 660: good for Jinc4+AR / Jinc4+AR (Luma / Chroma)
Do you think a GT 440 1GB GDDR5 could handle Jinc3+AR?
A search revealed that Madshi said GDDR5 increases speed but not quality so the answer seems to be stick to Lanczos+AR.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
Old 11-27-2012, 09:39 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
Most likely its too weak. People even said that a 550 was not up to the task.
Nevcairiel is offline
Old 11-27-2012, 10:24 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Originally Posted by Nevcairiel View Post
The new version doesn't need more performance by itself. You can still run it on on your GPU as before. There is simply a new scaling option called "Jinc", which may look better then the others, but it also requires some more steam.
So if you have a good GPU, you can switch the scaling algorithm to Jinc and enjoy a better image, or if you have a somewhat low GPU, you can simply use it with whatever scaling you had configured before. Its an optional new feature, it doesn't require more performance unless you use it.
I will probably just stick with the version I have now until I upgrade my video card. It looks fantastic as it is already.
Originally Posted by Heuer View Post
In my experience you can from within Media Browser (just point it at the Recorded TV folder in setup) and you also need to add and block 'Stream Buffer source' in MPC-HC. Can't say I am impressed by the results though as I get a lot of jerkiness (1080i 50hz BBC HD). Support for .wtv seems limited which has always struck me as odd, unless I am missing something and not found the relevant thread here or on Doom9!
I play RecordedTV just this way except for things marked with the CopyOnce flag. They won't play through any player but WMC.
wtv is a closed format from Microsoft only used by WMC, why would it be odd that such a closed format is poorly supported, when there are many standardized formats which just make much more sense to focus your development efforts on? tongue.gif
I am very pleased that you have put so much effort into LAV as I believe it is the premium splitter right now. Thank you. In a perfect world we wouldn't need to use WMC at all but in the real world those of us in the US using CableCARD tuners have no choice but to use WMC when it comes to playback of the previously mentioned CopyOnce CATV content. There are other PVR/EPG solutions but the only one that works with this particular LiveTV content is WMC. It is closed source maybe for this reason. It works pretty well for the most part, as it is just LiveTV and not blu-ray content, except that sticky 29/59 bug where the interlacing flag is not properly set by the content provider or whomever. This content is hard to watch without being put into a hypnotic trance. I was just thinking that your "aggressive" de-interlacer could help with this because of what you said about it working better with mis-set flags in the metadata.
Thanks again. I know it must get tiring posting this infor repeatedly. I think I'll be looking for a good deal on a low profile GTX 660, hopefully passively or quitely cooled, in the near future.
Sammy2 is offline
Old 11-29-2012, 02:35 AM
pleh4help's Avatar
You were right, it works without the bitstream formats checked and restarting the player; Thanks!
My setup:
Old 11-29-2012, 08:38 PM
squall12's Avatar
Hi guy,
Anyone know how to fixed tearing that fix on below video screen when using MPC-HC(Latest version) and only happen if the movie is running on 23hz on my samsung led tv and below is my setup.
1. Madvr - For Video
2. LAV- For codec
3. FFdshow - For audio
4. PC Spec
- Intel Core2Duo E6600 (2.4Ghz)
- 2GB Memory
- ATI 7750 - Latest ATI driver Version 12.10
- Window 7 Ultimate 32bit
squall12 is offline
Old 11-29-2012, 09:09 PM
vullcan's Avatar
to fix tearing try enabling vsync in your ATI drivers. If you game on this PC you may find you do not like having vsync "always on" and you can enable it on a per-program basis. I have mine enabled for chrome / firefox / ie and MPC-HC
vullcan is offline
Old 11-29-2012, 11:02 PM
squall12's Avatar
ok will try but it strange the tearing is always fix at below video screen not the usual tearing that moving up and down.
squall12 is offline
Old 11-30-2012, 10:11 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
squall, have you tried setting fullscreen exclusive mode in madvr? That should help fix any tearing.
JDLIVE is offline
Old 11-30-2012, 02:02 PM
vullcan's Avatar
Do you have to set that somewhere? When I double click MPC-HC it goes into full screen mode, the display flickers for a second and it says exclusive in the upper left corner.
I still got tearing in this mode.
vullcan is offline
Old 11-30-2012, 05:16 PM
squall12's Avatar
ok somehow tearing is fixed when change some setting on madvr and ati display setting lol thanks guy for the suggestion on the setting...next question what is the best setting for madvr which mainly use for playing mkv blu ray movie. (720p and 1080p)
squall12 is offline
Old 11-30-2012, 06:04 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
the only thing you would really want to change is the scaling if anything.
i think the defaults are pretty good, but a lot of people with high end graphics cards use jinc.
I don't really get too hung up on the scaling though.
MlNDBOMB is offline
Old 11-30-2012, 07:36 PM
squall12's Avatar
below is my pc spec and let me know which setting on madvr is best for me. Thanks
ATI 7750 with latest ati drivers.12.10 version
2GB Performance Ram
Windows 7 Ultimate 32bit
squall12 is offline
Old 11-30-2012, 07:37 PM
squall12's Avatar
also mainly use on blu ray rip which consist of 720p and 1080p. Thanks
squall12 is offline
Old 12-01-2012, 07:57 AM
alextheg's Avatar
Mindbomb, you are a star. followed your guideand my goals are now achieved. Bitstreaming all the way. A thousand thankyou's good sir cool.gif
alextheg is offline
Old 12-01-2012, 07:00 PM
vullcan's Avatar
I was a bit concerned after the windows 8 ffdshow talk a few pages back but just reporting I didnt have trouble as long as I installed the .bat's as administrator from the right click menu.
vullcan is offline
Old 12-01-2012, 07:29 PM
corpgator's Avatar
Jinc doesn't look that great actually. If you go through the madvr forum, they post some screen shots. It's better on some content, but you'll get better overall results with other filters. The highest jinc is especially bad.
corpgator is offline
Old 12-01-2012, 11:15 PM
fairchild99's Avatar
Liked: 151
chroma upscaling: catmull-rom
image upscaling: spline 3 with anti-ringing enabled
image downscaling: default (which is catmull-rom with anti-ringing enabled and linear light scaling enabled)
Sony 32" EX400 calibrated settings
Panasonic 50" S60 calibrated settings
HTPC/Sony S5100 to Sony HT-CT660 to Panasonic 55" VT60, Sony 32" EX400, Panasonic 50" S60
fairchild99 is offline
Old 12-02-2012, 03:39 AM
Eiffel's Avatar
Quoted: 13 Post(s)
2GB Performance Ram
With a Core2Duo E4300, Win 7 and a GT440, I get best results with Spline 3 + AR for both chroma and image upscaling (and Linear light for image). I don't use much downscaling as my displays are full HD.
I remember having to increase the number of video frames to be prepared in advance in exclusive mode, but this may no longer be needed.
Eiffel is offline
Old 12-02-2012, 07:49 PM
squall12's Avatar
ok thanks Eiffel and fairchild99.
squall12 is offline
Old 12-04-2012, 12:51 PM
justaquickie's Avatar
Anyone come across this and know a fix?
http://i.imgur.com/ADKqF.png?1
I was running this setup prior to uninstalling and now I get this when ever I install the x86 version. Can't seem to change it or go fullscreen.
justaquickie is offline
Old 12-04-2012, 01:10 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
hmm, i've never seen it like that before, don't know what to tell you.
In other news, playing around with my radeon 6310 some more, I've found that it can do 1080p up to 30 fps with madvr it seems, but with 1080i, hardware deinterlacing doubles the framerate and it can't render fast enough. I have to turn off interlacing in madvr to get it to play smoothly. I assume it will have problems with 1080p60 for the same reason.
MlNDBOMB is offline
Old 12-04-2012, 05:29 PM
ymarker's Avatar
Quoted: 28 Post(s)
So Core i5-2500k and a 60" Vizio LED that supports 24fps and allegedly 10bit, no discrete gpu, it looks decent but wondering if I can improve:
1) LAV video, should I use intel sync or DXVA?
2) madVR, if I use Jinc my render time exceeds 41.76 ms for 23.976fps.
Recs?
ymarker is offline
Old 12-04-2012, 07:37 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 81
i like quicksync best, but you can use dxva or none if you want.
for scaling on intel, i hear the new dxva scalers perform really well. Jinc is pretty hard even for discrete cards.
I wouldn't get hung up on trying to use the most complex scaling.
MlNDBOMB is offline
Old 12-05-2012, 05:08 AM
Right no worries, I filed a bug report over at sourceforge so should have an answer soon hopefully.
What setup would you recommend for the best visual quality using an i7 3820 + 7970?
Old 12-05-2012, 10:37 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Looks like you are in one of the built in editors, like the shader editor. If you close all those windows (little x in upper corner), does that fix things?
JDLIVE is offline
Old 12-05-2012, 10:58 AM
Here's the ticket I submitted earlier with a couple screenshots of closing the windows and the error I get when I try fullscreen.
https://sourceforge.net/apps/trac/mpc-hc/ticket/2756#comment:3
Edit: reinstalled AMD drivers and it's back to normal.
Old 12-08-2012, 12:46 AM
CoryW's Avatar
Quoted: 136 Post(s)
Liked: 97
I've followed all the instructions here for subtitles but it just won't load for Avatar...thoughts?
Cory
Audio: Ascend Acoutics, Sennheiser HD 598, Denon AVR-S710W
Video: JVC DLA-RS400, LG OLED B6, 92" Dark Energy Abyss screen, HTPC/MadVR/Darblet, Samsung UBD-K8500 UHD Player, HDFury Integral
CoryW is offline
