Advanced MPC-HC Setup Guide - Page 91 - AVS Forum | Home Theater Discussions And Reviews
 140Likes
post #2701 of 4260 Old 02-05-2014, 01:48 PM
steelman1991's Avatar
Quoted: 225 Post(s)
Liked: 118
Originally Posted by HDWorld View Post
i have added MPC BE audio renderer to external filters in MPC HC. When i do right click on MPC HC while watching a film i can see the filters madVR, lav filters, xysubfilter and MPC BE audio renderer which has WASAPI. Are there any drawback with this configuration?
Actually there is no need to even go that far - choose the MPC-HC Audio renderer (Options/Playback/Output/Audio Render/12. MPC-HC Audio Renderer) and you'll get WASAPI, without the need for the filter.
HDWorld likes this.
steelman1991 is online now
post #2702 of 4260 Old 02-05-2014, 02:06 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
no, don't do that. you need to use the one from mpc be.
MlNDBOMB is offline
post #2703 of 4260 Old 02-05-2014, 02:14 PM
Quoted: 225 Post(s)
Liked: 118
Why? I've had no issues using that one, but issues with the stand-alone mpc-be one?
post #2704 of 4260 Old 02-05-2014, 03:11 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
it's in a really bad state. It only actually worked with 16 bit stereo audio iirc, and even then there are issues with buffers or something, as the audio ends up having problems.
I'm guessing you just never had issues since you never played anything that was 16 bit stereo, so it never actually loaded.
MlNDBOMB is offline
post #2705 of 4260 Old 02-05-2014, 03:22 PM
Quoted: 225 Post(s)
Liked: 118
My only check/feedback was with LAV Audio/status, which always showed correct decoding from source to PCM (like for like), irrespective of Windows sound settings, therefore I assumed I was receiving WASAPI bit exact output. Is there any other way to test? just curious.
post #2706 of 4260 Old 02-05-2014, 03:22 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
i just tested the internal audio renderer with 16 and 24 bit and "no problem" i can't change the volume that's all.
mightyhuhn is offline
post #2707 of 4260 Old 02-05-2014, 06:33 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
the lav audio status only tells you what lav audio is doing. when you right click in the video and go to filters, you'll see that mpc audio renderer isn't there, unless you use the MPC BE one like HDWorld did.
if you check, you'll see that lav audio is only outputting 16 bit when it detects that renderer, and that renderer only loads when the audio is stereo. You'll get problems like sound loops on pauses and seeks, and pops for no reason iirc. I'm talking about the mpc audio renderer in mpc hc btw, the one in mpc be works perfectly.
MlNDBOMB is offline
post #2708 of 4260 Old 02-06-2014, 12:31 AM
Quoted: 225 Post(s)
Liked: 118
@MINDBOMB - see the screenshots below, they clearly show the MPC-HC Audio Renderer as a filter in WASAPI exclusive mode and the pin connection to LAV Audio.
Not attempting to undermine you or anything, just trying to clarify the position for myself and others. Can't say I've experienced any of the issues you describe, though I have with the MPC-BE renderer, as a stand-alone filter in MeediOS. I even posted about it on Doom9 and the MPC-BE dev bug tracker, neither of which even received an acknowledgement.
post #2709 of 4260 Old 02-06-2014, 05:10 AM
HDWorld's Avatar
I know, but i have had issues with MPC HC audio renderer (it even say, in a window, it is a broken renderer and don´t use it).
HDWorld is offline
post #2710 of 4260 Old 02-06-2014, 05:17 AM
Quoted: 225 Post(s)
Liked: 118
Appreciate that and I know what it says, but I'm not convinced that it isn't working properly - see my last screenshots. Though I'm happy for MINDBOMB to confirm and prove me wrong.
post #2711 of 4260 Old 02-06-2014, 06:14 AM
Quoted: 225 Post(s)
Liked: 118
@HDWorld - How did you get MPC-BE to install as an external filter - Having registered the filter (MpcAudioRendererFilter) I can't even see it on the list of filters in MPC-HC.
post #2712 of 4260 Old 02-06-2014, 06:25 AM
HDWorld's Avatar
Click -> Browse
HDWorld is offline
post #2713 of 4260 Old 02-06-2014, 06:28 AM
Quoted: 225 Post(s)
Liked: 118
Click -> Browse
Unless I'm really losing it here - that's the CoreAVC decoder you have highlighted, which has nothing to do with MPC-BE confused.gif
LOL yes I was losing it - sorry my bad. Got it from browsing to its location.
post #2714 of 4260 Old 02-06-2014, 10:51 AM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
nope it outputs 24 bit to the mpc hc audio renderer, i tested 5.1 too but i'm using a beyerdynamic mmx 300 and a asus essence stx so no real 5.1 but it seems to work fine.
ofc i can't say for sure if the renderer is outputing the 24 bit input to the soundcard but...
but i can reproduce the pauses/seek loop audio error this makes this renderer pretty useless.
i tested this with mpc-hc 1.7.1.383
post #2715 of 4260 Old 02-06-2014, 12:35 PM
wekya's Avatar
Quoted: 31 Post(s)
Originally Posted by wekya View Post
WOW! Frighteningly long thread.
Could an expert look at my signature and comment on the quality of my setup please? For the past several years I've been running MPCHC with stock settings (only DXVA) and no MadVR, ffmpeg, etc. I've simply been using only DXVA to play 1080p (and lesser) TV torrents/movies which played back near perfect, with only the slightest occasional stutter lately on some 1080p files. Tonight I tried to follow this guide, and nothing would play....but I would get a big red "OUT OF MEMORY" across a black screen, with the audio still playing.
I love the Revo HTPC because it sips power while torrenting 24/7, has an incredibly small footprint, is quiet, and puts out minimal heat, which is key here in the tropics. It has worked fine until I tried these tweaks. I'm hoping someone can point me to that last little bit I need as perhaps I've been (or the suggestions herein are) too aggressive in my approach by attempting to follow the OP's settings to the letter. Drivers for the Revo are not updated as often, but I have made sure they are the latest allowed by Nvidia for my chipset.
1 Is my rig under powered? I was basically trying to get the Ion to "CUDA" for me to try to eliminate the slight stutter, as I think DXVA may not fully utilize the Ion GPU. I felt spreading the load to both CPU and GPU would allow perfect playback despite my relatively humble hardware.
2 What might be some general useful enhancements for maxing out my hardware's capacity when using MPCHC? Am I better off with the simple DXVA settings? Is MadVR etc. only for more capable hardware?
P.S. What is SVP?
I would use cuvid in the video decoder along with hardware deinterlacing @25p/30p, and use bilinear scaling in madvr for chroma, image upscaling and image downscaling, with smooth motion off, and no image doubling or error diffusion (smooth motion, image doubling, and error diffusion are off by default). check if those settings work.
It seems to be OK for smooth motion with those settings on a very initial viewing, but I still get the red "out of memory" across the whole screen, and the dubug window pops up on the left top corner when playing a 1080p.mkv torrent. When doing a 720P.mkv it's OK, and the out of memory goes away after a few seconds. I do see some mention of frame buffers writing ahead (in settings, not the onscreen debug console), could that be the issue. GPUz shows around 490MB used of video memory and almost 100% GPU usage, where without madVR it's in the 40-60% GPU usage range, and a lot less RAM usage. The video RAM is shared btw. The debug window's first line says display 60Hz, but I can't seem to change it to 23 as I thought that might be the problem.
I think the settings you gave me are fairly low, so does my Revo just not have the power to use madVR?
Acer Revo RL100 HTPC Win7 64;1.3Hz Athlon II Neo K325 Dual Core;4GB 1,066MHz DDR3;512MB (shared) Nvidia GeForce GT9400 (Ion) OR Oppo 105D>Panasonic P50ST60.
Audio: Oppo 105D>Linn 6100/D>Aktiv Majik 109's(K600 and Linn silver RCA), OR Optical out from Oppo>Vizio S4251w-B4 5.1
Synology 215j, Asus N66U router
wekya is offline
post #2716 of 4260 Old 02-06-2014, 12:47 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
if you go to the rendering section in madvr, and lower gpu queues, you can lower vram usage. idk, try like 4?
I think your revo can use madvr as long as you are using some of the faster scaling methods, and none of the settings that eat into performance, like smooth motion and error diffusion.
MlNDBOMB is offline
post #2717 of 4260 Old 02-07-2014, 01:53 AM
fabriziorusso's Avatar
Hi everyone...
I have the i5 4670k
video card is :Asus 760 gtx directcu ii oc,
mainboard is :Asus z87-plus
Ram : 8Gb
Windows 7 64bit
For HT and stereo I use the computer
I connect with CHORD HDMI ADVANCE my PC to the Amplificator (Anthem MRX 710) and then to my TV.
With this configuration what are the best MPC-hc settings?
fabriziorusso is offline
post #2718 of 4260 Old 02-07-2014, 09:42 AM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
you can do everything in the first post except image doubling and error diffusion, which are not currently supported on nvidia cards, though error diffusion for nvidia will be in the next madvr build (87.5).
So you can bitstream all audio formats in the audio decoder if you want, and you can use jinc scaling as well in madvr.
MlNDBOMB is offline
post #2719 of 4260 Old 02-09-2014, 08:11 AM
DaveNY's Avatar
This guide was great, followed the instructions and MPC-HC is running great with DTS-HD audio. Currently I have 1 dropped frame every 8-9 minutes according to the readout when I press control+j with zero dropped frames.
DaveNY is offline
post #2720 of 4260 Old 02-09-2014, 09:13 AM
skaboy607's Avatar
Need some help please. Playing DTS audio seems to be fine but when playing dolby digital, it stutters almost like the signal is going on and off.
If I disable "built in audio switcher" then the opposite happens.
I have configured the audio according the guide in the link below.
http://www.ezoden.com/684/tutorial-htpc/13
I have optical cable between PC and amplifier and I have enabled bit streaming on dts and dolby.
Thanks in advance.
skaboy607 is offline
post #2721 of 4260 Old 02-09-2014, 04:39 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
i'm not sure. I would guess it's an issue with the audio renderer. I'd suggest you use this guide.
MlNDBOMB is offline
post #2722 of 4260 Old 02-09-2014, 11:41 PM
thong0803's Avatar
Hello
I installed MPC-HC, the output section, I share video using DirectShow Enhanced Video Renderer (custom)
I use Reclock audio renderer
I installed ReClock and adjust as instructed, but when I play video on Reclock icon is yellow, but when I play music icon green
Please help me, why I play video, Reclock does not work
thong0803 is offline
post #2723 of 4260 Old 02-10-2014, 03:36 AM
thong0803's Avatar
Originally Posted by thong0803 View Post
Hello
I do this
I turned on the Video and Reclock tray icon, show  up Reclock Properties.
right next to the Video stream and Audio stream If I to Automatic  then Reclock have yellow,but I also adjusted the manual then Reclock have green.
difference between yellow and blue is what?, why not choose  Automatic.
Slave reference clock to audio (debugging only) , what is it?
When I mark Slave reference clock to audio (debugging only), the parameters of  Clocks correction and Video hardware get changes, and If I adjusted the manual then Reclock have green then below When I mark Slave reference clock to audio (debugging only) then Reclock have yellow.
post #2724 of 4260 Old 02-10-2014, 02:37 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
To use reclock, you should have a display with a refresh rate that is roughly a multiple of the frame rate of the video. So, since most videos are ~24 fps you shouldn't be using it unless you have a display that supports 24hz, or a multiple of 24 (120hz, 144hz). With a 60hz display, I usually suggest madvr's smooth motion feature to take care of judder and not to use reclock.
thong0803 likes this.
MlNDBOMB is offline
post #2725 of 4260 Old 02-11-2014, 01:27 AM
AlwaysAngryGuy's Avatar
Anyone have any idea why 24 bit int padded to 32 in reclock would just suddenly stop working for me?
No changes to my computer or sound setup and it was working fine but now when I open any file I get:
Won't play any sound unless I change it to regular 24bit.
AlwaysAngryGuy is offline
post #2726 of 4260 Old 02-11-2014, 02:14 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
24 bit padded to 32 is the more common form for 24 bit audio. Idk, maybe another application had exclusive control of the device or you didn't give an earlier instance of mpc hc enough time to shut down fully. Or it crashed , in which case you have to kill the process.
MlNDBOMB is offline
post #2727 of 4260 Old 02-12-2014, 02:11 PM
Megalith's Avatar
Quoted: 20 Post(s)
I use a Radeon 5850 and have found that OpenCL error diffusion makes videos unwatchable. It makes the video look as if it is playing back at two or three frames per second. Is it really that demanding?
Megalith is offline
post #2728 of 4260 Old 02-12-2014, 04:18 PM
mightyhuhn's Avatar
Quoted: 737 Post(s)
Liked: 250
with smooth motion it's a lot
my 760 can handle 30 hz -> 120hz smooth motion (about 52 true fps)  jinc 3 ar ED on a 480p30 source with 20 ms without ED it's 10 ms.
post #2729 of 4260 Old 02-12-2014, 10:13 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
you'll probably be able to use error diffusion in the next build of madvr. the current opencl version effectively requires the gcn architecture.
MlNDBOMB is offline
post #2730 of 4260 Old 02-16-2014, 09:11 AM
Mirabela's Avatar
Hi all!
I have the following setup:
PC (Radeon 7950)->HDMI->Yamaha Receiver->5.1 Sound System+TV.
I use MPC-HC for movies, the latest version, with the LAV filters pre-installed. I have also installed separately MadVR although I'm not sure it was really necessary. Anyway, for a couple of days I encountered the following problem: on the receiver's display it now longer shows DTS, DD, DTS-HD or any kind of other message while playing movies, even though I do get some kind of multichannel sound since I can clearly hear the voices coming from the central speaker. The problem only appeared after my graphics driver crashed twice. I have since reinstalled everything, the latest drivers, MPC-HC, everything, but to no avail. MPC-HC is configured exactly as before, following this guide, I also made sure to check all bitstreaming boxes in LAV Audio, so on and so on. In Windows, in Playback Devices, I can see the receiver, it's configured properly (5.1), in Properties all the audio formats are listed (from simple DTS and Dolby Digital to Dolby TrueHD and DTS-HD). I don't understand why it's not working as before.
edit: I've just discovered a new problem: the volume control in MPC has absolutely no effect. So does the one in Windows. The only way to alter the volume is from the receiver. I'm guessing it's somehow related to the other issue.
Mirabela is offline
Reply Home Theater Computers
