Advanced MPC-HC Setup Guide - Page 97 - AVS Forum | Home Theater Discussions And Reviews
 142Likes
post #2881 of 4304 Old 04-11-2014, 12:30 AM
mightyhuhn's Avatar
Quoted: 757 Post(s)
Liked: 259
default mpc hc uses EVR and powerdvd uses either VMR9 or EVR so they look alike. follow the guide and try madvr. PQ shouldn't change when the decoder splitter is change only the renderer should have an effect. i'm not talking about subtitles and post progressing.
Would there be an advantage to using MPC over PowerDVD other than PQ?
it's free and can deal with a lot more codecs, subtitles and container. even the post progressing possibility are on a hole different level.
mightyhuhn is online now
post #2882 of 4304 Old 04-11-2014, 10:45 AM
morganf's Avatar
Quoted: 45 Post(s)
Liked: 24
Originally Posted by jhughy2010 View Post
Hey guys, I compared MPC-HC to PowerDVD 13 Ultra playback (a full rip MKV file ~ 22gb) and I couldn't tell a difference in playback quality.  Would there be an advantage to using MPC over PowerDVD other than PQ?
Cinavia, perhaps.
morganf is offline
post #2883 of 4304 Old 04-14-2014, 04:41 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
Originally Posted by JDLIVE View Post
Having some trouble with subtitles - I haven't watched a film where I needed them for quite a while, but I have "Jiro Dreams of Sushi" ripped to an M2TS file and subtitles aren't working. I'm using MadVR and the latest XY-Subfilter Beta. The PGS subtitles are there, verified by opening the file with Tsmuxer. But when I play the movie with MPC-HC, no subtitles display. I can see them using the Filters/LAV Splitter, but not if I use Filters/XY-Subfilter Beta. I've checked some other movies and most work but not all, so I'm a little confused. Any ideas?
you need to use the 32 bit version of xy subfilter. Other than that i dont know what could be causing it. Make sure the subs are selected in lav splitter, and enabled in xy subfilter. For subtitles to be enabled by default, you have to use the default flag in your mkv muxer when making the mkv. idk if there is an analogous feature in tsmuxer.
MlNDBOMB is offline
post #2884 of 4304 Old 04-14-2014, 07:14 PM
justinjames's Avatar
Stupid question - with MPC-HC are the subs in the same directory as the movie file? Maybe the subs aren't correct? Try downloading them from another place... I had an issue once where they were wrong... Just an idea
justinjames is offline
post #2885 of 4304 Old 04-15-2014, 07:58 AM
ricemanva's Avatar
Liked: 25
Need some help finding the right setting to change. When I start playing a movie or TV file, and when I close MPC-HC, my screen goes completely black for a second which I believe is because the refresh rate is being changed. I changed multiple settings in MPC-HC and madVR, but wasn't able to find the right one.
Software:
latest MPC-HC
latest madVR - image doubling set to NNEDI3 neurons 32 if scaling is 1.5 higher
no Reclock, audio bitstreamed
tried turning smooth motion off and on, no difference
no SVP
Hardware:
Amd 7850
Core i5
AMD CCC software - refresh rate set to 60Hz
Panasonic ST60
2808 Denon AVR connected with HDMI
When I hit ctrl+J, refresh rate is always 59.99 (top line of stats) regardless of frame rate of source (at least as far as I could tell. Checked 24 fps and 29 fps).
On at least 3 of the files the source rate was reported as 60.00 even when it was 23fps file.
Video looks fine, the screen blinking every time I start or exit is just very distracting.
Can someone help me find the setting that is making MPC-HC change the refresh rate of my screen every time it starts or exits?
Thanks for the help
ricemanva is offline
post #2886 of 4304 Old 04-15-2014, 08:36 AM
mightyhuhn's Avatar
Quoted: 757 Post(s)
Liked: 259
is "disable desktop composition" active under general settings? is "enable fullscreen exclusive mode" enabled under general settings?
by the way it is very important to change the refreshrate for perfect playback...
if you are on windows 8 there is a change madvr does this full automatic because windows 8 is not able to switch from 24 to 23 same for 60 and 59 so madvr takes care of this huge issue. but not sure if madvr only does this when both are listed in the "display modes"
post #2887 of 4304 Old 04-15-2014, 08:54 AM
ricemanva's Avatar
Liked: 25
I will check these settings when I get home. I should have put that I am using Windows 7.
Thanks for the help.
post #2888 of 4304 Old 04-15-2014, 09:48 AM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
I think it is the fullscreen exclusive mode setting, but I would advise you to leave it on and just get used to it, since it performs the best. The windowed overlay mode is an high performance alternative to fullscreen exclusive mode in the new madvr if I understand correctly, but only supports nvidia cards atm.
MlNDBOMB is offline
post #2889 of 4304 Old 04-15-2014, 10:17 AM
JDLIVE's Avatar
Quoted: 96 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
I am using the 32 bit version and it does show as a filter when I check while the film is playing. I watched it on another older HTPC with old versions of MPC-HC and MadVR (no xy subfilter) and they worked just fine, so the file seems to be OK. I did try re-muxing it as an MKV file, but that didn't help. I don't care about them being default or not, I can switch them if needed. But right now they just aren't working at all.
These are PGS subtitles, they are included as a stream in the M2TS file, not as external subs. I could try that option, but would rather get this working as it should.
JDLIVE is offline
post #2890 of 4304 Old 04-15-2014, 10:49 AM
Postmoderndesign's Avatar
Quoted: 282 Post(s)
Liked: 121
One thing I have noticed about xysubfilter is that I need to right click the playing movie and go to subtitles and turn the pgs subtitles on. I have not found a setting in MPC-HC which will automatically turn the subtitles on when using xysubfilter. I always turn the subtitles on. I always have the subtitles because I still use eac3to.exe to create .mkv files and I always include the subtitles. Sometimes I use to have to click on navigate and then subtitles.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #2891 of 4304 Old 04-16-2014, 10:01 AM
JDLIVE's Avatar
Quoted: 96 Post(s)
Liked: 51
Well I managed to get it working somehow. Although I was running a pretty recent version of MadVR, I installed the very latest and then installed xvsubfilter again. First tried it with an external .sub file and that worked. Then I tried the file by itself and was able to see the subtitles. So maybe the previous install of the filter didn't work, but it's fixed now.
JDLIVE is offline
post #2892 of 4304 Old 04-16-2014, 03:10 PM - Thread Starter
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 82
idk, it should always just work. Keep in mind that for mkv files, the creator decides whether the subs are played automatically with the default track flag.
MlNDBOMB is offline
post #2893 of 4304 Old 04-16-2014, 03:29 PM
Quoted: 282 Post(s)
Liked: 121
Interesting. I am sure you understand what I mean when I write that I am creating .mkv files with eac3to.exe and mkvmerge. I have been doing this for a very long time. But since beginning to use xysubfilter I need to set MPC-HC to show subtitles for each movie after it starts playing. I am not sure how to set a flag. Perhaps you can explain.
MPC_HC seems to be set to forced subtitles when I would like it to show all subtitles. Where can I change that?
post #2894 of 4304 Old 04-16-2014, 09:01 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Drag and drop a mkv file in mkvMerge GUI > File > Header Editor (or open it by File > Open). You can change / add a flag value.
renethx is offline
post #2895 of 4304 Old 04-17-2014, 12:34 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 217
Set up a keyboard shortcut in MPC-HC to turn subtitles on or to cycle between the subs. I have subs mapped to the channel up and down keys on my remote so I can change subs easily while the movie is playing without having to go into the menu.
StinDaWg is offline
post #2896 of 4304 Old 04-17-2014, 04:38 AM
mightyhuhn's Avatar
Quoted: 757 Post(s)
Liked: 259
the default subtitle change hotkey in mpc-hc is "s"
post #2897 of 4304 Old 04-17-2014, 05:46 AM
Quoted: 282 Post(s)
Liked: 121
Many approaches...many thanks. I think what I am looking for is setting the flag in mkvmerge since I always turn subtitles on. I admit that while I have used mkvmerge for many years I have not learned its many capabilities.
post #2898 of 4304 Old 04-19-2014, 11:35 PM
rexb610's Avatar
need help. mpc-hc randomly freezes and just shows black screen. I can't end task in task manager and can't go back to my desktop. Only way I can get out is to log out. I've re-installed mpc-hc and even updated my drivers. I'm using W8.1.
rexb610 is offline
post #2899 of 4304 Old 04-20-2014, 01:09 AM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
What has changed? Did you download something or move something right before this happened?
jhughy2010 is offline
post #2900 of 4304 Old 04-21-2014, 09:40 AM
dpoverlord's Avatar
Quoted: 23 Post(s)
Can someone help me with a bugging issue??
Q; Multi Monitor support - Enable 4 screens w/ Wallpaper or Background mode
How to set MPC to run on 4 screens in Wallpaper or Background mode?
I run Nvidia Surround + 1 = 4 monitors and the resolution is 4800 x 2560 or with 4 monitors 6400 x 2560. I want to run Full screen on all 4 monitors. The only problem so far that works is VLC by setting it to wallpaper mode. Mainly because windows sees the 3 monitors as 1 and the 4th as an accessory.
MPC only will allow full screen on 3 if you "stretch" it to the 4th it gets distorted.
Which puts me in a position A. Do I watch with VLC on 4 monitors or B. Do I watch MPC + SVP/reclock on 3?
I prefer 4 monitors but I cannot deny with this guide and SVP movies look AMAZING!!!
Any help on how to setup MPC or Potplayer on 4 monitors would be GREATLY APPRECIATED!
In my thread here I show this photo in how MPC distorts:
http://www.svp-team.com/forum/viewtopic.php?pid=40894#p40894
dpoverlord is offline
post #2901 of 4304 Old 04-21-2014, 12:55 PM
rexb610's Avatar
I think i've found a way to fix it. I turned off the view in fullscreen in the output of MPC-HC. But running it inside MediaBrowser3 as external plug-in it will still run it in fullscreen. After I turned off the option in MPC-HC, it now works and no more blank black screen and freezing. Thanks for the response.
rexb610 is offline
post #2902 of 4304 Old 04-21-2014, 10:16 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
Awesome. So you are running MPC-HC withing MB3?
post #2903 of 4304 Old 04-22-2014, 08:41 AM
dpoverlord's Avatar
Quoted: 23 Post(s)
anyone have luck with my question?
post #2904 of 4304 Old 04-22-2014, 09:38 AM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
I'm pretty sure most video cards only support 3 monitors total.
post #2905 of 4304 Old 04-22-2014, 10:06 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Radeon card supports 4 displays (EyeFinity). But you will need DisplayPort.
renethx is offline
post #2906 of 4304 Old 04-22-2014, 12:03 PM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
Modern NVIDIA cards also support 4 displays, but only 3 in surround and one separate, which sounds like what he is running.
Nevcairiel is offline
post #2907 of 4304 Old 04-22-2014, 05:47 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
The number of displays that can be turned to a single large display is Radeon: up to 6, GeForce: up to 3 (Quadro supports more by Mosaic).
renethx is offline
post #2908 of 4304 Old 04-22-2014, 11:41 PM
sonci's Avatar
I dont know why reclock icon stays always on yellow, I've tried everything,
Im using a samsung hdtv which currently change the resolution corresponding to the video,
The message on reclock says Cinema media adaptation: media speed changed to 24.000fps. Audio resampled at 48048Hz.
pressing CTRL+J:
display 23.96578Hz
movie 23.976fps (says source filter)..
But still icon is yellow and still I loose about a frame per 30sec.
Videocard is nvidia 8800gt, audiocard auzentech Prelude, windows 7x64 (all software x86)no bitstreaming,
Any help?
sonci is offline
post #2909 of 4304 Old 04-23-2014, 10:33 PM
nightfly85's Avatar
Quoted: 72 Post(s)
Liked: 43
There is a setting per devices, under the devices node that controls whether madvr changes to the closest matching refresh rate on start and optionally, returns to the existing on exit. They are both enabled by default.
nightfly85 is offline
post #2910 of 4304 Old 04-24-2014, 05:58 AM
Murilo's Avatar
Quoted: 134 Post(s)
Liked: 33
Dumb question but is their anyway with lav to bitstream lpcm audio? Seems any lpcm audio will only output whatever my speaker configuration is in windows. So if i set my speaker config in windows to 5.1, then 2 channel lpcm tracks on some old blurays are output as 5.1, and vice versa. If i set it to 2 channel in windows for music, it output lpcm 5.1 blurays as 2 channels.
And then if i set it 7.1 in windows, i cant use my avr processing (pro logic IIx) or anything on 5.1 or lesser tracks.
Besides using reclock that is, anyway to fix this within lav? Or do i have to hope media browser theater adds wasapi.
Murilo is offline
Reply Home Theater Computers
