Intel QuickSync Decoder - HW accelerated FFDShow decoder with video processing - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 295 Old 05-15-2012, 01:51 PM
Philip_L's Avatar
Quoted: 17 Post(s)
Liked: 30
Hi
Originally Posted by ericgur View Post
The Media SDK had a manual that covers the relevant encode parameters. I have no experience with encoding so I can't help. Sorry.
You should post questions on the Media SDK support forum
Thanks I will post a question over there.
I already reported the installer issue internally, a fix should be out soon. I don't know when. In the meantime, use v2696. The differences between them are small.
Update: the v2712 was removed from Intel's website.
I got 2712 installed all okay by just moving the Media SDK folder to the location the setup.exe was looking for it and that worked okay, obviously for most people they will not know to do this so good Intel has removed it pending a fix.
A question relating to decoding, is Windows Media Player using the hardware decoding provided by QuickSync? The reason I ask is I'm playing 1080/50p video (H264 Level 4.2) flawlessly with an i7 Ivy Bridge using the CPU graphics when on my prior computer with Nvidia graphics card and i5 (before Sandy Bridge so no QuickSync) couldn't play these files without serious judder and freezing. When playing these 1080/50p files the CPU is around 3 to 5% for the most part, and CPU remains in power-saving mode according to Intel's Turbo Boost real-time reporting app, so seemingly do very little work at all.
Regards
Phil
Philip_L is offline
post #212 of 295 Old 05-15-2012, 02:44 PM - Thread Starter
ericgur's Avatar
Windows media player will use Microsoft's own DXVA decoder (Microsoft DTV-DVD decoder). It's not the most robust decoder in the world though...
Other options are FFDShow or LAV filters, both support the QuickSync decoder (most stable and allows subtitles in any player) or LAV using DXVA. ffdshow-DXVA is not stable.
Eric Gur, Processor Client Application Engineer
Intel QuickSync Decoder author
Intel Corp.
ericgur is offline
post #213 of 295 Old 05-25-2012, 05:13 AM - Thread Starter
ericgur's Avatar
Version 0.32 beta is out with the following changes:
* Added HW deinterlacing - can't be disabled in this build. Works on content marked as interlaced. If this version give you problems, please report and revert to the previous version.
* Added support for HW Detail and Denoise filters. Disabled in this build. Need ffdshow GUI for these features.
* FFDShow rev4453
Downloads
* For the latest cutting edge FFDShow builds download my builds Intel QuickSync Decoder SourceForge home page
* FFDShow-tryout site
* LAV Splitter builds
Intel Corp.
ericgur is offline
post #214 of 295 Old 05-29-2012, 01:14 AM - Thread Starter
ericgur's Avatar
Version 0.33 beta is out with the following changes:
* Support for H264 frame doubling/tripling flags.
* Added forced DI mode - currently disabled.
* Added forced filter order - currently disabled.
* FFDShow rev4455
I'm working on adding GUI to ffdshow and then all new features will be enabled.
Downloads
Intel Corp.
ericgur is offline
post #215 of 295 Old 05-29-2012, 09:11 AM
Zhera's Avatar
Yes it is much faster. Especially for encoding. You can try one of the QS enabled transcode tools and compare results. You can get the app list here.
Note that my decoder will speed up decoding not encoding.
Well and update to my endeavors. I finally managed to work on continuing to get QSync to function. I installed the latest version of ffshow and LAV splitter as suggested and checked everything for QSync. Once I started the encoding process I saw a 25% reduction in CPU usage and only taxed the CPU to 75% now instead of 100% as before. Also saw a increase in compilation time from avg. 9-12 minutes for a 1.5g file (before the change) to 59 minutes with new changes. So there was slight gain but more loss then I was expecting.
Zhera is offline
post #216 of 295 Old 05-29-2012, 12:45 PM - Thread Starter
ericgur's Avatar
Can you describe your trasncoding flow (tools, scripts, content type, etc)?
Intel Corp.
ericgur is offline
post #217 of 295 Old 05-29-2012, 01:10 PM - Thread Starter
ericgur's Avatar
Version 0.33.1 beta is out with the following changes:
* Added forced DI mode.
* FFDShow rev4457 with new QuickSync config!
This version has the same QS decoder with upgraded ffdshow.
Control most QS decoder options, including video post processing via a new ffdshow configuration dialog. Look for a new entry just below "decoder options".
Visit the configuration once for your new settings to stick.
Downloads
Intel Corp.
ericgur is offline
post #218 of 295 Old 05-29-2012, 01:36 PM
Zhera's Avatar
That might be a lot bit easier said then done. Transcoding flow, I'm not sure what that means exactly.
System is a ASUS Maximus IV GEN Z/GEN 3, intel i5 2500k
Tools? Not sure what you mean but I was using only MultiAVCHD
Scripts? Don't know what you mean by this term
Content type? I'll take a stab at it meaning file, which was MK 1080p movie encoding. I think MK file.
Zhera is offline
post #219 of 295 Old 05-29-2012, 02:11 PM - Thread Starter
ericgur's Avatar
Sorry for the confusion
Content type is H264, 1080p, 30mbps (like in BluRay) or can be something more modest.
Some transcoding tasks are done via a collection of applications and avisynth scripts (MeGUI is a good example).
Some people just convert using commercial SW, some of which use HW encoding.
Usually the decoder takes a small part (time/cpu) of the encoding process.
If you meant MKV files, they are most likely H264.
Intel Corp.
ericgur is offline
post #220 of 295 Old 05-29-2012, 02:36 PM
Zhera's Avatar
Yeah MultiAVCHD is one of those SW apps but not commerical instead it's free and it incorporates ffdshow, Haali, AviSynth into an intuitive graphic GUI.
Plus no need to apologize, all this helps me to learn new terms and more about each.
Zhera is offline
post #221 of 295 Old 05-29-2012, 03:41 PM - Thread Starter
ericgur's Avatar
You need to make sure ffdshow outputs the color space avisynth expects (YV12), otherwise a lot of needless conversions will occur.
Intel Corp.
ericgur is offline
post #222 of 295 Old 05-30-2012, 07:36 AM
Zhera's Avatar
I'll give that a look and make changes as needed.
Zhera is offline
post #223 of 295 Old 05-30-2012, 07:55 AM - Thread Starter
ericgur's Avatar
FYI, all HW decoders output NV12 not YV12 and avisinth doesn't work in NV12.
Intel Corp.
ericgur is offline
post #224 of 295 Old 05-30-2012, 09:19 AM - Thread Starter
ericgur's Avatar
Version 0.34 beta is out with the following changes:
* Bugfixes.
* FFDShow rev4460 with improved QuickSync config
Note that official ffdshow builds from now will contain the QS config dialog.
Downloads
Intel Corp.
ericgur is offline
post #225 of 295 Old 06-04-2012, 01:49 PM - Thread Starter
ericgur's Avatar
Version 0.36 beta is out with the following changes:
* Bugfixes - DI was stalling or crashing.
* FFDShow rev4464
Downloads
Intel Corp.
ericgur is offline
post #226 of 295 Old 06-07-2012, 05:51 PM
xfett's Avatar
Ok just to clarify ...how many people can enable quicksync as an option using the LAV filters with a Celeron G530/G620...etc. Im getting into a pissing match on another forum where everyone is saying you can not use quicksync on any Celeron. I even posted a screen shot showing the LAV config with quicksync as an option.
"Man, I told you we shouldn't have shot Niedermeyer"
xfett is offline
post #227 of 295 Old 06-08-2012, 08:42 AM
Xaeon's Avatar
I can: ZPa6v.png
Xaeon is offline
post #228 of 295 Old 06-13-2012, 02:28 AM - Thread Starter
ericgur's Avatar
did anyone try the HW deinterlacing options (configured from fdshow's config dialog under Intel QuickSync Decoder)?
Intel Corp.
ericgur is offline
post #229 of 295 Old 06-13-2012, 08:41 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Video-mode HW deinterlacing works fine as it should do. (Pulldown detection does not work, however.)
renethx is offline
post #230 of 295 Old 06-13-2012, 01:45 PM
nxsfan's Avatar
Quoted: 24 Post(s)
Quicksync is selectable and works within the LAV decoder using a Pentium G850.
nxsfan is offline
post #231 of 295 Old 06-13-2012, 04:48 PM
xfett's Avatar
Thank you...
xfett is offline
post #232 of 295 Old 06-14-2012, 06:37 AM
netant's Avatar
Does this filter work within Metro environment?
netant is offline
post #233 of 295 Old 06-14-2012, 08:36 AM - Thread Starter
ericgur's Avatar
Will work only in desktop apps. That's the state today but Metro apps may be supported if the Intel Media SDK supports it.
Intel Corp.
ericgur is offline
post #234 of 295 Old 06-15-2012, 07:30 AM - Thread Starter
ericgur's Avatar
* FFDShow rev4464
Downloads
Intel Corp.
ericgur is offline
post #235 of 295 Old 06-17-2012, 10:20 AM
vad74's Avatar
Hello Ericgur. I try use Intel QuickSync Decoder. I use MPC-HC. CPU - Intel Core i3-2330M 2.2GHz with Intel HD Graphics 3000. OS - Windows-7 Ultimate x86 SP1. Play 1920x1080x50i 16Mbits/s video from camcoder Sony CX550.
I download ffdshow_rev4464_20120615_egur.exe from http://sourceforge.net/projects/qsdecoder/. I select QuickSync Decoder and use EVR, but play not smooth. After many experiments I found working configurations - ffdshow DXVA Decoder + EVR, and LAV Video Decoder + EVR. QuickSync Decoder load CPU for 20%, DXVA only 10%. FullHD video play smooth at both variants. But when I put USB-FLASH to my TV-set and run this video, TV play smoother and colors better. I posted this my settings, please check it. May be have errors, and need set or clear some checkbox.... I want that videoadapter switch output freq to freq of input video. Example: file is 50i, HDMI out is 50p; 25p -> 50p... Where I must set deinterlacing in settings for better quality? Or, HDMI can output 50i signal, and deinterlacing will be do in TV?
Click to green + to open info and screenshots. Media Info (Click to show)
General
Complete name : D:\Video\20110306175725.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 252 MiB
Duration : 2mn 2s
Overall bit rate mode : Variable
Overall bit rate : 17.3 Mbps
Maximum Overall bit rate : 18.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=13
Codec ID : 27
Duration : 2mn 2s
Bit rate mode : Variable
Bit rate : 16.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.309
Stream size : 235 MiB (93%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 129
Duration : 2mn 2s
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -80ms
Stream size : 6.53 MiB (3%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 2mn 1s
Intel(R) HD Graphics 3000 Driver report (Click to show)
Report Date: 6/17/2012
Report Time[hr:mm:ss]: 16:31:23
Driver Version: 8.15.10.2622
Operating System: Windows 7 Service Pack 1(6.1.7601)
Default Language: Russian (Russia)
DirectX* Version: 10.1
Physical Memory: 3493 MB
Minimum Graphics Memory: 64 MB
Maximum Graphics Memory: 1554 MB
Graphics Memory in Use: 8 MB
Processor: x86 Family 6 Model 42 Stepping 7
Processor Speed: 2195 MHz
Vendor ID: 8086
Device ID: 0116
Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics 3000
Video BIOS: 2119.0
Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Digital Televisions: 1
* Digital Television *
Monitor Name: Универсальный монитор PnP
Display Type: Digital
Gamma Value: 2,2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 40,16 inches
Vertical: 22,44 inches
Monitor Supported Modes:
640 by 480 (60 Hz)
800 by 600 (60 Hz)
1024 by 768 (60 Hz)
1280 by 720 (60 Hz)
1280 by 1024 (60 Hz)
1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4D D9 02 2C 01 01 01 01
01 15 01 03 80 66 39 78 0A 0D C9 A0 57 47 98 27
12 48 4C 21 08 00 81 80 01 01 01 01 01 01 01 01
01 01 01 01 01 01 02 3A 80 18 71 38 2D 40 58 2C
45 00 FA 3D 32 00 00 1E 01 1D 00 72 51 D0 1E 20
6E 28 55 00 FA 3D 32 00 00 1E 00 00 00 FC 00 53
4F 4E 59 20 54 56 0A 20 20 20 20 20 00 00 00 FD
00 30 3E 0E 46 0F 00 0A 20 20 20 20 20 20 01 55
02 03 3B F0 53 1F 10 14 05 13 04 20 22 3C 3E 12
16 03 07 11 15 02 06 01 26 09 07 07 15 07 50 83
01 00 00 74 03 0C 00 10 00 B8 2D 2F D0 0A 01 40
00 7F 20 30 70 80 90 76 E2 00 FB 02 3A 80 D0 72
38 2D 40 10 2C 45 80 FA 3D 32 00 00 1E 01 1D 00
BC 52 D0 1E 20 B8 28 55 40 FA 3D 32 00 00 1E 01
1D 80 D0 72 1C 16 20 10 2C 25 80 FA 3D 32 00 00
9E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F5
Internal Filters (Click to show)
482
External Filters (Click to show)
482
Output (Click to show)
482
FullScreen (Click to show)
482
Used Filters (Click to show)
415
LAV Splitter (Click to show)
700
LAV Video (Click to show)
467
LAV Audio (Click to show)
457
LAV CPU load (Click to show)
420
ffdshow QS CPU load (Click to show)
444
ffdshow DXVA CPU load (Click to show)
453
vad74 is offline
post #236 of 295 Old 06-17-2012, 12:06 PM - Thread Starter
ericgur's Avatar
CPU usage seems fine for a dual core running high bitrate clips.
LAV video decoder doesn't support QS deinterlacing yet. Only ffdshow.
By default DI is off, you can change it in ffdshow's config->Intel QuickSync, right under decoder options.
DI will add CPU usage due to more copying. If you don't subtitles, let EVR do the DI.
ffdshow-DXVA is not maintained by me and it's known to have problems. If DXVA is good for you, try LAV's implementation.
ATM, I don't expose DXVA surfaces to the renderer. Instead I copy them to system memory, impersonating a SW decoder.
Adding more EVR buffers (MPC-HC output) may help stability. Give it a try.
I don't see the difference as to why colors are different when running from USB, it doesn't make any sense to me. Unless it's a really slow USB stick, playback should be smooth in all cases.
Intel Corp.
ericgur is offline
post #237 of 295 Old 06-18-2012, 10:55 PM
vad74's Avatar
I try LAV's implementation, it work very well. I dont understand why ffdshow QS decoder dont play smooth.
Checkbox "Aggressive deinterlacing" in LAV Video dont work when select QuickSync decoder?
In Output Formats in LAV Video may be better select only NV12 and clear other checkbox, or not?
vad74 is offline
post #238 of 295 Old 06-19-2012, 06:57 AM - Thread Starter
ericgur's Avatar
It works smooth for me and most users. If it doesn't for you, please share a clip.
I don't know what LAV is doing with aggressive deinterlacing.
NV12 is the preferred format for HW acceleration and usually asked for by EVR automatically. Some players will tell you what's the connection type.
Intel Corp.
ericgur is offline
post #239 of 295 Old 06-19-2012, 12:24 PM
augerpro's Avatar
Quoted: 126 Post(s)
Liked: 66
Ericgur I wonder if you could answer a question I had around the h264 preset profiles used by QS. In programs such as Arcsoft Mediaconverter the only "handle"you have, other than bitrate, is a general quality setting. As you change this setting what are the changes to the actual h264 presets? If I set max quality for example, what is the preset profile QS uses (talking Ivy Bridge here)? Thanks
augerpro is online now
post #240 of 295 Old 06-19-2012, 01:03 PM - Thread Starter
ericgur's Avatar
Sorry, I have zero experience with the encoder. You can ask in the Media SDK forum.
Intel Corp.
ericgur is offline
Reply Home Theater Computers
