advice needed: DIY laptop -> digital pictureframe, internet radio, alarm clock - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 09-08-2011, 01:19 PM - Thread Starter
bearcat77070's Avatar
I have access to a large array of laptops in various degrees of assembly, everything from netbooks up to a 20" display. I've been thinking about taking one and turning it into a digital pictureframe on steroids - one that will sit on a nightstand and double as an alarm clock, cd player, internet radio, etc. To start with I'll probably just use some amplified speakers, if it works well I may spring for some wireless ones (bluetooth?).
In any event, for controling it, I'm thinking about a mix of IR, maybe touchscreen, and/or a trackball.
Has anyone here already done a project like this and have any advice as to what worked well and what didn't?
I like the idea of using a touchscreen (I can use something like a HP Elitebook 2730 or 2740) as that way there's always some degree of control, no hunting around for a remote. Does anyone know of a good way to either integrate the different functions (internet radio, cd player, picture display) - is Win7 media player up to the task? I have pc IR remotes with some media center dedicated buttons, I suspect between that and something that lets me customize the way the unit handles IR will be the way to go. Are there any sort of plug-ins (like an alarm clock) in media player?
Thanks for any and all suggestions!
bearcat77070 is offline
Reply Home Theater Computers
