Remote Controls - AVS Forum | Home Theater Discussions And Reviews
Old 09-11-2011, 01:02 PM - Thread Starter
Neimad's Avatar
Hi all,
I'm new here and to the idea of media pc's in general so I thought I'd seek some expert guidance with one thing that I can't seem to find a good answer for, that being media centre remote controls which can control the mouse too.
I've seen a few possibilities, some of which don't seem to be available any more and others which are little more than hacks.
One of the few that seems like it could work is the Fractal Design Shape remote control, but I can't seem to find any information on how good/easy it is to use in reality, it also seems like they may have discontinued it although I can still find a few places stocking it.
Any suggestions would be much appreciated -- I'm located in the UK which may also reduce the options I have.
Neimad is offline
Old 09-12-2011, 03:45 PM
jobber777's Avatar
hey there, if you have an android based phone, the ''universal remote'' app works really good over your wifi network. You can use your phone as a mouse pad, keyboard, number pad, and has preset layouts.
The xbmc app for your phone is awesome if you use xbmc. Though it doesn't have a mouse capabilities, the ability to have access to your entire media library on your phone is just so cool.
As far as physical remotes, I just bought a remote with a mouse function that costed me $7us. Works awesome. Cheap looking and feeling, but just works.
jobber777 is offline
Old 09-12-2011, 03:54 PM
jobber777's Avatar
search ''wireless usb pc remote control mouse for pc''
Old 09-12-2011, 07:38 PM
gonzo90017's Avatar
Quoted: 42 Post(s)
The ZVRemote works great.
gonzo90017 is offline
Old 09-15-2011, 01:38 PM
snakyjake's Avatar
This is the best I've seen:
snakyjake is offline
Old 09-15-2011, 01:42 PM
gtgray's Avatar
Quoted: 206 Post(s)
Liked: 136
I want a remote that is a full 5 or more device univeral remote, full air mouse capabilities, and has a traditional WMC remote layout including the Green button and all the standard MC controls in the standard positions. Oh and I want to be a learning remote and actually have a decent library of codes not like the Gyration crap with extra buttons free to assign.
Don't want much do I?
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
Old 09-15-2011, 01:59 PM
snakyjake's Avatar
@gtgray. You are not alone!
My HTPC is too complicated for my family to use (and sometimes I wonder if it is worth the money and hassle). A remote should be simple and have the most used functions.
When I need something more functional, I grab my wireless keyboard.
When I administer the HTPC, I simply remote into it.
A remote without a mouse is VERY limited. Especially with Hulu's UI button locations. Or when you get dropped out of an application into the OS. Or when a pop-up dialog appears.
But I'm not willing to pay a lot for this. To me, this should be very basic, with a basic price.
Old 09-15-2011, 04:34 PM
jriver's Avatar
Quoted: 91 Post(s)
Liked: 69
An Android tablet makes a nice remote. You don't need a mouse since it's a touch screen.
A straight Media Center remote is also nice, but isn't as family friendly as the Android solution.
Jim Hillegass / JRiver Media Center
jriver.com or Owners Thread at AVSForum
jriver is offline
Old 09-15-2011, 05:40 PM
ekscden's Avatar
http://www.amazon.com/Windows-Contro...6129971&sr=8-1
I use a few of these with great results and full mouse functionality with the middle pad.
ekscden is offline
Old 09-17-2011, 01:58 AM - Thread Starter
Neimad's Avatar
Thanks for all the replies so far -- some good ideas and certainly things I haven't seen before.
Unfortunately the Android option is out -- I'm not a big fan of smart phones and my dumb phone does everything I need of it.
The Motorola remote looks awesome, shame about the supply issues but then since I'm only just starting to put a build together maybe they'll be sorted by the time I need something.
The motherboard I just bought (ASUS F1A75-I Deluxe) actually comes with a remote (although I've heard it's pretty bad) so I guess I'll see how I get on and then revisit the topic later if need be.
Thanks everyone!
Neimad is offline
Old 09-17-2011, 07:03 AM
jriver's Avatar
Quoted: 91 Post(s)
Liked: 69
There are a lot of tablets coming out now. They aren't phones. They're similar to the iPad. Samsung Galaxy Tab's, for example. I realize you're probably not interested. In my opinion, they are game changes as remotes. In an HTPC setting, you can leave the TV off and still select music easily.
jriver is offline
