NAS or external hard drive via SATA.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-13-2011, 09:58 AM - Thread Starter
vzphoneman's Avatar
Quoted: 101 Post(s)
Liked: 100
I need to expand my hard drive space for music file storage. Presently I only play the music on the computer they are stored in but it may be nice to have it as a option to have the music networked in the future. I'm looking to expand from 2gig's now to 4gig via a 2 or 4 bay external enclosure (computer is pretty full). I might do the 4 bay for future expansion, and or raid. With the cost of 2gig drive so low I am going to use them instead of single 3-4 gig drive. Are there any advantages to using a NAS over a SATA connection or even USB? I would like to have it look like one big drive to the computer but that's not critical. Also, I do run my network through a gigaport switch. Thanks for any thoughts you can offer me.
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is offline
post #2 of 2 Old 09-13-2011, 10:18 AM
Nebiroth's Avatar
Liked: 30
It seems to me that a NAS would be overkill for what you need. You'd be spending more to gain not much, since all you want is more storage and you don;t need to share it between multiple boxes. Espescially if you're looking to buy a solution rather than build your own. A simple DAS will suffice and be cheaper. Essentially this just adds a bunch of hard-drives to your PC - in an external enclosure, usually connected by eSATA or USB (which ideally is 3.0). If you haven't either of these in your PC expansion cards are easy and cheap - a lot of the enclosures come supplied with an eSATA card anyway. You can configure most of them as a RAID array - if you're willing to risk losses you can set that up to appear as just one big drive without any data protection (though I personally wouldn't!)
Sans Digital do some nice 4-drive enclosures
Like you say, at present 2Tb drives offer the best storage-price; however, larger drives need to be considered if you get to the point where it;s a choice between one enclosure filled with 3Tb drives or having to buy two enclosures using 2Tb drives. It doesn;t sound like you need that though. Yet (evil laugh)
Nebiroth is offline
Reply Home Theater Computers
