XBMC IR options - AVS Forum | Home Theater Discussions And Reviews
Old 09-16-2011, 04:56 PM - Thread Starter
Brad Horstkotte's Avatar
Liked: 68
I have a Windows HTPC running XBMC, and I'd like to control it using my Harmony remote. I'm looking for suggestions for IR receivers that I can use - or IR receivers that come with MCE remotes.
Came across this one - anyone have any experience with it? Good, bad? Other suggestions?
http://www.amazon.com/Windows-Contro...p_ob_e_title_0
Brad Horstkotte is offline
Old 09-16-2011, 07:00 PM
bryansj's Avatar
Quoted: 1151 Post(s)
Liked: 567
That would work, but you don't need the remote since you have a universal.
The HP Media Center IR Receiver on eBay works well and can be purchased for ~$10 shipped.
bryansj is offline
Old 09-17-2011, 07:41 PM - Thread Starter
Liked: 68
Thanks Bryan, I'll give that a shot.
Old 09-23-2011, 10:14 AM - Thread Starter
Liked: 68
Just to close this out, got my $10 IR receiver (eBay), set it up, and everything is working great. This was a useful thread to get me started (key mappings):
http://forum.xbmc.org/showthread.php?t=54466&page=19
Old 09-23-2011, 10:53 AM
bryansj's Avatar
Liked: 567
Look at this if you haven't already. Lots of Harmony codes for the MCE remote.
http://forums.logitech.com/t5/Harmon...ur/td-p/374844
bryansj is offline
