HTPC - Turning on and off with Remote Control? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 10-17-2011, 11:20 AM
djearl81's Avatar
Quoted: 12 Post(s)
Interesting topic. Thanks for posting all the information and options.
I too have my HTPC in the basement with an IR repeater system. I went with the "leave HTPC on all the time route". I run windows 7 from an SSD and power down the storage drives after 10 minutes of inactivity.
Just for kicks, would there be an advantage to turning off the entire system over just powering down the disks? (Assuming fans only run above set temps.) What about other tasks like all the windows updates and antivirus updates? If you power up the PC at 5pm, I'd think you'd be met with updates more often than not.
You can set your harmony remote to use the "end" key to shutdown xbmc. There is also a blog with an install package to overwrite the windows MCE remote button to start xbmc.
http://inchoatethoughts.com/launchin...-center-remote
Very interested in this thread....
I'm confused too.
djearl81 is offline
post #32 of 37 Old 10-17-2011, 12:13 PM - Thread Starter
dugan26's Avatar
Powering down the disks would def. be more preferable for me - but I could not seem to "wake them" with an IR command -
dugan26 is offline
post #33 of 37 Old 10-17-2011, 01:05 PM
djearl81's Avatar
Quoted: 12 Post(s)
Is your xbmc instance on the same drive as your movies/pics/music? I can understand not wanting to spin down your OS drive without putting the whole pc to sleep.
The drives will wake up automatically when they are accessed again. Granted it takes a few extra seconds to spin up, but not nearly the time it takes to boot up from a cold start.
I'm confused too.
djearl81 is offline
post #34 of 37 Old 10-17-2011, 02:26 PM
HDmakeitso's Avatar
Did you ever hook this up?
I got one of those last week. I put it inside the case and drilled a hole for the receiver. Works perfect. Suprisingly wide range of positions it will see the remote commands from also. I was epecting to have to have the remote pointed just right but that's not the case.
I am happy with it and have less cables to deal with. From my couch I can't even see the hole I made in the case at all. Right now the case is outside the entertainment system.
I would recommend it. I think they all come with a cable to connect to the motherboard but make sure you get one that has one. I got the remote with it too. The remote is pretty good.
HDmakeitso is offline
post #35 of 37 Old 03-23-2013, 08:25 AM
dacica's Avatar
Hello dear friends,
I really need your advice for a buy. A few weeks ago I decided to make the transition from a dedicated tvix media player and make a HTPC in order to have a full support in what media center experience has to offer. I decided for a hardware based on:
Processor: AMD A6 3500 2.1Ghz 3-core Socket FM1 HD6530D
Motherboard: Asrock A75-PRO4-M with CIR header
Memory: 2x2GB or 2x4GB DDR3 1600MHz
The system will run on Windows 8 and XBMC.
My wish is to have a HTPC that can be totally controlled remotely. I'm reading forums for the last 3 weeks and I'm still not sure what remote control and IR receiver to choose. The main function that I look for is the power on/off option from the remote control button and full compatibility with XBMC and Win 8 without having to reprogram and change the commands of the remote control, I'm not good with that.
As I understood so far my best options are: Inteset receiver/remote ; HDPlex remote/receiver . The only problem is that I have to order one of these from US, being in Europe and I don't know which one makes a good job.
My other unsure options are: iMon Inside ; MCE remote/receiver like Hama 52451 ; or IR receiver and Logitech Harmony® 300 Remote
I still don't know which one of these options can offer me for sure the power on/off option. Can someone give me a good advice about this?
Thank you guys so much
dacica is offline
post #36 of 37 Old 03-24-2013, 04:29 AM
Eiffel's Avatar
Quoted: 13 Post(s)
HDPlex can ship from Continental Europe (I go my HD5 in the UK this way). Works well with one exception: pressing the number keys in MCE won't allow to enter text in search boxes (which is a minor inconvenience).
Eiffel is offline
post #37 of 37 Old 05-01-2013, 05:53 AM
tahn's Avatar
have a look at simerec or rfpcremote.com. They only turn your pc on and off. Other controls can be can be done with a programmable wireless mouse / keyboard.
tahn is offline
Reply Home Theater Computers
