Best remote for <40$ ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-29-2011, 07:46 AM - Thread Starter
Nuke142's Avatar
What remote is best choice for our days from ebay/amazon? Have 40$.
Nuke142 is offline
post #2 of 10 Old 09-29-2011, 07:55 AM
Calcvictim's Avatar
Calcvictim is offline
post #3 of 10 Old 09-29-2011, 09:00 AM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 108
I would really suggest a trip down to the "remotes" forum section.
That is where you will find good advice on universal remotes, but also leads to good places to buy them.
-Suntan
Suntan is offline
post #4 of 10 Old 09-29-2011, 11:06 AM
hanly2's Avatar
Is that harmony remote capable of rf or are they all ir?
hanly2 is offline
post #5 of 10 Old 09-29-2011, 11:30 AM
bryansj's Avatar
Quoted: 1134 Post(s)
Liked: 560
IR only. The Harmony 890, 895, 900, 1000, and 1100 are the only RF Harmony remotes. There is also the new Harmony Link which I guess you would consider RF since it uses your phone/tablet's WiFi.
Does the OP even want a universal remote? Or are you just looking for a good MCE remote? Once you factor in ~$10 for your USB IR receiver you are left with <$30 for your remote.
bryansj is online now
post #6 of 10 Old 09-29-2011, 11:55 AM
Derek K.'s Avatar
this one is supposed to be pretty good. $20.
http://www.amazon.com/Universal-Cont...7318837&sr=8-3
Derek K. is offline
post #7 of 10 Old 09-29-2011, 12:41 PM - Thread Starter
Nuke142's Avatar
Need good MCE for htpc.
I've found something but what is better?
http://ebay.com/itm/320754375479
http://ebay.com/itm/220840579407
http://ebay.com/itm/220751406269
http://ebay.com/itm/260849620746
http://ebay.com/itm/150469865765
http://ebay.com/itm/120686629389
Nuke142 is offline
post #8 of 10 Old 09-29-2011, 12:56 PM
bryansj's Avatar
Liked: 560
Your links seem to be dead.
I'd get the HP Media Center IR Receiver from eBay and pair it with any universal remote that you can afford with the money leftover.
post #9 of 10 Old 09-29-2011, 01:27 PM - Thread Starter
Nuke142's Avatar
Nuke142 is offline
post #10 of 10 Old 09-29-2011, 02:38 PM
bryansj's Avatar
Liked: 560
I'd go with the HP one, second link. However, neither of those should be considered "best". They'd get the job done and are cheap. If you are trying to control a TV and AVR then you'd be better off with a universal.
Reply Home Theater Computers
