Streacom FC8 fanless mITX Build - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 66 Old 11-17-2012, 10:34 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
March 2013?! Ugh... I'll go out of business before then...
StardogChampion is offline
post #62 of 66 Old 05-25-2013, 08:27 AM
mulluysavage's Avatar
In fabless systems with HDDs, how are people cooling the drives? I see heatsinks and pipes on processors, but HDDs generate a lot of heat and keeping them cool will prolong their lives, are people heat sinking these too?
mulluysavage is offline
post #63 of 66 Old 05-25-2013, 08:27 AM
In fanless systems with HDDs, how are people cooling the drives? I see heatsinks and pipes on processors, but HDDs generate a lot of heat and keeping them cool will prolong their lives, are people heat sinking these too?
post #64 of 66 Old 05-25-2013, 10:35 AM
ccrocker001's Avatar
Use an SSD drive instead of a traditional hard drive and then you don't need to worry about heat.
EDIT: Sorry I didn't answer your specific HDD question. Maybe someone else has experience with HDDs. I have a Streacom FC5 case and it gets pretty warm under load. I can't imagine putting in a traditional hard drive that would add to the heat. Maybe it would work if you could add a heat sink with heat pipes attached to the side of the case to dissipate the heat. http://www.meedios.com/EN/forum/viewtopic.php?f=25&t=7682
ccrocker001 is offline
post #65 of 66 Old 06-04-2013, 02:50 AM
philjwb's Avatar
Regarding cooling of hard drives in the FC8 fanless case, I have found this to be a significant issue.
My original system was FC8 with GA-A75N-USB3 and A8-3820 processor (fastest 65W processor I could find). I installed a SSD drive for the OS and a WD green HDD for storage. But the HDD was running pretty warm and after a few months it failed. I swapped in a replacement and that also failed after a few months, so I now have an external USB HDD for storage and this has been solid as a rock for 6 months now...
philjwb is offline
post #66 of 66 Old 01-05-2014, 07:00 AM
digzz's Avatar
I have the same case running a Intel Core i7 4770S 3.10GHz.
Are these temps ok ?
digzz is offline
Reply Home Theater Computers
