HTPC + Kill-A-Watt: Power usage thread (With Pics) - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 186 Old 03-06-2013, 12:49 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
Originally Posted by Dark_Slayer View Post
  • relativity - maybe it doesn't make sense to compare things on this forum, but it's not as bad since most of us are testing under 100W. What I saw indicated it's pretty poor the higher you go, but the lower your power the less difference 10% can make. 50 or 55, I don't really care. 50 or 100 and I can make a decent comparison. I can compare my AVR, TV, PC, etc with the same meter and they should be in the appropriate order even if they are phase shifted by inaccuracy
+1 on this. I use my Kill-a-Watt more to see if something weird is going on. If I build 5 systems that use 20W and the sixth (same components) is pulling 40W I known something is up somewhere. It's the same way I use reported temps and WEI -- more as a comparison tool to tell me if something's up not for the absolute values.
StardogChampion is offline
post #182 of 186 Old 03-06-2013, 01:15 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
Originally Posted by AnthonyB View Post
Oh.. That is why I don't sleep it.. X10/YAC
Glad I replaced my e6600. Also replaced my Opteron server with an Intel. Hopefully that will bring the power bill down some.
Just set up Plex and quit converting your movies to iPad friendly size/resolutions, I think you can use Fing, RemoteBoot, or Wake in iOS for remote WoL (WoW)
Dark_Slayer is online now
post #183 of 186 Old 03-06-2013, 01:37 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Are there android apps to issue WOL magic packets to your HTPC or PC from a phone/tablet either WiFi or 3g/4g?
Sammy2 is offline
post #184 of 186 Old 03-06-2013, 01:54 PM
Quoted: 655 Post(s)
Liked: 434
There are a lot more for Android than iOS. Fing was initially an Android app
Pure WOL should have more options available than WOW, but I have used Fing for WOW
post #185 of 186 Old 03-06-2013, 02:59 PM
AnthonyB's Avatar
Umm.... X10 and YAC have nothing to do with Android or iPad. It's a home automaton system. When a motion sensor is tripped it triggers events on my computer like a text message on the screen that its been tripped. And that is through YAC and Tapirex and it serves computers around the house to notify.
AnthonyB is offline
post #186 of 186 Old 06-05-2013, 06:23 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I am going to borrow a kill a watt this weekend and measure my Norco server and also my HTPC.
Mfusick is offline
Reply Home Theater Computers
