HDMI Audio not working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-04-2011, 01:04 PM - Thread Starter
licnyc's Avatar
Hi all
my computer is both an htpc and a workstation so it is connected with HDMI to an onkyo avr and to a monitor with vga. My OS is win 7 64. The problem is that I cannot seem to find any way to enable HDMI solely for audio while working on the monitor. Windows seems to require video to be fed at the same time. If I disable the video to the onkyo that I have HDMI to, the audio properties become greyed out "not plugged in" and I cannot use the audio.
Is there anyway to enable HDMI audio within windows without being forced to pretend it is a monitor?
Video card: Geforce GT 240
Receiver: Onkyo HT-RC360
licnyc is offline
post #2 of 7 Old 10-04-2011, 04:39 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Does your video card have a dvi and hdmi connection? If it does, you could connect the monitor via dvi as display 1 and the avr via hdmi as display 2. Then, extend your desktop to display 2.
audit13 is offline
post #3 of 7 Old 10-04-2011, 08:36 PM - Thread Starter
licnyc's Avatar
Thanks. I discovered that there is no way one can stream only audio. HDMI works only if the video feed is present. So your solution works but I will be losing the mouse cursor on the second screen. Also I can't clone as my monitor is not widescreen.
How crazy is that? Couldn't they allow audio only when the designed HDMI? It almost made me regret the purchase of the new receiver as I still have to connect the htpc to avr using hdmi and spdif.
licnyc is offline
post #4 of 7 Old 10-05-2011, 03:34 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Hmm, that's weird becuase I can stream hi-def flac files to my avr with my monitor turned off or on.
audit13 is offline
post #5 of 7 Old 10-05-2011, 04:30 PM - Thread Starter
licnyc's Avatar
Do you mean that you are streaming flac to avr using hdmi without streaming video to avr at the same time? That's strange-I thought this was impossible.
licnyc is offline
post #6 of 7 Old 10-05-2011, 05:28 PM
vladd's Avatar
Liked: 39
It is impossible. HDMI requires a video signal for the audio signal to piggyback. He's just not seeing the cloned/extended desktop that is going to the AVR.
Edit: (this is what I get for skim reading).
Even though his monitor is turned off, the HTPC is still sending a video stream to the AVR.
vladd is offline
post #7 of 7 Old 10-05-2011, 05:36 PM
audit13's Avatar
Quoted: 37 Post(s)
Liked: 33
Yes. I have an hdmi cable going to the avr, dvi cable to the tv. Audio is not carried over the dvi cable; therefore, I can only hear sound when the avr is running.
audit13 is offline
Reply Home Theater Computers
