HDCP Error out of the blue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-06-2011, 05:56 AM - Thread Starter
CTShooter's Avatar
I have had no problems playing blu-rays on a zino pc since I purchased it 7 months ago. I have only one monitor (Epson 8350 projector) and my outputs run through a HDMI switch to the projector.
2 days ago I lost the ability to play blu-rays through the computer. I get a message from PowerDVD that 'my display is not HDCP enabled' and when I try WinDVD it says it cannot play a procted disc through this enviroment.
If I backup my disc and play it through Media Center all is fine but the actual discs no longer play.
I have not changed anything on the computer that I can think of and am stumped why all of a sudden im not HDCP Enabled.
Any suggestions on what the problem can be and how I can resolve it? I was planning on getting rid of my PS3 since I have this fully loaded HTPC but now that isnt possible.
XBL - Poongamer PS3 - Poongamer
CTShooter is offline
post #2 of 3 Old 10-06-2011, 09:23 AM
tehowell's Avatar
You might try the suggestions here...
Samsung UN65JS8500 65" SUHD TV FW1455; Yamaha RX-A750BL Receiver FW1.77; Samsung UHD-K8500 UHD BD player, FW1005, w/dual HDMI; one to TV (video), one to AVR (bitstream); Arris DCX-3600M Cable STB; Nvidia Shield Android TV Update 3.2, Server: Windows 10 Home and Emby Server.
tehowell is offline
post #3 of 3 Old 10-06-2011, 09:34 AM
Zon2020's Avatar
Any chance Power DVD did any kind of update that created a problem?
I would try pulling the HDMI switch out of the loop and connect the PC directly to the projector and see if the problem persists.
Just a couple of (probably useless) random thoughts.
Zon2020 is offline
Reply Home Theater Computers
