Video Card for HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-09-2011, 11:46 AM - Thread Starter
66BMW's Avatar
Hi All,
I'm going to build another HTPC and I think I overbuilt the last one.
I'd like a few suggestions on a video card that can be used for broadcast TV (will get a tuner card) and Blu-ray. No gaming at all. I have a 55" Vizio (240HZ with LED backlighting). I prefer a fanless card or something very quiet if it does have a fan. Obviously with HDMI.
I'm not sure if I need a $69 card or if I'm going to be in the $300 range.
Thank you in advance for your help.
66BMW is offline
post #2 of 5 Old 10-09-2011, 12:04 PM
blueroom's Avatar
If you're starting from scratch the new AMD APUs have a decent built in GPU. The 65W series is fairly quiet. e.g. A6-3500
Bill
blueroom is offline
post #3 of 5 Old 10-09-2011, 12:17 PM
Scallica's Avatar
I have built several systems using the Gigabyte GeForce 8400 card which is inexpensive and works well. Also, the HDMI port will carry the system's sound signal as well.
http://www.newegg.com/Product/Produc...igabyte%208400
HTPC Enthusiast
Scallica is offline
post #4 of 5 Old 10-09-2011, 12:19 PM
Servicetech571's Avatar
If you are building new I'd get an I3 based system and just use the integrated graphics.
Servicetech571 is offline
post #5 of 5 Old 10-09-2011, 12:47 PM - Thread Starter
66BMW's Avatar
Okay, so I can use the integrated HDMI on the mobo without any problems? I am starting from scratch as my current build has started developing issues after 3-years of continuous use.
66BMW is offline
Reply Home Theater Computers
