HDHomerun Prime Owners Thread - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #721 of 2761 Old 11-08-2012, 08:00 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
Originally Posted by tawd1992 View Post
Thanks for confirming that. I have an LG 42LM6200 TV & when I watch 3D Blu-rays through Media Browser & TMT5 the TV will automatically switch to 3D mode. Hopefully the same will happen when I'm watching 3D TV. Does your TV automatically switch to 3D mode when watching 3D Blu-rays?
Yes, my TV automatically switch over to 3D when play Blu Ray. But that's not the same 3D signal you will receive from cable or satelite. The BD 3D is called FullHD 3D that requires HDMI 1.4 equipments and different 3D signal format. Cable and Satellite are using the same old equipments to pass a signal that is not really 3D. It split the screen with top-down or side by side to transmit a 3D picture in one video frame while the video signal complies to existing 2D video. You loss half of the resolution in exchange for compatibility with virtually any equipement. There is also no flags (or at least none of the devices understands that) to indicate that this is a 3D video. So, you will have to manually switcch your TV to one of the 3D mode matching the video and switch back when you switch to 2D channel.
Foxbat121 is online now
post #722 of 2761 Old 11-14-2012, 09:12 PM
ewhenn's Avatar
I've accomplished encrypted channel live streaming using free software.
1) Capture screen at 30 FPS with SCFHDSF,
2) Mux audio and screen cap in Adobe live encoder which also real-time encodes it to x264,
3) output the stream to Adobe Streaming Media server developer edition hosted on the HTPC,
4) connect to the stream anywhere using JWPlayer,
5) use VNC or remote keyboard to swap channels
I stream at 480p and 1.2 mbit, (~50-70% processor usage on an i3-2100), so it's not perfect, but still looks pretty decent. Packet drops/and the ups and downs of home broadband isn't an issue because RTMP protocol has some buffering built in. You also need an active HDMI splitter (about $30) to do the HDCP handshake and to sit between your TV and HTPC so your TV doesn't need to be on the whole time.
ewhenn is offline
post #723 of 2761 Old 11-15-2012, 05:10 AM
Liked: 659
Um, ok. But what does this have to do with the HDHR Prime and why do we care?
slowbiscuit is offline
post #724 of 2761 Old 11-15-2012, 05:38 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
My thoughts exactly. Besides, you can just go buy a Slingbox as it does everything described above plus remote control and mobile apps supported,
post #725 of 2761 Old 11-15-2012, 06:12 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Is ewhenn talking about protected content or is he talking about encrypted digital content that is copy freely?
Sammy2 is offline
post #726 of 2761 Old 11-23-2012, 11:09 AM
leebo's Avatar
Quoted: 530 Post(s)
Liked: 300
I'm having a problem getting a family members Xbox set up as an extender. If I'm posting in the wrong place let me know, but I thought some of you have experience with it so I'm giving it a shot.
This system was working fine up until yesterday, when my brother made several changes to the win 7 pc that is recording the programming from the Prime.
The Xbox started saying it could not connect to Windows Media Server. I ended up doing a roll back to a point last week when I knew everything was working.
The Xbox still had the same problem.
I removed the extender from WMC and started over with the Xbox. I got the 8 digit code from the Xbox and entered it into WMC.
WMC complained that the code was incorrect and to try again, which I did. After about five tried, I have up and went to bed.
So my question is, how do I trouble shot this?
Sent from my Nexus 7
leebo is offline
post #727 of 2761 Old 11-23-2012, 11:49 AM
leebo's Avatar
Quoted: 530 Post(s)
Liked: 300
Additional info re my problem above:
WMC fails during extender set up at step three - configuring extender.
I then get a configuration error, and am prompted to enter a new, 8 digit code (which ultimately fails).
leebo is offline
post #728 of 2761 Old 11-23-2012, 12:57 PM
greggplummer's Avatar
Leebo-
I'm a hdhomerun prime owner, and I don't see how these questions relate to this thread. Maybe some of us are xbox owners, but maybe a lot are not. So, in response to your original comment, maybe you are posting in the wrong place. I think you'd get better answers searching for an xbox thread and asking there or starting a new one with the topic title "xbox extender no longer functioning after unknown changes" or something.
I don't want to whine, but it is a little annoying to get an email notification for a thread I've subscribed to with a question for something that doesn't seem to be related to the topic of the thread.
Gregg Plummer
Amplizone - a blog about the development of Amplio Audio's soundcard/amps
The Short History of Audio/Video Technology
greggplummer is offline
post #729 of 2761 Old 11-23-2012, 03:11 PM
leebo's Avatar
Quoted: 530 Post(s)
Liked: 300
Ok. Thanks.
leebo is offline
post #730 of 2761 Old 11-23-2012, 08:54 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 401
Sounds like something is blocking the traffic between WMC and Extenders. Check the firewall settings and if your brother installed some new 3rd party firewall, good luck.
post #731 of 2761 Old 11-23-2012, 11:45 PM
aztony's Avatar
Hi, new to this forum. I saw tonight that Amazon has the SD HDHR3 on sale for $55. I would like to know if I would need any other accessories to make it work. One of the reviewers on Amazon mentioned needing the WMC remote. I use an OTA antenna on my TV. The laptop runs Win7, no TV tuner, I'm assuming that's what the HDHR3 is for. My TV is a Sony HX850, hooked up to a D-Link DES 1105(switcher). Also, my Xbox and blu-ray player are hooked into the switcher. Any advice would be greatly appreciated on how to set it up. TIA
http://www.amazon.com/SiliconDust-HDHomeRun-Definition-Television-HDHR3-US/dp/B004HO58SO/ref=cm_cr_pr_product_top
aztony is offline
post #732 of 2761 Old 11-24-2012, 07:38 AM
Liked: 659
This thread is about the Prime (with Cablecard tuners), not the original HDHR. Great price on that one though.
post #733 of 2761 Old 11-24-2012, 08:29 AM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
The HDHR products work with a mouse if you're using WMC. Win7's WMC is slightly better with a mouse than Vista's, but both are fine. I've not tried Win8's WMC.
aztony likes this.
Karyk is offline
post #734 of 2761 Old 11-24-2012, 10:46 AM
aztony's Avatar
Sorry about posting in the wrong thread but this is the only one that came up when I did a search that had to do with the HomeRun. I didn't even know there was a Prime model.
Thanks for the info.
aztony is offline
post #735 of 2761 Old 11-24-2012, 11:43 AM
leebo's Avatar
Quoted: 530 Post(s)
Liked: 300
I still haven't gotten any answers to my Xbox issue, not even in the dedicated Xbox thread. So if anyone here is a media extender expert, feel free to PM me please.
Anyway, I have another question. I just ordered the Win 8 update. Are there any known issues getting the Prime working with Windows 8's Media Center?
leebo is offline
post #736 of 2761 Old 11-24-2012, 01:13 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
There is a separate thread for the Prime and SiliconDust has it's own forums too. As far as the xBox goes, you may have better luck posting at the Green Button forums.
Sammy2 is offline
post #737 of 2761 Old 11-26-2012, 02:28 AM
leebo's Avatar
Quoted: 530 Post(s)
Liked: 300
leebo is offline
post #738 of 2761 Old 12-04-2012, 01:00 PM
arztonyou's Avatar
Hello everyone,
I recently purchased a Prime and have read through this thread. I have Charter and after reading a few comments, I decided to chat with Umatter2Charter rather than calling the standard support line. However, because I have not been very active (long-time lurker, though) I am apparently limited to 2 messages a day. Do you know how long I need to be "active" or just how "active" I need to be before that limit goes away?
Sorry to derail the thread with a question like this.
arztonyou is offline
post #739 of 2761 Old 12-04-2012, 01:07 PM
Karyk's Avatar
Quoted: 225 Post(s)
Liked: 44
Just a guess, but it might be dependent on the number of posts. You now have one under your belt.
Karyk is offline
post #740 of 2761 Old 12-04-2012, 01:09 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I don't know. I think it is based on the number of posts you make on the forum. Using UMatter2Charter is the best way to go as the other support via phone and chat is hit and miss. I was having issues just the other day. Phone support said they "hit" my tuning adapter but nothing changes so they set up a truck roll. I pm'd umatter and within 15 minutes it was fixed with no truck roll.
Sammy2 is offline
post #741 of 2761 Old 12-04-2012, 02:57 PM
arztonyou's Avatar
Okay, thanks for the information. I guess I'll have to just keep posting. smile.gif
The CableCard has been successfully activated and I can view some channels, but the tuning adapter is not working properly. It keeps flashing an amber light and is listed as disabled in the Prime setup menu. I'll check on the firmware and talk to Umatter2Charter as soon as I can.
I'm just about to test the recording of the channels that can be viewed. This should be a great device once the tuning adapter is working correctly.
post #742 of 2761 Old 12-04-2012, 03:17 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Tuning adapters need to be successfully paired and sometimes they become un-paired. It is frustrutating as hell sometimes.
Sammy2 is offline
post #743 of 2761 Old 12-05-2012, 02:16 PM
Iteki's Avatar
http://www.engadget.com/2012/12/05/hdhomerun-prime-is-the-first-cablecard-tuner-to-deliver-live-tv/
Interesting stuff....I don't have a PS3, but I might be tempted to pick one up now.
I'm no expert....so your mileage may vary
XboxLiveID: archie68
Iteki is offline
post #744 of 2761 Old 12-05-2012, 03:19 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
There's already a dedicated thread for this.
Sammy2 is offline
post #745 of 2761 Old 12-06-2012, 11:01 AM
maxBR's Avatar
I'm on day 3 of my HDHomerun Prime and cable card setup. Basic install was pretty easy and everything was up and running according to plan quickly. I'm still dealing with a few issues though. Maybe someone can help as Google hasn't gotten me results on these yet.
First is this error that comes up when scanning for the tuners: http://www.silicondust.com/support/hdhomerun/testfai/upnp_multicast_send_unicast_recv/
Looks like a network issue. I went through every setting in my router that looked applicable and no change. I disabled Windows Firewall, no change. I setup WMC on a laptop to see if that would have the problem, same issue. I'm using Netgear WNDR3700, maybe someone knows the settings to use?
Second issue came up while configuring WMC on a laptop to access the tuners. The main HTPC finds all 3 tuners, the laptop only finds 2 tuners. This issue is impossible to google! Everything that comes up is is about not finding any tuners, or WMC found them all, but has trouble accessing them. I find 2 tuners, which I can use in WMC fine. I am able to watch the stream from all 3 tuners in Quick TV.
I am loving this setup so far. I really hope I can get it to the point where it's working flawlessly 99% of the time.
maxBR is offline
post #746 of 2761 Old 12-06-2012, 11:18 AM
dman97's Avatar
I had to had the exact same amber light problem with Charter and I was missing several channels. The fix was to remove the cable card and re-insert it then have Charter resend the activation signal to the tuning adaper. 5 minutes later my amber light stayed solid and I had all of my channels.
dman97 is offline
post #747 of 2761 Old 12-06-2012, 12:05 PM
arztonyou's Avatar
My Prime is now up and running, including the Tuning Adapter. Without going into details, let's just say there was an embarrassing user error. The Umatter2Charter team was very helpful, and I am loving the Prime. Have watched several hours of Live TV on a couple different computers. I was pleasantly surprised I was able to watch LiveTV over a wireless connection on one computer (not my main HTPC, which is wired). I've also taped two programs while watching a third, so everything seems to be working great.
Now to try and integrate LiveTV into XBMC and also keep my eye on the LiveTV via DLNA thread.
post #748 of 2761 Old 12-06-2012, 02:22 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
What T.A. do you have?
You can't watch content with the copy once flag via XBMC for sure and I am not sure about the rest of it as last I knew the XBMC epg/pvr was still in development but I haven't followed this.
Good thing that you got Umatter2Charter to help you as Charter, in their infinite wisdom, has decided to disband the team. The best CS channel in the entire company and they disband it; what a lame ass company.
Sammy2 is offline
post #749 of 2761 Old 12-06-2012, 04:00 PM
arztonyou's Avatar
The TA is a Motorola MTR700.
I don't have premium channels like HBO, etc. and I haven't had any problems watching recorded content in XBMC so far, so most of the channels must be copy freely. So far I've stayed with just the official Eden release of XBMC and haven't jumped into any of the Frodo builds yet. I started out using Media Browser within WMC and really liked it, but found the Aeon Nox skin just as visually appealing with the added addition of some great add-ons. Now LIveTV in WMC makes it tempting to go back to MB, but I can't keep bouncing back and forth between them. I may just wait until the final release of Frodo comes out.
Sorry to hear about the Umatter2Charter team, especially with their presence on this site. Talk about convenient.
post #750 of 2761 Old 12-06-2012, 04:10 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Palladia
HDNet
HDMovies
Universal
Smithsonian
TWCsportsnet
A few SDV channels for me that get a lot of play time.
Sammy2 is offline
Reply Home Theater Computers
hdhomerun bluray
