HDHomerun Prime Owners Thread - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #2071 of 2761 Old 08-02-2014, 04:49 PM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
You want the Plus if the device your streaming to (directly from the tuner) doesn't support MPEG 2, but supports h.264.
Also, it's possible the Plus has a better demodulator, and can handle signal sensitivity better than the Dual; being that it's newer/could contain newer/better parts. I can't say for sure with any degree of probability though.
I would personally go with the Plus over the Dual. You know what you might need/face down the road better than I though. The Plus will work with everything the Dual would work with/for; the same can't be said the other way around (whether said use case currently exists yet, or not). But obviously, the Plus costs more than the Dual (while only $20 more currently at Newegg, it's still more. And $100 more normally). Just keep all that in mind.
staknhalo is offline
post #2072 of 2761 Old 08-03-2014, 11:20 AM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
Thanks. I really appriciate the help, especially considering this is technically off topic in this thread.
I did my indoor antenna test. Looks like this may be a moot point for me. I was not able to get ANY signal at all, even though one of those signal strength sites showed we should be able to get ABC and CBS with an indoor antenna. We're in a one story house, but we have a three story apartment building behind us, andI'm pretty sure it's blocking everything
After that I had to make a run to the store, and only then did I notice only two houses had rooftop antennas within a four block area of our place. I assume that's for the same reason.
leebo is offline
post #2073 of 2761 Old 08-03-2014, 12:27 PM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
I was quoted this from Microcenter. I am building this solely for the purpose of recording, editing, then burning onto Blu-ray. NOT permanent archiving on the HDD.
Please let me know what you think
of what I am being presented.
thank you
·AMD A10 7850K 4.0 GHz Black edition processor 140
·ASUS A88X – Pro Socket FM2+ ATX AMD Motherboard 130
·Corsair Vengeance pro series 8 GB DDR3-2133 (two 4GB memory modules) 100
·EVGA 500 watt 80+ 500 watt ATX power supply ($5 rebate) 45
·Hauppauge Colossus 168
·LG Internal 16X super-multi Blu-ray writer 130
·Windows 7 Home premium 64 bit 100
·V3 Black edition ATX computer case ($15 rebate) 40
·Toshiba 7,200 RPM SATA 1 TB hard drive 50
I will also be picking up the Home Run prime as well as VideoReDo (for editing)
I do know I can get the colossus cheaper ( i do need this as there may be events I will have to off load from my DVR) and I know the burner can be had for about $60.
the specific grafics "core" in my processor is :
AMD Radeon R7 graphics “270 AMD”.
Is this a good enough card for what I want to do?
How much $$ would I save if I went with 4 GB of memory compared to 8? is 8 reasonable, or rediculous over kill?
ANY SUGGESTIONS I CAN HAVE IS GREATLY APPRECIATED
Total = 900
Plus build 100
Discounts (40)
Sub Total 962
total/tax 1020
rebates (20)
TOTAL 1000
billmich is offline
post #2074 of 2761 Old 08-03-2014, 12:32 PM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Originally Posted by leebo View Post
I believe both 32 and 64 bit cost the same, so I would go with 64 bit. You can then get 4 Gb ram, and always add another 4 later if you like.
Using the PVR capabilities of WMC won't tax your system much, but burning to BR can, if you're doing something else at the same time.
When burning, I will be doing NOTHING else on this PC
billmich is offline
post #2075 of 2761 Old 08-07-2014, 03:45 PM
EDDIEB33's Avatar
Synology NAS with HD Homerun Prime
I am new to this thread and have searched online, but haven't seemed to find an answer. Synology Video Station has recently come out with being able to watch Live TV from your NAS. Can my HD Homerun Prime work with this or do I need some other hardware to get this to work? Would appreciate any help on the matter.
EDDIEB33 is offline
post #2076 of 2761 Old 08-07-2014, 04:08 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
Do you have a link with more details? I briefly looked and all I could find was support for USB based European tuners.
Westly-C likes this.
rc05 is offline
post #2077 of 2761 Old 08-17-2014, 09:40 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Is there some sort of app that will allow me to schedule recording via the homerun prime remotely?
Apple didn't have anything under "homerun prime"
Thanks for your help
billmich is offline
post #2078 of 2761 Old 08-17-2014, 09:44 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
MyMediaCenter by Ceton.
Sammy2 is offline
post #2079 of 2761 Old 08-17-2014, 11:42 AM
mdavej's Avatar
Quoted: 2125 Post(s)
Liked: 940
... or Remote a Potato which does scheduling and streams recordings to any device, something MMC can't do.
mdavej is offline
post #2080 of 2761 Old 08-17-2014, 11:48 AM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
Remote Media Center (on Android) is also ugly as hell too compared to the MMC app - if you like that, lol.
The actual Remote Potato app (only for iOS) is a bit better.
+1 for MMC though
post #2081 of 2761 Old 08-17-2014, 11:51 AM
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
I use WMC so I just RDP into my home system and schedule the recording.
Gronnie is offline
post #2082 of 2761 Old 08-17-2014, 12:51 PM
mdavej's Avatar
Liked: 940
WMC refuses to start if I RDP on another session. If I RDP any other way it disrupts whoever is watching TV.
And don't you find it very awkward to RDP from a phone?
mdavej is offline
post #2083 of 2761 Old 08-17-2014, 05:19 PM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
So which is better, the MMC, or the potato?
Can I set/schedule recordings via MMC?
billmich is offline
post #2084 of 2761 Old 08-17-2014, 05:30 PM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
I think MMC is better, and yes.
post #2085 of 2761 Old 08-17-2014, 06:52 PM
paulsaz's Avatar
Quoted: 12 Post(s)
MMC is much easier to use, but doesn't have as many features. If you only want to be able to schedule recordings, MMC is the easiest.
paulsaz is offline
post #2086 of 2761 Old 08-17-2014, 07:42 PM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Thank you guys
All I want to do is to be able to schedule recording remotely and change channels with the app
billmich is offline
post #2087 of 2761 Old 08-17-2014, 08:36 PM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
It will do all that then.
post #2088 of 2761 Old 08-17-2014, 08:41 PM
Gronnie's Avatar
Quoted: 32 Post(s)
Liked: 30
There is a patch you can install that will allow you to have multiple concurrent sessions. Google "concurrent rdp windows".
But yea, RDP sucks from a phone. I had a brain fart and didn't put two and two together that when you asked for an app that it would be from a phone.
There is also a bug in one of the Windows updates that screws up the terminal server permissions. Run regedit and do the following:
HKEY_LOCAL_MACHINE --> SYSTEM --> CurrentControlSet --> Control --> Terminal Server --> WinStations --> Right-click RDP-Tcp... go to permissions and add read permissions for "Users"
This will allow you to start WMC again from an RDP session.
Gronnie is offline
post #2089 of 2761 Old 08-17-2014, 08:49 PM
mdavej's Avatar
Liked: 940
Originally Posted by Gronnie View Post
There is a patch you can install that will allow you to have multiple sessions. Google "concurrent rdp windows".
Thanks. I've installed that patch and do indeed run concurrent sessions. But WMC simply won't run again if it's already running in another session. Any way around that?
For the OP, I agree that MMC is the way to go for what he wants to do. But there's no reason you couldn't use both, RP for streaming and MMC for management/control. Speaking of control, Hippo Remote is far better at that than MMC and RP, IMO. I don't think it's available on Android.
mdavej is offline
post #2090 of 2761 Old 08-18-2014, 07:56 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I use MMC for remote access and scheduling and I use MediaBrowwer3 Server for remote streaming of copy freely content.
Sammy2 is offline
post #2091 of 2761 Old 08-19-2014, 10:44 PM
action_jackson's Avatar
Quoted: 321 Post(s)
Liked: 108
I just got my hdhomerun prime setup this week and am running into an issue. For some reason I am not able to watch all the channels, namely HBO, cinemax, Showtime, and DisneyJr. There are others as well, but if I flip through the channels, there might be several in a row that work with a few in between that don't.
I am on Charter Cable and am viewing using WMC on windows 7 with an Invidia graphics card and an ATI graphics card. I have 3 monitors, a couple connected using DVI and one using a VGA cable. I have updated all drivers, and firmwares. I am not sure if all the monitors are compliant with DRM or not, each one is different.
I was planning on using this as a DVR instead of the Motorola box that the cable company sent, but if I can't get these channels working this thing is pretty much useless.
I also have an xbox 360, but have not tried viewing anything on it yet because it is still boxed up after our recent move.
Epson Home Cinema 3010 Projector____Paradigm 9SE MK II Main LR
Yamaha RX-V667 AVR_______________Paradigm CC-270 V.3 Center
Emotiva UPA-5 Amplifier______________Dual Stereo Integrity 18" Infinite Baffle
Sony BDP-570 Blu Ray_______________DIY Sound Group Volt 10
action_jackson is online now
post #2092 of 2761 Old 08-20-2014, 05:41 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
^^ This sounds like an issue with the Tuning Resolver / Adapter most likely. Have you checked in the HDHR Prime's Web Interface? The Tuning Resolver should say "ready" on the home screen. If this doesn't do it then Call Charter and have them send the appropriate "hits" to get it initialized.
Sammy2 is offline
post #2093 of 2761 Old 08-20-2014, 06:08 AM
mdavej's Avatar
Liked: 940
Last time I changed my package, they accidentally removed the TA from my account entirely. So that's a possibility too. And make sure it's connected of course.
mdavej is offline
post #2094 of 2761 Old 08-20-2014, 07:51 AM
Quoted: 321 Post(s)
Liked: 108
Here is the hdhr tuning resolver status:
Authentication none
Downstream success
Upstream success
Operational status initializing
User activity none
post #2095 of 2761 Old 08-20-2014, 08:16 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Authentication none
Downstream success
Upstream success
User activity none
First try rebooting the Prime and TA by unplugging the power on both for 10 seconds then plugging them back in. If the LED on the TA doesn't go solid green call Charter and ask for CableCARD support, then have them send the authorization hits..
Sammy2 is offline
post #2096 of 2761 Old 08-20-2014, 11:21 AM
signcarver's Avatar
Based on what you reported, you obviously do have a problem with the TA. There has been a problem with many providers recently (including charter) with a prime and motorola tuning adapters, for some assuring the TA is on 1.37 has helped (I think the minimum has always been 1.34 and someone had a problem with 1.33). On SD's forums nick recently split a large thread into individual issues as they prefer that for problems as not everyone's is always the same. I would also try without the TA as some of the rebuild areas of charter are no longer using TAs and the TA map and communication has been neglected. You also mentioned flipping through channels... many TAs don't like that and may time out for a minute if you flip too fast, especially the first week (few days) on the system but seem to settle in within a week.
Though my second instinct would have been the TA, due to the channels listed, my first instinct would have been DRM as 3 of those channels will almost always be protected and have CCI set to copy once ... with disney it varies by market with charter (showtime also won't be protected on verizon but will everywhere else... I have even heard of areas of comcast that protect some disney channels where nothing else other than premiums are protected)... I would definitely troubleshoot with a known good protected path to the display... sometimes VGA needs to be kickstarted and run in a window first... the dvi can be hit or miss as many dvi connections aren't hdcp compliant... also make sure you are not cloning the displays. Protected channels also need a properly/fully paired card... usually most notice this on Comcast/Verizon with HBO as the card isn't fully paired and works with everything else... some areas of Charter are like this in that they only protect those premiums.
signcarver is offline
post #2097 of 2761 Old 08-20-2014, 03:10 PM
Quoted: 321 Post(s)
Liked: 108
Thanks for the help! I tried powering cycling the TA and the hdhr, that didn't work. I tried calling customer service and they could not help me resolve the issue over the phone. I now have to have another service call.
post #2098 of 2761 Old 08-20-2014, 05:14 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
In the mean time try calling them again. Sometimes it depends on the competency of the CS person on the other end of the line to do this right.
Sammy2 is offline
post #2099 of 2761 Old 08-20-2014, 05:47 PM
huy30's Avatar
Quoted: 16 Post(s)
I don't know that anyone has the same problem or this problem already covered.
Just recently I can not watch ABCHD, CBSHD, NBCHD, and FOXHD. For these channels, they are very choppy. FXHD has problem too but a lot better than other network channels. The rest of the channels are normal. I open HDHomeRun Config (GUI), I see the Symbol Quality % for the problem channels is not at 100%. It happens on PC with Win7 MC and DLNA over TV. I am with Comcast. My unit start having problem or Comcast signal problem? Thanks for any helps.
huy30 is offline
post #2100 of 2761 Old 08-20-2014, 07:50 PM
mdavej's Avatar
Liked: 940
On Moto, solid amber is good. Slow blink or red is bad.
I assume you have the TA plugged into coax and USB, right? And your cable card is showing activated?
Remember when you talk to Charter, pretend you have a Tivo. If you mention homerun, they'll only get confused. If you get the right person, they should be able to get everything working over the phone. My last activation took about 10 minutes start to finish, a new record for me and Charter.
mdavej is offline
Reply Home Theater Computers
hdhomerun bluray
