HDHomerun Prime Owners Thread - Page 77 - AVS Forum
 19Likes
post #2281 of 2284 Old Yesterday, 10:35 AM
Karyk's Avatar
Quoted: 79 Post(s)
Originally Posted by jbailey895 View Post
Would it benefit me to order a cablecard for the prime, especially since I don't subscribe to the upper tiers? Although I might. . .
I suspect it might deal with your issues, but one thing it will definitely help is automatically changing the channel assignments (at least for the Prime) when your cable company does that. I have Comcast and before I had the Prime they seemed to do that about every two years, so it would be worth it just for that. Comcast also gives me the Cablecard for free, and still gives me a $2.50 credit because I have my own equipment.
Karyk is offline
post #2282 of 2284 Old Yesterday, 10:52 AM
jbailey895's Avatar
OK, thanks Karyk, I'll order it and give it a shot, if nothing else, would be great if it helps MCE recognize the proper channel line up.
Cheers,
Joel
jbailey895 is offline
post #2283 of 2284 Old Yesterday, 06:37 PM
tranle's Avatar
Quoted: 18 Post(s)
Has any of you successfully use the new HDHomeRun_View application with a Comcast cable card on a HDR Prime ?.
Comcast encrypt their basic channel but they are not protected and I can record them to a .tp file and view them with vlc.
I can also view the channel with MCE but HDHomeRun View give a blank screen.
tranle is offline
post #2284 of 2284 Old Yesterday, 07:59 PM
retate's Avatar
Quoted: 12 Post(s)
Yes it has worked for me on both the beta software and the release software that was posted earlier this week.
Bob
retate is offline
Reply Home Theater Computers
