HDHomerun Prime Owners Thread - Page 79 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #2341 of 2761 Old 12-31-2014, 09:48 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
Originally Posted by amarshonarbangla View Post
Thanks a lot! How can I check the CCI flags of the channels?
If you enter the IP address of your HDHR in a web browser, you can navigate to the "tuner status" page which will show you the CCI info for that channel.
JDLIVE is offline
post #2342 of 2761 Old 12-31-2014, 09:53 AM
Ken.F's Avatar
Quoted: 1471 Post(s)
Liked: 1256
It will show you the CCI info for the program that is playing on that channel. I have seen some programs flagged copy once and others flagged copy freely on the same channel.
Ken.F is offline
post #2343 of 2761 Old 01-01-2015, 12:39 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
Me too, and I have also seen content flagged as copy once, then copy freely during advertisements.....strange.
qz3fwd is offline
post #2344 of 2761 Old 01-04-2015, 11:00 PM
mva5580's Avatar
Quoted: 37 Post(s)
Having a strange issue I'm hoping someone can assist me with. My setup is:
- HDHomerun Prime being used with Cox CableCard/Tuning Adapter
- PC with an nvidia GTX 970 GPU
- HDMI from GPU to Denon receiver
I am having a problem with certain channels, for example AMC/TBS/SyFy flickering while watching live tv. The channels will flicker usually every ~5 seconds or so and it obviously makes watching these channels impossible. It's not every channel; for example ESPN/TNT/ABC Family work fine.
I've also noticed that it will only do this when WMC is full screen. If I exit out of full screen mode, these channels work as normal. The only thing I have seen online in regards to a "fix" is to ensure that in the nvidia control panel that dynamic contrast is off, and it already is.
Any help in this would be greatly appreciated.
mva5580 is offline
post #2345 of 2761 Old 01-05-2015, 12:22 AM
signcarver's Avatar
29/59 issue AMC and SYFY for certain (SYFY is usually 14/29 now), haven't noticed it on TBS usually but don't watch it much off PC, only extenders... dynamic or adaptive contrast is the major thing to turn off but there are many other settings depending on video card... some need older drivers, others have other settings (I believe for nvidia it is something about a full screen video setting and I think some had dynamic contrast in two locations).
The best workaround is to use non-microsoft codecs/filters... however most cox markets protect everything but locals so that usually isn't an option (Cox New England is generally the only one that doesn't protect anything... there are a few areas from VA going NE to NE that vary... NOLA also has some areas that doesn't).
signcarver is offline
post #2346 of 2761 Old 01-05-2015, 09:29 AM
Quoted: 12 Post(s)
Liked: 1
Let me ask this: By "flickering" do you mean the "strobe effect" (flashing) that everyone in here has talked about or is it just blinking (going black and then coming back) frequently?
davis449 is offline
post #2347 of 2761 Old 01-05-2015, 10:25 AM
mva5580's Avatar
Quoted: 37 Post(s)
Going black and coming back frequently.
mva5580 is offline
post #2348 of 2761 Old 01-05-2015, 10:46 AM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
Nvidia Control Panel / Adjust desktop color settings / Content type reported to the display / Full screen videos.
sawfish is offline
post #2349 of 2761 Old 01-05-2015, 10:59 AM
Quoted: 12 Post(s)
Liked: 1
Ok, the reason I asked is because I had this EXACT same issue on certain channels. It turned out to be display resolution settings in WMC. I had WMC launching itself in full 1080p (1920x1080) while my windows desktop was set in the Nvidia control panel as a custom resized, perfect fit variation of 1080p. I simply went through the display wizard in WMC and told it to keep my current resolution and this resolved my issue. I would assume the other way would work as well, i.e. set the desktop to a non-resized, full 1080p resolution and tell Windows to keep THAT resolution during the display setup wizard.
davis449 is offline
post #2350 of 2761 Old 01-05-2015, 05:56 PM
mva5580's Avatar
Quoted: 37 Post(s)
This solved the problem, thank you sir.
mva5580 is offline
post #2351 of 2761 Old 01-05-2015, 06:05 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
Great. The screen blanking is the worst manifestation of the 29/59 bug, and it only occurs with some TVs. It happens because the TV is switching between TV and PC timings or modes, and that can take several seconds. Lesser manifestations include whole-screen flicker (very fast, strobe-like flicker), and that is solved by turning off dynamic contrast. The least offensive type is jerky motion, and that is solved possibly by trying a different card, but IME, the biggest improvement to that was due to the broadcast chain getting its act relatively together, and that's going to be on a provider by provider basis.
Anyway, using "Full screen videos" keeps the TV in TV mode at all times, which can also enable various TV settings that aren't available when PC timings are being used. This was the case with my Sony LCDs.
sawfish is offline
post #2352 of 2761 Old 01-05-2015, 06:21 PM
mva5580's Avatar
Quoted: 37 Post(s)
Yeah I figured there was something like that going on, just couldn't find the proper setting to fix it. I really appreciate it.
Do you think turning this on will mess with anything else, like playing games? I tried a few and all seems normal, just curious.
mva5580 is offline
post #2353 of 2761 Old 01-05-2015, 06:48 PM
sawfish's Avatar
Quoted: 137 Post(s)
Liked: 144
It would depend on what the TV does with it. Besides affecting settings availability, mode differences could include things like input lag and
"levels" AKA HDMI/DVI Dynamic Range differences. You could check the latter with pattern sets like AVS HD 709, particularly the Black Clipping and White Clipping patterns. It's been years, but I now realize my Sony LCD implicitly changed its dynamic range setting based on the Nvidia Content Type setting, and it required wildly different Brightness and Contrast settings to account for it.
sawfish is offline
post #2354 of 2761 Old 01-07-2015, 09:01 AM
originalsnuffy's Avatar
Two little questions
First, any idea why one regular broadcast channel would work fine in SD but show a message along the lines of "not provisioned" for HD viewing? HBO etc. works just fine. I am on Comcast and would love some pointers.
Second, for viewing at home, can I view recorded materials on more than one PC? I seem to have issues with both HBO and regular OTA style programs.
originalsnuffy is offline
post #2355 of 2761 Old 01-07-2015, 09:11 AM
TornadoTJ's Avatar
Quoted: 1612 Post(s)
Liked: 510
If the programs are marked "copy once", you will not be able to view them on a different PC. This is where extenders (XBOX 360) come in handy.
TornadoTJ is offline
post #2356 of 2761 Old 02-04-2015, 01:22 AM
westsidehf's Avatar
nice to find this thread. I am a novice trying to save $ on the very high cable box fees and such.
will the HDHRPrime3 work with 3 HDTVs that are not DLNA? TVs are old (2007, 2009, 2011). I understand the need for a CableCard and tuning adapter but what device can I use to receive and hook up with HDMI to the TV?
I understand Roku1 may accomplish that but the HDHR3 transmits MPEG2 but ROku1 can only process H264, is that true?
also, what kind of remote control can I use to replicate the cable remote -- or will we have to use the Roku1 remote?
Any help is appreciated.
westsidehf is offline
post #2357 of 2761 Old 02-04-2015, 06:53 AM
Ken.F's Avatar
Liked: 1256
I use a Windows 7 computer with Windows Media Center. I also use Ceton Echo extenders to share Windows Media Center with the other TVs in the house. Xbox 360s can also be used as Media Center extenders.
The HDHomeRun Prime passes along whatever kind of signal your cable company provides. I have FiOS and most of my channels are MPEG-2, but some of my channels are h.264.
Inexpensive Windows Media Center remotes are available if you choose to go that route.
Ken.F is offline
post #2358 of 2761 Old 02-07-2015, 12:48 PM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
I'm not even certain a stand alone Roku can be used. I could be wrong. I believe with out DLNA, you can't escape using a computer as an intermediary. The most common is running Windows Media Center, which can pass the stream to either of the devices Ken mentioned. To use a Roku, I think you need additional software like Media Center 3 or PlayOn.
We have three TV's using our HDHR's: two are connected to PC's running WMC, the third is connected to an Xbox 360.
If you don't have a PC available, pick up a used one on Craigslist. Win 7 and 4Gb ram and your good.
Sent from my Nexus 7 using Tapatalk
leebo is offline
post #2359 of 2761 Old 02-08-2015, 09:31 PM
TornadoTJ's Avatar
Liked: 510
A PS3 can play all channels from an HDHR, even copy once, but the issue is there's no guide.
post #2360 of 2761 Old 03-25-2015, 08:33 PM
leewcraft's Avatar
I thought I'd point out this thread here since HDHR Prime owners may be interested. I'm working on an add-in for a multi-view app in Windows Media Center for multiple channels on one screen. I find it particularly useful for sports, but others have mentioned news/weather as another application for it. Take a look if you're interested.
Sports Bar - New Windows Media Center add-in
leewcraft is offline
post #2361 of 2761 Old 03-25-2015, 09:14 PM
ellisr63's Avatar
Quoted: 990 Post(s)
Liked: 412
I have heard that Microsoft might be dropping support for WMC when Windows 10 comes out. I hope you are not wasting your time.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #2362 of 2761 Old 03-26-2015, 07:06 AM
TornadoTJ's Avatar
Liked: 510
Windows 7 and 8 will be supported for a long time to come. In fact, January 14, 2020 and January 10, 2023, respectively.
post #2363 of 2761 Old 03-30-2015, 08:49 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
How long after support stops would you expect out Home run prime tuners to continue to function?
billmich is offline
post #2364 of 2761 Old 03-30-2015, 09:14 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Forever. They can already work independently of WMC anyway. When MS eventually shuts down the guide servers years from now, 3rd party guides will take their place. So I expect even WMC to work forever as well. Cable card will probably go away before WMC finally breaks.
billmich and Ou8thisSN like this.
mdavej is offline
post #2365 of 2761 Old 03-30-2015, 01:52 PM
TornadoTJ's Avatar
Liked: 510
Just because Windows 7 support stops, doesn't mean we can't keep using it. Look how many people are still on Windows XP.
And SiliconDust is already sending out solutions. HDHR in Kodi, HDHR View, etc.
billmich likes this.
post #2366 of 2761 Old 03-31-2015, 07:36 AM
billmich's Avatar
Quoted: 258 Post(s)
Liked: 60
Thanks for the feedback, guys!!!!!
billmich is offline
post #2367 of 2761 Old 04-12-2015, 07:08 PM
Whoosy's Avatar
Quoted: 12 Post(s)
Silicondust finally has official firmware (non beta) for the prime which no longer checks the cgms protection.
Release 20150406:
  • HDHR4/TC/CC/DC models: Support Kodi add-on.
  • HDHR4/TC/CC/DC models: Fix problem where UPnP channel list or guide data could be truncated in some situations.
  • HDHR4/TC/CC/DC models: Improvements to diagnostic logging.
  • HDHR3-US/DT/EU models: Fix reboot when DNS returns multiple IP addresses.
  • CC models: Eliminate CGMS-triggered DRM. Please run a channel scan on the device or through HDHomeRun Setup after upgrading.
  • DC models: Improvements to repairing streams from YouSee cable.
  • TC models: Improvements to power management.
Whoosy is offline
post #2368 of 2761 Old 04-12-2015, 07:33 PM
Ken.F's Avatar
Liked: 1256
8><---
I updated the firmware on my HDHR3-CC and HDHR4-2US yesterday. I didn't run any channel scan in WMC or in the HDHR setup. I haven't noticed any bad things yet. Maybe I should do it soon.
Ken.F is offline
post #2369 of 2761 Old 04-13-2015, 06:07 AM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
I think I'm gonna wait a few weeks. I haven't had any issues with cgms, so I'm not in any rush to change something that works.
dfkimbro is offline
post #2370 of 2761 Old 04-13-2015, 06:56 AM
bmcn's Avatar
Quoted: 1539 Post(s)
Liked: 2327
Experienced too many annoying WMC 'searching for tuners' type messages during the past 4-5 months so I applied it and rescanned the cc channels. No noticeable difference and received at least one WMC searching message after applying. My SD setup of one HDHR3 and one HDHR Prime has overall performed very well during the past three years.
bmcn is offline
Reply Home Theater Computers
hdhomerun bluray
