HDHomerun Prime Owners Thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #2521 of 2761 Old 01-20-2016, 02:51 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I'm going to make a move. I know this is off topic so will only ask one more question. Do you need sabnzbd with Sonarr?
Sammy2 is offline
post #2522 of 2761 Old 01-20-2016, 02:55 PM
TornadoTJ's Avatar
Quoted: 1612 Post(s)
Liked: 510
Yes.
TornadoTJ is offline
post #2523 of 2761 Old 01-20-2016, 03:59 PM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
No. I also switched from SabNZBd to NZB-Get.
bryansj is offline
post #2524 of 2761 Old 01-20-2016, 05:34 PM
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
is my HD homerun Prime dying?
I got our HD homerun PRIME in 2013. It's been rock solid since then except now. Today, for instance, all the HD channels went out. The SD channels worked fine but the HD channels were scrambled or I got a WMC 'no signal' error. I called Comcast and they said there was an outage, and after a few hours, I am getting HD reception again. However, the quality of service over time has definitely deterioated. Like right now, I tried to tun into TBS-HD and ESPN2-HD and the sound would come in and I'm presented with a black screen. The only way I can get TBS-HD (or other channels this happens on) to work is to either restart WMC or restart the computer, and tune into TBS-HD. it isnt a computer issue because I have replicated this problem on other computers. It also isn't a windows update or something like that which is a problem because I have diabled updates for all our media center PCs (they are only used as set top boxes to watch TV).
So what's the problem: is it Comcast screwing around or is it homerun?
Ou8thisSN is online now
post #2525 of 2761 Old 01-20-2016, 05:41 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Can you post the Prime logs from the web interface?
Do you have a tuning adapter? Does it say "Ready" if you do?
Have Comcast re-send all hits and then power cycle the prime.
If you have a tuning adapter power cycle it first, wait, power down the Prime then bring back up the tuning adapter, then the prime.
Report back.
Sammy2 is offline
post #2526 of 2761 Old 01-20-2016, 06:00 PM
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
Report back.
Do you have any instructions on how to get the prime logs?
I dont require a tuning adapter.
I called this morning when none of the channels were working and the comcast lady did 'something' but at time it didn't do anything since it was an outage. I can call tomorrow and ask them to rehit the box. I have power cycled it a bunch of times this morning trying to get my cable to work but haven't power cycled outside of that.
post #2527 of 2761 Old 01-20-2016, 06:48 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
is it cold where you are?
my cable channels all looked like a mess last night and this morning. ive read that the extreme cold here could have caused a bit of havoc. did comcast move to mpeg4 in your area yet?
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #2528 of 2761 Old 01-20-2016, 07:17 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Report back.
Look in your router configuration page for the mac ID of the Prime then look for the ip address associated with the Prime. It should be something like 10.0.0.xxx or 192.168.0.xxx..Put that in the address bar of your web browser. Altrenatively, open your HDHR Configuration Software and click on any of the three tuners.
Navigate to the CableCARD Screen. Check the status of the CablCARD.. strength, quality, etc.
Navigate to the System Status Screen. Click on System Log and scroll down, looking at what it says. Copy paste it here.
Report back.
Sammy2 is offline
post #2529 of 2761 Old 01-20-2016, 08:31 PM
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
Report back.
I used the code command to paste this but let me know if i should use a different cmd to make it more legible.
Code:
CableCARD Status
  Card ManufacturerMotorola Card Authenticationsuccess Card Validationsuccess 3DES encryptionsupported
OOB Frequency75.250 MHz OOB Lock2.048 Mbps Signal Strength100% (-0.1 dBmV) Signal Quality100% (39.9 dB)
Channel Listcablecard-oob
Code:
System Status
  Hardware ModelHDHR3-CC Firmware Version20150826 DTCP-IPDTCP 1.7-SD20140607 WMDRM-NDTWMDRM 10-SD20130219 Memory Report64 MB SDRAM, 2 MB Flash
Power StatusStandby Boot StatusBooted Device ID1318508E MAC Address00:18:DD:31:85:08 IP Address192.168.1.8 Subnet Mask255.255.255.0
Code:
19700101-00:00:00 System: reset reason = power on 19700101-00:00:01 CableCARD: M-CARD inserted 19700101-00:00:03 System: network link 1000f 19700101-00:00:04 System: ip address obtained: 192.168.1.8 / 255.255.255.0 19700101-00:00:05 CableCARD: Motorola card (0000:0625) 19700101-00:00:05 CableCARD: authentication status: authentication in progress 19700101-00:00:05 CableCARD: authentication status: authentication success, validation success 20160120-20:53:01 CableCARD: time changed from Thu Jan 01 00:00:12 1970 to Wed Jan 20 20:53:01 2016 20160120-21:02:34 Tuner: tuner0 tuning 1005 WTVF 1005 WTVF (auto:85MHz-5) 20160120-21:02:34 Tuner: tuner0 streaming rtp to 192.168.1.16:57737 20160120-21:02:35 CableCARD: tuner0 1005 WTVF 1005 WTVF (auto:85MHz-5) access = subscribed 20160120-21:03:13 Tuner: tuner0 tuning 2 WKRN 0002 WKRN (auto:339MHz-1) 20160120-21:03:13 Tuner: tuner0 streaming rtp to 192.168.1.16:57742 20160120-21:03:14 CableCARD: tuner0 2 WKRN 0002 WKRN (auto:339MHz-1) access = subscribed 20160120-21:03:57 Tuner: tuner0 tuning 17 WNPX 0017 WNPX (auto:339MHz-8) 20160120-21:03:57 Tuner: tuner0 streaming rtp to 192.168.1.16:57745 20160120-21:03:57 CableCARD: tuner0 17 WNPX 0017 WNPX (auto:339MHz-8) access = subscribed 20160120-21:04:54 Tuner: tuner0 tuning 2 WKRN 0002 WKRN (auto:339MHz-1) 20160120-21:04:54 Tuner: tuner0 streaming rtp to 192.168.1.16:51540 20160120-21:04:56 CableCARD: tuner0 2 WKRN 0002 WKRN (auto:339MHz-1) access = subscribed 20160120-21:05:03 Tuner: tuner0 tuning 1002 WKRN 1002 WKRN (auto:85MHz-2) 20160120-21:05:03 Tuner: tuner0 streaming rtp to 192.168.1.16:51545 20160120-21:05:04 CableCARD: tuner0 1002 WKRN 1002 WKRN (auto:85MHz-2) access = subscribed 20160120-21:05:51 Tuner: tuner0 tuning 1006 WZTV HD 1006 WZ (auto:63MHz-6) 20160120-21:05:51 Tuner: tuner0 streaming rtp to 192.168.1.16:51556 20160120-21:05:53 CableCARD: tuner0 1006 WZTV HD 1006 WZ (auto:63MHz-6) access = subscribed 20160120-23:20:28 Tuner: tuner1 tuning 1002 WKRN 1002 WKRN (auto:85MHz-2) 20160120-23:20:28 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160120-23:20:28 CableCARD: tuner1 1002 WKRN 1002 WKRN (auto:85MHz-2) access = subscribed 20160120-23:22:17 Tuner: tuner1 tuning 1108 MSNBC 1108 MSNB (auto:79MHz-4) 20160120-23:22:17 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160120-23:22:17 CableCARD: tuner1 1108 MSNBC 1108 MSNB (auto:79MHz-4) access = subscribed 20160120-23:22:35 Tuner: tuner1 tuning 1606 ES2HD 1606 ESPN (auto:465MHz-2) 20160120-23:22:35 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160120-23:22:35 CableCARD: tuner1 1606 ES2HD 1606 ESPN (auto:465MHz-2) access = subscribed 20160120-23:22:48 Tuner: tuner1 tuning 1605 ESPND 1605 ESPN (auto:465MHz-1) 20160120-23:22:48 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160120-23:22:48 CableCARD: tuner1 1605 ESPND 1605 ESPN (auto:465MHz-1) access = subscribed 20160120-23:22:59 Tuner: tuner1 tuning 1606 ES2HD 1606 ESPN (auto:465MHz-2) 20160120-23:22:59 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160120-23:22:59 CableCARD: tuner1 1606 ES2HD 1606 ESPN (auto:465MHz-2) access = subscribed 20160120-23:24:11 Tuner: tuner1 tuning 1606 ES2HD 1606 ESPN (auto:465MHz-2) 20160120-23:24:11 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160120-23:24:12 CableCARD: tuner1 1606 ES2HD 1606 ESPN (auto:465MHz-2) access = subscribed 20160121-00:01:13 Tuner: tuner1 tuning 1991 SZCHD 1991 STAR (auto:261MHz-1) 20160121-00:01:13 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160121-00:01:13 CableCARD: tuner1 1991 SZCHD 1991 STAR (auto:261MHz-1) access = subscribed 20160121-00:01:24 Tuner: tuner1 tuning 1005 WTVF 1005 WTVF (auto:85MHz-5) 20160121-00:01:24 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160121-00:01:24 CableCARD: tuner1 1005 WTVF 1005 WTVF (auto:85MHz-5) access = subscribed 20160121-00:19:59 Tuner: tuner1 tuning 1108 MSNBC 1108 MSNB (auto:79MHz-4) 20160121-00:19:59 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160121-00:19:59 CableCARD: tuner1 1108 MSNBC 1108 MSNB (auto:79MHz-4) access = subscribed 20160121-00:20:27 Tuner: tuner1 tuning 1220 TBSHD 1220 Turn (auto:459MHz-2) 20160121-00:20:27 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160121-00:20:27 CableCARD: tuner1 1220 TBSHD 1220 Turn (auto:459MHz-2) access = subscribed 20160121-00:20:51 Tuner: tuner1 tuning 1220 TBSHD 1220 Turn (auto:459MHz-2) 20160121-00:20:51 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160121-00:20:52 CableCARD: tuner1 1220 TBSHD 1220 Turn (auto:459MHz-2) access = subscribed 20160121-00:21:58 Tuner: tuner1 tuning 1220 TBSHD 1220 Turn (auto:459MHz-2) 20160121-00:21:58 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160121-00:21:59 CableCARD: tuner1 1220 TBSHD 1220 Turn (auto:459MHz-2) access = subscribed 20160121-01:04:26 Tuner: tuner1 tuning 1002 WKRN 1002 WKRN (auto:85MHz-2) 20160121-01:04:26 Tuner: tuner1 streaming rtp to 192.168.1.33:5001 20160121-01:04:27 CableCARD: tuner1 1002 WKRN 1002 WKRN (auto:85MHz-2) access = subscribed 20160121-01:57:55 Tuner: tuner0 tuning 1002 WKRN 1002 WKRN (auto:85MHz-2) 20160121-01:57:55 Tuner: tuner0 streaming rtp to 192.168.1.33:5001 20160121-01:57:56 CableCARD: tuner0 1002 WKRN 1002 WKRN (auto:85MHz-2) access = subscribed
post #2530 of 2761 Old 01-20-2016, 08:39 PM
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
this week has been absolutely freezing, much colder than normal.
I think maybe they have moved to mpeg4. I haven't lived in Nashville in two years. All I can say is that before I left, the picture quality was actually quite good from comcast. Now it's just a blocky, compressed, almost unwatchable mess. I like to watch Sunday Night football on the projector and the local NBC feed blown up to 10 feet looks horrendous. So does any ESPN/FOX/ABC feed and I swear it wasn't this bad before. We also have 1 analog TV for which we rent a small cable box from them. That is all digital as well so i think maybe they did go to MPEG4 here.
post #2531 of 2761 Old 01-21-2016, 01:34 AM
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
update: the problem, whatever it is, is definitely getting worse. I was just watching MSNBC-HD right now and it just stopped playing and WMC said 'no signal or station available'. I even waited 2 minutes and nothing changed. Then I tried another channel and they worked fine. Going back to MSNBC worked fine but to have a channel abruptly stop playing has NEVER happened before, not in the 3+ years of having the PRIME. I have also noticed at many points tonight that I have limited access to my cable lineup. Channel surfing onto some channels will only play audio, and I have to restart WMC or the computer to get them to work. I have no clue what is different, I have made no hardware changes. the firmware on the PRIME is the current firmware and the only other thing I can think of is that we have a cable amplifier connected on one of the outlets. But it has been there for the last 3 years and I've had no issues with TV reception until yesterday/today. Is this a signal strength issue? Could the comcast tech's be of any help at all?
post #2532 of 2761 Old 01-21-2016, 04:46 AM
bmcn's Avatar
Quoted: 1539 Post(s)
Liked: 2318
Why don't you check it using SD's app?
bmcn is offline
post #2533 of 2761 Old 01-21-2016, 05:42 AM
Ken.F's Avatar
Quoted: 1471 Post(s)
Liked: 1255
I had the same thing happen recently. The trouble was being caused by a WD Access program running on one of the desktop computers on the network. It wasn't even installed on the HTPC but it was causing problems tuning channels in WMC.
To test if something on the network is misbehaving, try un-plugging the ethernet cables for everything on your network except the tuner and the HTPC and see if the problem goes away. If the problem goes away re-connect the network cables for the other devices one at a time until you find out which device is causing trouble.
Ken.F is offline
post #2534 of 2761 Old 01-21-2016, 05:49 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Code:
CableCARD Status
Code:
System Status
Code:
Take a look at the Tuner Status. Start watching a channel then go to Tuner Status and then check the active tuner. Report back the signal strength and quality.
Sammy2 is offline
post #2535 of 2761 Old 01-21-2016, 06:49 AM
Quoted: 648 Post(s)
Liked: 426
Signal strength in my case was good - all close to 90%
Signal quality is where I've seen changes overnight. You basically need it to be 55% or higher to work. Last night after work I was in good shape, but I noticed again this morning that certain channels were dropping to 50% or lower.
Amplifying won't fix bad quality. Its possible there is some ingress somewhere. I live less than a mile up the hill from Comcast's primary hub in Pittsburgh, so hopefully if I do need their help they can do it quickly.
I'm going to try blow drying the outdoor connection and wrapping it in electrical tape tonight, in case moisture has gotten in there.
If I have problems again Saturday morning I'm going to connect my HDHR direct to the line off the street to rule out my internal home connections as the issue.
post #2536 of 2761 Old 01-21-2016, 07:54 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Yet another reason to live in SoCal!
All kidding aside, isn't the outdoor connection the provider's responsibility to keep in good shape?
Also, limiting the number of splitters is key but if you haven't had issues until now I'd say it is on their side unless you have something in your walls, attic or basement chewing your cables. I'm pretty sure you already know this as long as you've been on these forums, pittsoccer33, but the quality of the connector and each splitter in your chain is very important.
At my previous house, I had Charter drop a new cable right off the pole and had one splitter feeding the modem and Prime/TA. When I moved to the new house, I had one of those thick buried cable feeds from across the box street, one splitter to the office where it splits again as before to the modem and Prime/TA. Next week, I have them coming out to install a new splitter for another Prime/TA. For $35 it is well worth it to have them do the install with their quality cabling, splitters and fittings.
Sammy2 is offline
post #2537 of 2761 Old 01-21-2016, 07:58 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
That would be the web page diagnostics, yes?
Sammy2 is offline
post #2538 of 2761 Old 01-21-2016, 08:06 AM
bmcn's Avatar
Liked: 2318
HDHomeRun Config.
bmcn is offline
post #2539 of 2761 Old 01-21-2016, 08:06 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Yet another thing to look at. Too much network traffic and you'll have issues.
This brings to mind another probable cause. If there was an outage due to electrical instabilities (power outage or lighting strikes?) in your area, it could have taken out your router or at least damaged it. A long shot I know, but worth keeping in mind while diagnosing this issue.
Sammy2 is offline
post #2540 of 2761 Old 01-21-2016, 08:08 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
HDHomeRun Config.
I see. I hardly ever use that and checking this out requiers access to the logs. That said, going to the config page and re-running it won'thurt and may show less channels than before becaus of channel weakness from whatever cause it may be.
Sammy2 is offline
post #2541 of 2761 Old 01-21-2016, 08:17 AM
bmcn's Avatar
Liked: 2318
It's in the HDHomeRun folder and provides real time signal strength. No logs required, but agree it's probably good to occasionally rerun setup.
bmcn is offline
post #2542 of 2761 Old 01-21-2016, 08:35 AM
Ken.F's Avatar
Liked: 1255
Network Tuner Monitor is a pretty good program for keeping an eye on things. It shows you a detailed status of all of your HDHomeRun tuners in one display. It includes signal strength and quality, and a lot more.
https://www.silicondust.com/forum/vi...tart=60#p95184
ClearToLand likes this.
Ken.F is offline
post #2543 of 2761 Old 01-21-2016, 09:00 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I get what you're saying but I prefer to have a complete picture of what is going on when I start diagnosis. I have been fortunate enough to never have to deal with weak signals or symbols so, although I've seen this real-time monitoring page, I don't use it. Also, It is difficult on there to determine which channel you're monitoring.
Sammy2 is offline
post #2544 of 2761 Old 01-21-2016, 09:04 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
One other thing comes to mind. What firmware and software version are you using? You may want to consider upgrading to the latest stable version which came out last August.
Sammy2 is offline
post #2545 of 2761 Old 01-21-2016, 09:10 AM
TornadoTJ's Avatar
Liked: 510
You can use antennaweb.org or tvfool.com to get the real channel numbers if you are using an antenna based HDHR. For cable channels, it's more difficult, but in both cases the network/channel name is displayed in the application where it says "Program", so that makes it pretty easy. The easiest way I've seen to get Config to go to the channel you want is to start a stream with WMC or View, which should put Tuner0 in use, then when you go to Config, Tuner0 will be on that channel.
post #2546 of 2761 Old 01-21-2016, 10:00 AM
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
Our power didn't go out over the last couple of days. I haven't installed any new devices on the network within the last few days, or are any devices or computers on and running when they are not in use. The only thing acting up is the prime.
One other thing I have noticed is my internet speed is now markedly slow. I have comcast's 'blast!' service package which was giving me 90/10 speeds, as of yesterday and today, its down to about 50. Not sure if that matters or if something happened to the line which is the cause of all this.
post #2547 of 2761 Old 01-21-2016, 10:01 AM
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
I am , and have been running the latest firmware:
post #2548 of 2761 Old 01-21-2016, 10:05 AM
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
I will be running this while I watch TV for the next few days and report back. It's really sad and frustrating that I have to go through all this as the prime has worked perfectly for so many years and I've checked the signal strength and quality, which has never been less than 99% on all channels.Even now it's always at 99% until it randomly drops all the way down and then a few minutes later goes back up again.
post #2549 of 2761 Old 01-21-2016, 10:05 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Sounds like it's time for Comcast to roll a truck on THEIR dime.
bmcn likes this.
Sammy2 is offline
post #2550 of 2761 Old 01-21-2016, 10:16 AM
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
You know how stingy they are with sending their trucks. I dont want to pay for a house call when it is their fault. What do I say to them to come out here without me having to pay for it, or should I wait till the weather improves?
Reply Home Theater Computers
hdhomerun bluray
