HDHomeRun stream to iPad? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #31 of 57 Old 04-10-2012, 11:43 AM
netant's Avatar
For those interested, we are working hard on making next version of Telly a PC-free solution. Telly 2.0 will enable direct streaming from HDHomeRun (ATSC/QAM/CableCard/DVB) to iOS device.
Currently we are looking for beta testers. How to join beta & more information can be found here at Silicondust forum:
http://www.silicondust.com/forum/viewtopic.php?t=11847
And beta 3 video demo is available here:
http://youtu.be/jcXZYsV2rQI
screenshot(click link below for a full size one):
http://www.telly-app.com/hdhr/Telly_beta3_ipad_3.png
netant is offline
post #32 of 57 Old 04-10-2012, 03:00 PM
amarshonarbangla's Avatar
Quoted: 30 Post(s)
Liked: 43
Kewl
amarshonarbangla is offline
post #33 of 57 Old 04-13-2012, 08:45 PM
jester3's Avatar
Is iPad capable of decoding HD video?
jester3 is offline
post #34 of 57 Old 05-04-2012, 06:29 AM
netant's Avatar
Well, iPad1/2/3 is capable of playing back SD video and iPad2/3 is able to playback 720P is 'fast' mode. 1080i is out of the question for now.
Telly has been renamed to InstaTV and it's free for a limited time. Please note that the currently released InstaTV is a transcoding solution which means a Windows PC is required.
netant is offline
post #35 of 57 Old 05-04-2012, 07:59 AM
monkeymania's Avatar
I'm having trouble detecting any tuners. I'm using a Hauppauge 2650 Cablecard tuner. Based on the help section, I changed the HDHomeRun Setup to default to ATSC / QAM (rather than WMC), but that still didn't work. Rebooted too just in case.
Any suggestions?
monkeymania is offline
post #36 of 57 Old 05-11-2012, 12:39 PM
netant's Avatar
Any suggestions?
For CableCard tuner, it is required for the application to have the same bitness (32 or 64) as the Windows. Are you using 64bit Windows 7? TellyServer currently only have 32bit version and a 64bit build is being considered.
netant is offline
post #37 of 57 Old 06-19-2012, 07:26 PM
netant's Avatar
I received a few bug reports for TellyServer on Windows 8 unable to start.
This will be fixed in next release.
To workaround the issue in current version, just right click 'TellyServer.exe' and 'TellyTuner.exe' then set both compatibility mode to "Windows 7"
netant is offline
post #38 of 57 Old 06-20-2012, 06:53 AM
Quoted: 21 Post(s)
Liked: 31
Sorry for the basic question, but I see no mention of GoodPlayer in either the InstaTV site or the App store. Is a separate player app still required for iPad viewing? If yes, which one(s) supported?
Laserfan is offline
post #39 of 57 Old 06-20-2012, 12:18 PM
netant's Avatar
There are two branches of InstaTV. The one available on AppStore is a transcoding solution that requires a Windows PC and an ATSC/ClearQAM tuner card. No external player is required.
Another branch that is still in development (InstaTV 2.0) is a direct streaming solution that does not require a Windows PC. It streams directly from a HDHomeRun device to iPad/iPhone. It's currently in testing and should be available sometime this summer. It does not require any external player anymore.
We have just released InstaTV 2.0 beta 5 today on TestFlight.
For those who do not have a TestFlight tester account and want to access the app as well, InstaTV is now also available as QuickTV-20120620 on a Cydia repo: http://apt.appbeta.org
QuickTV is based on the exact same source code as InstaTV except it will be updated more frequently.
So just to be clear: On Cydia it's called QuickTV and on AppStore it's called InstaTV wink.gif
Changes:
- New: Requires email for follow-up
- New: Available as QuickTV on AppBeta.org
- New: Show audio property on audio selector
- New: Improved multi-tuner support. Now each HDHR device have a separate channel list. This is useful when there are multiple HDHR devices with different signal source.
- New: Improved native AV decoder
- New: Improved logging for better feedback
- New: Show which tuner is currently used in channel list
- Fix: Change audio stream causes crash
- Fix: Various bugs based on Beta 4 feedback
UPDATE 1: If your JB device can install but can't start the app, please wait....looks like we have a build problem. It works for some devices but not all.
UPDATE 2 (June 24): If you used Absinthe on the Mac to JB and have problem start the app, try Absinthe on the PC
netant is offline
post #40 of 57 Old 06-27-2012, 06:20 PM
jester3's Avatar
I have installed the beta app on my iPad3 and it's awesome! Anyone with a HDHomeRun and iPad should definitely check this out.
It crashed a few times but the SD and 720P video looked flawless. 1080 video is a bit choppy and hope this can be improved.
jester3 is offline
post #41 of 57 Old 07-21-2012, 05:51 PM
netant's Avatar
InstaTV 2.0 Beta 6 is now available for jailbroken devices..
Major changes:
- Fix: lots of crashes
- New: Ignore and continue when there is channel scan error (DVB-C)
- New: Better 1080i playback quality
- New: Improved channel list layout
- New: Support audio only channel (radio)
- New: Able to abort loading channel immediately
- New: 32bit/64bit InstaTV Server beta now available for XP/Vista/7/8
Thanks for all the feedback cool.gif We are working hard to release the app this summer.
netant is offline
post #42 of 57 Old 09-06-2012, 10:34 PM
netant's Avatar
Beta 7 has been posted.
- New: Improved decoder performance and stability
- New: For cable card tuner, verify if a channel is subscribed as part of scan process
- New: Improved icon
- New: Improved channel change work flow and it should be a lot more stable
- New: Added lots independent broadcasters' channel icon
see here for download instructions: http://www.silicondust.com/forum/viewtopic.php?t=11847
netant is offline
post #43 of 57 Old 11-27-2013, 10:35 AM
DaPooch's Avatar
nPlayer app for iOS. Hands down the best solution I've found so far and I've tried A LOT of apps, here'e the quick and dirty benefits
-Universal, one app/ cost for iPhone and iPad.
-Plays EVERYTHING, including subtitles.
-Fantastic interface.
-SMB access for network shares
-UPNP/DLNA (how you access the HomeRun)
-Legit AC3 license
-Frequent Updates/attention from developer
-Doesn't nickel and dime you for in-app upgrades.
Well worth the $5 IMHO
If you want a free solution and you have a jailbroken iOS device XBMC is the answer... also UPNP/DLNA compat.
DaPooch is offline
post #44 of 57 Old 11-28-2013, 07:42 AM
Quoted: 21 Post(s)
Liked: 31
This thread is about the HDHomerun and I see nothing in the nPlayer description to suggest it plays directly from an HDHR. Does it?
Laserfan is offline
post #45 of 57 Old 12-15-2013, 09:55 PM
netant's Avatar
InstaTV Pro is available again:
https://itunes.apple.com/us/app/instatv-pro/id704841894
works for Prime/ATSC/DVB Models and upcoming HDTC...
netant is offline
post #46 of 57 Old 12-28-2013, 09:56 AM
Quoted: 21 Post(s)
Liked: 31
Wow best $9.99 I've spent on an app! Video & audio are just great on my iPad Mini (from my 1st gen HDHR) and my only complaint is that identifying Favorites doesn't seem to work right. At least, I can't get a list of only those stations that I want to show using the Like and Unlike buttons.
I found too that the local OTA programming information is displayed properly also, thought there doesn't appear to be a way to e.g. click on a program such that InstaTV Pro then tunes to it.
Laserfan is offline
post #47 of 57 Old 03-16-2014, 08:09 PM
netant's Avatar
New update added HDHomeRun Plus support and ability to AirPlay to AppleTV (2/3)
Chromecast support is coming soon.
netant is offline
post #48 of 57 Old 03-18-2014, 05:36 AM
Quoted: 21 Post(s)
Liked: 31
The last two versions including 2.5 have been almost completely broken for me, and I've had to revert to 2.3.1 each time. The guide doesn't work at all, and at least for 2.4 the switching of channels was problematic as well (haven't bothered to work much with recent 2.5 given no Guide info is displayed). And with 2.5.0 I've gotten a wierd "select your HDHR tuner" popup every time I change a channel.
Reverting to 2.3.1 can be done, but is really a pain with iTunes and avoiding the update after is not fun either. Am I the only person suffering these problems?
Laserfan is offline
post #49 of 57 Old 07-14-2015, 05:25 AM
J_ph's Avatar
Question Which HDHomerun to stream to iPad 3?
I only need to stream OTA stations to an iPad3. I assume I will be using the InstaTV app.
The HDHomerun Connect supports SD only via wifi, and the HDHomerun Extend will encode HD (and SD?) to h.264.
If I only need SD quality or even less for the iPad, which device do I need. Can the iPad even see the SD data if it's not pre-encoded to h.264. Would the Extend streaming be more consistent, without dropping or buffering problems.
thanks,
j
J_ph is offline
post #50 of 57 Old 07-14-2015, 05:50 AM
TornadoTJ's Avatar
Quoted: 1717 Post(s)
Liked: 539
You need the Extend.
http://www.silicondust.com/products/...run/hdhomerun/
I have both the old Dual (now called the Connect) and the Extend, and I can tell you the Extend offers a much more consistent picture on SD, and works great on HD where the Connect won't work acceptably at all. Tablet functionality is a huge reason for the existence of the Extend.
J_ph likes this.
TornadoTJ is offline
post #51 of 57 Old 07-14-2015, 05:58 AM
J_ph's Avatar
And am I correct that I don't need to put a Mac or PC in the mix. All that I'd need would be the Extend, wifi router, iPad and the app?
thanks again.
J_ph is offline
post #52 of 57 Old 07-14-2015, 06:12 AM
TornadoTJ's Avatar
Liked: 539
That's right.
One thing, I got to thinking, and it just hit me you are talking about iPad. I haven't had an iPad in years, so I didn't think about it, but there's not an HDHR View app available for iPad currently. A long time ago I played around with InstaTV, back when it was really free. Now, it appears free in the app store, but then when you try to use it, you get no sound and you have to pay to unlock the full functionality. I do have an iPhone, and did try it a while back, but since I was unwilling to pay to unlock the full functionality of the app, I can't give you hands-on experience with the Extend on an Apple device.
They used to have two versions of InstaTV - free and pro. Pro required the use of a PC in-between to transcode the data. I have a feeling if the free one were still available, it would work with the Extend, but I just checked and it is no longer on the app store.
post #53 of 57 Old 07-14-2015, 06:35 AM
J_ph's Avatar
thanks, I'll see if I can get in touch with the InstaTV people to see how it's working with iPads.
J_ph is offline
post #54 of 57 Old 07-14-2015, 06:41 AM
TornadoTJ's Avatar
Liked: 539
Do you use Plex? On a whim, I just fired up my Plex client on my iPhone and tested viewing channels through the HDHR Viewer channel for Plex. It works, even on my Prime. Now, it may not meet the criteria you are looking for, since it requires a Plex server be set up, and somewhere you'll need to have ServerWMC set up. It was kind of slow to start up on the Prime, but once started it works great. I don't have ServerWMC configured on my Extend, so I don't know if it would be any faster with it, but my gut feeling is that it would not be any faster since it still has the ServerWMC middle-man.
post #55 of 57 Old 07-14-2015, 06:42 AM
J_ph's Avatar
although, there is this on the horizon from Apple:
http://fortune.com/2015/07/14/apple-...=yahoo_fortune
It may be enough for me to hold out on the HDhomerun setup.
J_ph is offline
post #56 of 57 Old 07-14-2015, 06:50 AM
J_ph's Avatar
I have looked at Plex in the past, but never started. My need for the HDHR is very limited.
I have a small TV that was mounted under a cabinet in our kitchen that finally gave up. And, unfortunately I can't find any 7-9" sets that are not battery operated. I've contacted the companies that make them and they say that they can't be kept on the adapter without burning out the batteries and causing problems with the unit. Not sure how this passed the safety testing... or if there was one.
But I now have an OTA setup w/ Netflix, Hulu, Sling, and I would like to clean that up. I'm hoping that the Apple offering will be the answer.
regards,
j
J_ph is offline
post #57 of 57 Old 07-14-2015, 08:53 AM
TornadoTJ's Avatar
Liked: 539
The Roku is already pretty fantastic, but it doesn't support AirPlay if that matters to you.
A super-cheap Android tablet might be the ticket for you if you can't get the iPad working. The wife uses a little 7" LG and it works great. I saw some Android tablets on sale at MicroCenter today for $29.
Reply Home Theater Computers
