Netflix in WMC hangs after video is done - AVS Forum | Home Theater Discussions And Reviews
Old 10-27-2011, 06:36 PM - Thread Starter
leewcraft's Avatar
I'm having an issue with the Netflix plugin on my Windows 7 MC PC. Frequently, as soon as a video is over, the PC just sits there at the final screen of the video (like the 20th Century Fox logo, for example) and doesn't return to the WMC interface to navigate back to something else. The only way I've figured out to get out of it is to bring up Task Manager and kill it, which is really annoying without a keyboard hooked up. It does this about 75% of the time when we're watching various things on Netflix, but sometimes does go back. I've tried un-installing and re-installing the Netflix plugin and doing all the latest WMC updates. Anyone have any other ideas?
leewcraft is offline
Old 10-27-2011, 08:26 PM
Ruiner's Avatar
Perhaps try the Silverlight 5 beta?
Ruiner is offline
Old 10-27-2011, 09:27 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
Yep, same here for the past few weeks. It doesn't seem to be every video though -- but it's every Pink Panther cartoon and of course that's what the kids want to watch .
StardogChampion is offline
Old 10-28-2011, 06:42 AM
jriver's Avatar
Quoted: 91 Post(s)
Liked: 69
Did you try pressing the stop button? Or the next track button?
Jim Hillegass / JRiver Media Center
jriver.com or Owners Thread at AVSForum
jriver is offline
Old 10-28-2011, 07:53 AM
Quoted: 93 Post(s)
Liked: 160
WMC becomes unresponsive and you have to kill it with Task Manager. It will not respond to remote, keyboard or mouse. C'est la vie.
Old 10-28-2011, 08:28 AM
Roussi's Avatar
Quoted: 45 Post(s)
Liked: 36
Uncanny. I had to force-close WMC after a Pink Panther video yesterday...
How is this even possible?
Roussi is online now
Old 11-01-2011, 06:12 PM - Thread Starter
leewcraft's Avatar
Yeah, stopping the video before it reaches the end works fine. But if you're not paying attention, it's annoying to have to kill Media Center. Maybe I'll give the Silverlight Beta a try.
Old 11-07-2011, 07:10 AM
Bobcrane's Avatar
Did anyone have luck with the Silverlight beta?
I just built a second HTPC. For the first half a dozen shows no problem. Now it's locking up on almost all of them. Original HTPC has had this happening for a few weeks.
I ended up writing a batch file to kill ehshell.exe so my wife can RDP in and click something to force close media center when I'm not home.
Bob
Bobcrane is offline
Old 11-07-2011, 10:51 AM
Erighan's Avatar
Quoted: 14 Post(s)
I've been experiencing the same exact problem over the last few weeks. If anyone has a solution, please help. The wife gets very frustrated with this type of stuff...
Erighan is offline
Old 02-26-2012, 02:37 PM
Bengalih's Avatar
Anyone still struggling with this?
Here is the most comprehensive thread I have found on this issue.
Unfortunately, I've tried everything listed with no success. I'm getting this issue almost 25% of the time.
This is a newly built system. I'm pretty sure the issue is with Silverlight or perhaps IE9+Silverlight combo. Finding and installing a Pre-5 Silverlight is not an option, as there are plenty of PQ tearing display issues before 5.
Hopefully someone has found something that works (other than automating a complete reset of WMC).
Bengalih is offline
Old 03-24-2012, 01:35 PM - Thread Starter
leewcraft's Avatar
I found that same thread and did as they suggested, and it's now working fine for me. The key from that thread is to uninstall Silverlight using MATS and not just through Control Panel, as it cleans up some registry keys in the process that a normal uninstall doesn't do. If you've done that and it's still not working, I don't know what else to try.
