7MC remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-28-2011, 05:30 PM - Thread Starter
Metallica's Avatar
I bought a remote that controls MC, and it does it well. The only issue I'm running into is movie controls while watching an MKV. I can't fastforward/rewind unless I drag the bar down at the bottom with my mouse. The FF/RW buttons on the remote will only bump forward with every press about 30 - 60 seconds or so, but I can't hold it down to get it to go faster .. so if I wanted to FF 30 mins into a movie, it would take forever unless I just get up and do it manually.
With other movie files I don't seem to have this issue. I'm using MC + MB
Metallica is offline
post #2 of 4 Old 10-28-2011, 08:27 PM
bryansj's Avatar
Quoted: 1377 Post(s)
Liked: 638
MKVs have that problem in WMC. Here is a trick that might help. If you press a number key and then Skip Fwd or Back it will skip that many times at once. If your skip fwd is indeed 60 seconds then hitting 9 + Skip Fwd will move it nine minutes forward. You can also use more than one digit like 30 + Skip.
There is also a registry edit that allows you to change the number of seconds you skip. I think I have 45 fwd and 30 back.
bryansj is online now
post #3 of 4 Old 10-28-2011, 10:55 PM
tawd1992's Avatar
I'm not sure about MKV playback, but while playing recorded tv in MCE you can enter the number in minutes you want to go to & then hit play & MCE will go to that time in the show. So if you wanted to go to the 45 minute mark, just press 45 & then the play button.
tawd1992 is offline
post #4 of 4 Old 10-29-2011, 10:58 AM
sievers's Avatar
Yes that works for mkv too. I was a little miffed about this at first too, but 1 minute increments works really well to get you where you need to go. At this point I prefer it to tracks or fast winding.
sievers is offline
Reply Home Theater Computers
